LG55UB850V no picture or audio - flashing LED's help please?
  • Scoff
    • Jul 2017
    • 101
    • Uk
    #161
    Re: LG55UB850V no picture or audio - flashing LED's help please?
    No difference with 3D turned off. Same behaviour with 3D on and off. Does this question relate to R13006 which is for 3D_EN_LGD_120Hz? This resistor is not present on by board, yet the service manual does NOT say it is optional?
    Another resistor that the service manual says should be present, but it is not, is R13005 - If I am reading the board numbers correctly? This says Non-LGD 60 Hz T120 module UB85 so perhaps doesn't apply to my board as I do have the T120?
    I found a picture online of another EAX65684604 Main Board which also is missing R13018 and R13019
    so perhaps some configurations of this board are not supposed to have these 2 resistors, but the service manual has an error and should show OPT next to them...
    Either way, they aren't there on my board and never were. I will continue with the freeze test next and see if that reveals anything.
    • Diah
      • Feb 2013
      • 6483
      Originally posted by Scoff
      Red arrow side of R13018 and R13019 = 3.272v STABLE
      Yellow arrow side of R13018 and R13019 = Fluctuates in time with buzzing, between 3.299v and 3.304v. During each 2 second 'buzz' the voltage climbs from 3.299 up to 3.304v, and when the buzz stops, the voltage falls back down to 3.299v.
      we do know S.M are internal documents delivered with other sheets of suggestion and repair steps which we don't have and just we guess issue on MB.
      so yes R13018 and R13019 not at MB but they exist at S.M. mean its could be solution or too test way if one of source or gate tap IC pull abnormal currents at panel ( you said ribbon cable contact pins are good. and when you disconnect one a time or both of ribbon the buzzer stop )
      so i would put 2 SMD 4.7K in place and see if this rail became stable easy cheep way to try.... if not just remove them.
      • Scoff
        • Jul 2017
        • 101
        • Uk
        #163
        I just want to say thanks for all the help on this thread. I've learnt a lot about circuit boards and the general workings of LCD TVs. Unfortunately due to other commitments, I can't spend any more time on this, so will have to store the tv and hope that the correct main board comes up for sale at some point in the future.
        • Diah
          • Feb 2013
          • 6483
          sorry MAN. if you were disappointed some how.. the service manual some time issued after the TV in production one years or more.. and we can find MB different version too over all brands. this mean any we find on SM. it could be correction of later version on MB. this i do used before at my work.. its not only TV. this happened always after any new issue appears after using product at end customer . so need to change some parts or add some to solve problem.
          if we do know the issued time stamp of S.M will explain its years after 2016.
          wish you good luck.
          • toke lahti
            • Jun 2022
            • Finland
            #165
            WOW,
            this was a long thread.
            I'm in similiar situation with just entry level skills and equipment.
            So maybe this 55UB850V-ZD goes to recycling center...
            BUT,
            what I'm still curious is, what does those FIVE FLASHES mean?
            (Just registered to ask this...)
            • toke lahti
              • Jun 2022
              • Finland
              #166
              I made a standard bake to my main board 10min 200°C.
              And the backlight started to glow!
              But, no picture, only vertical magenta lines with constant space between each other.
              Anybody recognises this malfunction?
              What next?
              https://drive.google.com/open?id=16Y...m&usp=drive_fs
              • peterkos2
                • Nov 2020
                • 43
                • Slovensko
                #167
                Hello everyone.
                This is a great forum, it always helps me.
                This topic also helped me with exactly the same problem. I also lacked 12V power supply to the panel and after warming up the TV started up.
                Thanks to everyone
                • peterkos2
                  • Nov 2020
                  • 43
                  • Slovensko
                  #168
                  Hello. The same TV was returned to me again with the same error, but after warming up the LED LD1900 lights up, but not fully. 12V is missing again on the panel. Didn't anyone solve it already?
                  • peterkos2
                    • Nov 2020
                    • 43
                    • Slovensko
                    #169
                    I also have no voltage on DRV_ON
                    • krissie
                      • Apr 2023
                      • Nederland
                      #170
                      Hello All, I have a simelar problem. Does anyone have a replacement board for sale or is there an equivalent that will work in this tv?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #171
                        From my experience with similar boards, seems more like a ceramic capacitor plague developing. In a few common areas they short.
