Vizio TV E470VL SMPS Flucuation Output Voltage
  • nomoresonys
    • 12284
    • U.S.
    #121
    Re: Vizio TV E470VL SMPS Flucuation Output Voltage
    Yep, that zener is shot, does cap read short now that its off the board? doubtful but dont hurt to make sure.
    • nomoresonys
      • 12284
      • U.S.
      #122
      best to practice soldering and desoldering on just any old scrap of pcb board, theyre in most electronics, so just about any old nonworking device, tear apart and practice on the boards.
      • nomoresonys
        • 12284
        • U.S.
        #123
        zener has tiny writing on it telling its value, check it under magnification, cap is probably ok, make sure its not still reading short in diode mode, then check it in ohm mode. check across where they come off the board and make sure the short is gone.
        • dholley
          Mr. Blinky
          • Jan 2022
          • 87
          At the the moment I think the Cap is covered with alloy, because I don't see the part anywhere else!!! and with that testing is not possible. Any idea about a replacement part for the zener and cap? Are those types of capacitors polarized?
          • dholley
            Mr. Blinky
            • Jan 2022
            • 87
            our messages occurred at the same time so I have you answer about the zener. Can you tell me if the cap is polarized?
            • nomoresonys
              • 12284
              • U.S.
              #126
              theyre nonpolorized, pretty sure you can use a cap thats the same size, just make sure its a cap, zener value is on it tiny writing.
              • dholley
                Mr. Blinky
                • Jan 2022
                • 87
                thank you!
                • dholley
                  Mr. Blinky
                  • Jan 2022
                  • 87
                  The ZD104 has 18 ZD written, so is that an 18 volt zener diode? I found cap c107 buried in some alloy, it is about the 1/4 the size of a pencil tip. If I did it correctly is measures about 66 pf, does that sound right? It was not short.
                  • nomoresonys
                    • 12284
                    • U.S.
                    #129
                    yes 18 volts, measure the cap in ohm mode, what do you get?
                    • nomoresonys
                      • 12284
                      • U.S.
                      #130
                      did you measure across the pads the cap came off of and the holes the zener came out of, no more shorts there right?
                      • nomoresonys
                        • 12284
                        • U.S.
                        #131
                        as long as its not shorted and isnt reading very low ohms, i would put it back in with the new zener and see what you get.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          #132
                          I think you should have a diode and and a 10uf cap in the circuit also.
                          • dholley
                            Mr. Blinky
                            • Jan 2022
                            • 87
                            As of yet I don't see a diode on Vcc Pin 3, I don't see a 10uf cap, but there is a 47uf. I have tested that cap I think it is approximately 43uf
                            • dholley
                              Mr. Blinky
                              • Jan 2022
                              • 87
                              The cap charges up very quickly in ohm mode, so there is not really a measurement for before it goes to OL
                              • dholley
                                Mr. Blinky
                                • Jan 2022
                                • 87
                                Correct
                                • dholley
                                  Mr. Blinky
                                  • Jan 2022
                                  • 87
                                  Ok
                                  • nomoresonys
                                    • 12284
                                    • U.S.
                                    #137
                                    I think the reason is you need to set meter higher in ohm mode to get a steady reading, its probably ok.
                                    • dholley
                                      Mr. Blinky
                                      • Jan 2022
                                      • 87
                                      When installing the zener diode does the dot / bar go to the pointed arrow side ?
                                      I lost the capacitor, I think it is 66 pf, how critical is it match the original cap?
                                      • nomoresonys
                                        • 12284
                                        • U.S.
                                        #139
                                        Yes the black stripe to bar side, I think you will be ok with a cap the same size, look at one of your other zeners to verify orientation.
                                        • dholley
                                          Mr. Blinky
                                          • Jan 2022
                                          • 87
                                          It is a head scratcher! I replaced the zener diode and the cap. There is approximately 2.2 volts at Vcc which is better than zero I guess. But still no output voltage. With the power off and multimeter in diode mode Vcc to ground shows about 1.47 volts, before changing the zener I think it was approximately.02 volts.
                                          I sprayed the board front and back with freeze spray with power on but did not find any obvious shorts.
                                          Any suggestions?
                                          • electron_jj
                                            Panasonic TH-L42D25A checking the PSU output voltage
                                            by electron_jj
                                            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                            08-29-2021, 08:13 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • David Miteff
                                            NM-D521 rev. 2.0 output voltage on CPU coils seemingly low
                                            by David Miteff
                                            Hello, guys!
                                            As the title says - the board is NM-D521, on the input of the CPU coils I read 1.2-1.3V, which should be normal, but on the output I read around 0.6-0.8V. The laptop bootloops with no picture.
                                            As of right now I don't have a thermal camera, so I can't confirm a shorted or partially shorted CPU chip. Do you have any other suggestions as of why the output voltage might drop like that?...
                                            12-30-2024, 07:02 AM
                                            MT3608 Step-Up Converter IC Datasheet
                                            The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                                            Internal soft-start results in small inrush current and extends battery life.
                                            The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                                            10-07-2024, 05:02 AM
                                          • Ri5ux
                                            Playstation 5 2 Second BLOD, F3501 Voltage Output Question
                                            by Ri5ux
                                            Hi there, just wondering if anyone out there who has a semi-working or working PS5 board could check the output voltage on F3501's buck converter for me, with and without power. I have 12V on the input, fuse not blown, no output voltage on that IC, with or without power, and no shorts present.
                                            Symptom: 2 Second BLOD
                                            Testing: All other rails seem present. APU, SSD, South Bridge, and RAM confirmed to be powering up using a thermal camera. Monitoring the current draw of the 12v rail shows a somewhat normal boot cycle of the south bridge. Jumps up to 300ma, and down to 0....
                                            09-09-2023, 06:57 PM
