Vizio TV E470VL SMPS Flucuation Output Voltage
  • R_J
    • 9607
    Re: Vizio TV E470VL SMPS Flucuation Output Voltage
    That is just paint marking where the ic is located
    • dholley
      Mr. Blinky
      • Jan 2022
      • 87
      thank you!
      • dholley
        Mr. Blinky
        • Jan 2022
        • 87
        I replaced the IC. No output voltage. Her are the voltages of the IC
        1. drain 167
        2. Ground 0
        3. Vcc 0
        4. FB 0.59
        5. Sync
        6. Vstr 77.2
        Any suggestions?
        • dskall
          • Oct 2016
          • 2905
          • usa
          #84
          I didn't see but assume R_J had you check the diode and capacitor connected to pin 4.
          • dholley
            Mr. Blinky
            • Jan 2022
            • 87
            Are you referring to ZD103? If yes, then with power off and in diode test mode it is 1.72 one way and .602 the other
            For the capacitor are you referring to c109? If yes, can tell me the best method to test it?
            • dholley
              Mr. Blinky
              • Jan 2022
              • 87
              Any suggestions why no output voltage and no voltage at Vcc.
              Q709 Mosfet (pictured attached circled in red) has very low voltage; around 2 to 3 volts and is unstable
              • dskall
                • Oct 2016
                • 2905
                • usa
                #87
                You said you damaged traces. Did you measure on the trace and pin to confirm you have continuity between pin and trace?
                I would pull ZD103 a C109 off the board and check them. I would also then check to see if there is any voltage on vcc with them disconnected. Start up voltage is supplied to pin 4 from pin 6.
                  • 12306
                  • U.S.
                  #88
                  I agree Dskall, I've been suspect of that zener since post 64 at least.
                  • dholley
                    Mr. Blinky
                    • Jan 2022
                    • 87
                    I have checked the traces and all 6 ic pins and they are good.
                    I checked ZD103 with another Voltmeter, it shows 0.579v one way and OL the other. My guess is this voltmeter uses less volts for testing compared to the other VM that showed voltage each way. ZD103 and C109 share the same traces for each of side of their leads which might account for why there is voltage each way on ZD103 with the VM that has a higher voltage. I'm not real good in installing or removing SMD so I would prefer to wait on doing that until all other troubleshooting options are exhausted.
                    You mentioned that start up voltage is supplied to pin 4 from pin 6, can you help me better understand how it works; Is Pin 4 Feed back and Pin 6 Voltage Start up? Pin 6 has 77.2 volts when the power supply is plugged in. This has been about 2 and 1/2 month project and it gets discouraging at times. I appreciate your help.
                    • Diah
                      • Feb 2013
                      • 6487
                      hold on... yours OP Photo what are this jumper you did ??? for what?? if its for simulated power on then its wrong.
                        • 12306
                        • U.S.
                        #91
                        No worries on that, the other meter read it correctly, I'd say it's fine.
                        • dholley
                          Mr. Blinky
                          • Jan 2022
                          • 87
                          The jumpers allow me to check the 5 volt output when the board is right side up
                          • Diah
                            • Feb 2013
                            • 6487
                            you have Stanfby pin i think it is stable 3.3v... this pin need to jumper it with power on /off then you will have 5V and 12V.
                            • dholley
                              Mr. Blinky
                              • Jan 2022
                              • 87
                              I not sure I understand your post. There is no output voltage of any kind
                              • Diah
                                • Feb 2013
                                • 6487
                                how it come.. then how you were testing LOL
                                you had the PCB out side the TV. so at plug in wall you dont have Standby V at the socket where you did jumber to your messurements ?? black probe refrences to GND on COLD area.? if you dont have standby then yours HOT area dont work.
                                • dholley
                                  Mr. Blinky
                                  • Jan 2022
                                  • 87
                                  There is 167volts at the filter capacitors and 167 at the drain of the ic pin 1
                                    • 12306
                                    • U.S.
                                    #97
                                    Strange indeed.
                                    • Diah
                                      • Feb 2013
                                      • 6487
                                      nothings strange.. from start he did wrong. yours post #48 i don't know who told you or how you come to this idea... the threat so long and allot of replacement you did .. good luck
                                      • dholley
                                        Mr. Blinky
                                        • Jan 2022
                                        • 87
                                        Hi Diah, I’m just starting out in electronics and welcome any insights you can share about electronics
                                        • Diah
                                          • Feb 2013
                                          • 6487
                                          1. The 3 main filter caps all have approximately 167 volts steady
                                          2. I have replaced 4 mosfets next to what I think is called the inventor transformer (big black transformer) pictures attached
                                          3. I have replaced Fuse F102 with an equivalent
                                          4. I have check all diodes and caps and they seem to be ok
                                          5. I replaced the 431 chip at U201
                                          Pictures attached for reference
                                          thank you for your help!!
                                          no problem... we go back to yours first post... why you changed f102.. can you show us the original f102? now u used R .. !!!
                                          • electron_jj
                                            Panasonic TH-L42D25A checking the PSU output voltage
                                            by electron_jj
                                            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                            08-29-2021, 08:13 AM
                                          • David Miteff
                                            NM-D521 rev. 2.0 output voltage on CPU coils seemingly low
                                            by David Miteff
                                            Hello, guys!
                                            As the title says - the board is NM-D521, on the input of the CPU coils I read 1.2-1.3V, which should be normal, but on the output I read around 0.6-0.8V. The laptop bootloops with no picture.
                                            As of right now I don't have a thermal camera, so I can't confirm a shorted or partially shorted CPU chip. Do you have any other suggestions as of why the output voltage might drop like that?...
                                            12-30-2024, 07:02 AM
                                            MT3608 Step-Up Converter IC Datasheet
                                            The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                                            Internal soft-start results in small inrush current and extends battery life.
                                            The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                                            10-07-2024, 05:02 AM
                                          • Ri5ux
                                            Playstation 5 2 Second BLOD, F3501 Voltage Output Question
                                            by Ri5ux
                                            Hi there, just wondering if anyone out there who has a semi-working or working PS5 board could check the output voltage on F3501's buck converter for me, with and without power. I have 12V on the input, fuse not blown, no output voltage on that IC, with or without power, and no shorts present.
                                            Symptom: 2 Second BLOD
                                            Testing: All other rails seem present. APU, SSD, South Bridge, and RAM confirmed to be powering up using a thermal camera. Monitoring the current draw of the 12v rail shows a somewhat normal boot cycle of the south bridge. Jumps up to 300ma, and down to 0....
                                            09-09-2023, 06:57 PM