                        • tjrudd1310@aol.com
                          • Dec 2023
                          • Uk
                          #172
                          Hi I have the same problem same tv , turned it off then went to turn it on and nothing , I have the same reading on the t-con F1 0.8volts only one led on the main board and the led on the power board flashing 5 times .
                          has anyone found any main boards or compatible boards yet ? Or a fix for the main board ?
                          • elviscen
                            • Apr 2022
                            • 8
                            • Slovenia
                            #173
                            Hi All,
                            I have the same problem and no main boards available on the internet.
                            Anyone have found any solution for this problem?
                            Maybe re-baling the CPU will work?
                            Thanks.
                            • Ubleha
                              • Sep 2012
                              • 5
                              • BiH
                              #174
                              Reflow IC100 works 100%
                              • nomoresonys
                                • 12306
                                • U.S.
                                #175
                                Bad bga chip then, really 9 pages to get to this conclusion?
                                • wylde
                                  • Sep 2025
                                  • FR
                                  #176
                                  Firstly thanks to all involved on this thread - although I am coming in many years later there were some useful ideas and the initial problem description was perfect, as well as ongoing comments from Scoff and Diah helped a lot but also distracted me from the most direct repair which should be focused on a faulty mainboard.
                                  OK - I am summarizing these as my problem was exactly the same as the post#1 and I found a solution that many people with medium electronics background may be able to repair.
                                  Option 1.
                                  If you have the exact same problem as post#1 - the most direct repair is to replace the mainboard- yes hard to find , or send the mainboard off to have the flat chips under the heatsinks heated and reflowed.
                                  Option 2.
                                  If you have the exact same problem as post#1 - you can reflow it yourself I will outline what I used and an explanation in the next post - this is not exceptionally hard , I used a good quality heat gun(not even electronics grade) with temp setting and and aluminium tape / masking tape as well as flux and solder (the solder was not used on the board only used to get a gauge for the heat need to melt the solder and dial in the time and heat setting for the heat gun for me it was 300 degrees celcius and less than a minute - using the flux around each chip to determine when to stop)- probably the hardest part is unsoldering and removing the heatsinks and putting them back in place. I DID NOT FEEL CONFIDENT DOING THE BAKE TECHNIQUE - reason being there are so many plastics and micro caps and components that baking could damage and start another set of problems.
                                  OVERVIEW
                                  Some of the other solutions outlined on the 9 pages are way too involved for me so I will outline what I have learnt after about 10hrs of reading, watching video repairs etc. SPECIFIC LG tvs and specifically these models can have multiple false ideas to problem check and can be difficult to rule out other faulty components so I will outline on what I have found on next post. I am sure the PROS know what to look for but I was coming from very little experience only having 2 TV repairs under my belt.
                                  my setup / problem - I used Option 2. to repair.
                                  tv model: 55UB850V-ZD
                                  outer casing model 55UB850V-ZD.BEUWLJP
                                  mainboard model: EAX65684604 (1.0)
                                  mainboard sticker: MJM48164B300287 287216546 55UB850V-ZD.BEEWLJP EBT63083605
                                  • Green Probe
                                    Recapping a Denon AVR X6400h SMPS
                                    by Green Probe
                                    (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                                    Disclaimer: I'm an amateur hobbyist and will get things wrong.
                                    Always use caution when working around mains power and high voltage capacitors!
                                    Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                                    SYMPTOMS:
                                    -No display...
                                    07-18-2025, 03:36 PM
                                  • STKR123
                                    Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                    by STKR123
                                    As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                    I wonder if re-flashing the BIOS might be of any use here.
                                    As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                    There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                    11-03-2024, 06:58 AM
                                  • rabbituk
                                    Sony HCD BX7700dbi CMT flashing standby
                                    by rabbituk
                                    I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                                    So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                                    02-11-2025, 05:05 PM
                                  • Bloopeta
                                    Samsung UE43KU6400U Flashing Red Standby Light
                                    by Bloopeta
                                    Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                                    Power button does nothing
                                    Have unplugged the mainboard, and backlights illuminate.
                                    Have tried removing panel ribbon cables one at a time, and that makes no change.
                                    With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                                    Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                                    09-11-2023, 02:34 AM
                                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                    I am comparing them to a brand new one that I installed
                                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                    I going to let it run for several days before I remount back on the wall next to the...
                                    09-05-2024, 06:48 PM
