Vizio TV E470VL SMPS Flucuation Output Voltage
  • dholley
    Mr. Blinky
    • Jan 2022
    • 87
    Re: Vizio TV E470VL SMPS Flucuation Output Voltage
    I have ordered a new IC and optocoupler. I will update with results once those are installed.
    • dholley
      Mr. Blinky
      • Jan 2022
      • 87
      I replaced the IC and optocoupler and unfortunately the fluctuating voltage is the same as before, between 9 and 10 volts at Vcc and about 2 volts at the 5 volt output
      • R_J
        • 9535
        So I guess pin 4 is still 0 volts?
        Have you tried replacing C104 & C105?
        • dholley
          Mr. Blinky
          • Jan 2022
          • 87
          Pin 4 is zero volts, C104 and 105 test ok with an ESR Meter. ZD251 is just below the voltage outputs on the bottom of the board. Measuring one way is .731 the other 1.671 is that a normal reading?
            • 12096
            • U.S.
            #65
            No, take it out of circuit and test again, you are testing in diode mode with tv unplugged right?
            • R_J
              • 9535
              • dskall
                • Oct 2016
                • 2905
                • usa
                #67
                Have you checked secondary side for shorts?
                • dholley
                  Mr. Blinky
                  • Jan 2022
                  • 87
                  Zd251 was tested in diode mode with the power off. Working with small surfaced mounted components is not something I'm good at so I would like to save that for last if needed.
                  I have looked and looked and looked for shorts but no luck yet.
                  I understand that one method to test for shorts in a switch mode power supply is to use a diode as a jumper and install at the output side of the optocoupler, with the diode installed with the stripped side (I think you call that the cathode) at pin 3 (picture attached). Supposedly the shorted component will become hot within a second or two. I pre-connected my mulitimeter to ground and the 5 volt output. Assuming I did this correctly, the output voltage was 3.5 volts steady, but there was no obvious hot component. I left the power applied for approximately 10 seconds but was concerned about unknown side effects from this test procedure. I also tested for standby voltage with this method, still no standby voltage
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    #69
                    And your voltages where stable on input side? I would think bypassing your feedback would give you over 5v. Have you tested your main caps?
                    • dholley
                      Mr. Blinky
                      • Jan 2022
                      • 87
                      I did not check the input side. The main caps are approximately 167 volts and stable
                      • dholley
                        Mr. Blinky
                        • Jan 2022
                        • 87
                        I may have misunderstood your previous question, the input side (hot side) is good and main caps are stable.
                        • dholley
                          Mr. Blinky
                          • Jan 2022
                          • 87
                          I put everything back together and tested the 5volt output and believe it or not the output was 5.25 volts stable!!! I then reinstalled the SMPS back into the TV and believe it or not it came on!!! Unfortunately before I could connect my laptop, the TV went off. I took the SMPS back out and found no output power and no voltage at Vcc but there is 167 volts at the filter caps. Upon closer inspection I found a black residue on the bottom of the board at the IC and where the SMPS was installed on the TV there was a burn mark that matched the location of the IC. I assume the IC burned up. My question how do I determine if something shorted the IC or if I did something to short it. Once while testing the IC the mulit meter probe slipped and created a spark, maybe I shorted it at that time. I have ordered a replacement IC. And to add insult to injury in de-soldering the IC for a second time I tore at least 3 of the pads. I have a fair amount of determination to fix the power supply but sometimes it feels like a mountain
                          • dholley
                            Mr. Blinky
                            • Jan 2022
                            • 87
                            I was not able to find an exact datasheet of the original IC. This is the replacement IC FSQ0465RSWDTU. I'm attaching the data sheet for it. Could someone confirm if it is a suitable replacement?
                            I'm also attaching a picture of the original IC
                            • lotas
                              • Jan 2016
                              • 4535
                              • Russia
                              #74
                              Your original Q0465R (bottom line) is FSQ0465RS/RB (this is the full label).
                              • dholley
                                Mr. Blinky
                                • Jan 2022
                                • 87
                                thank you!!
                                • dholley
                                  Mr. Blinky
                                  • Jan 2022
                                  • 87
                                  there seems to be a big difference between RS and RB, is there a way to tell which one the original part was?
                                  • dholley
                                    Mr. Blinky
                                    • Jan 2022
                                    • 87
                                    The first IC I purchased may not have have been an equivalent replacement. Hopefully FSQ0565RQWDTU is. one item that is different from the original is the Continuous Drain Current Max; on the original it is 4.00 on the 565RQ it is 2.8. I don't know how the Continuous drain current works so I ask Do you think having an IC that has lesser rating for this characteristic would have a negative impact on the switch mode power supply? Data sheet attached
                                    • R_J
                                      • 9535
                                      That is how much current the internal mosfet can handle not what it draws.
                                      I can't find a datasheet on the original R only the replacement which are the RS (1.8A) or the RB (3.0A) so I would pick the RB version, Or you can go to the one you ordered, it should also be fine.
                                      The problem won't be related to the current rating on the controller ic.
                                      • dholley
                                        Mr. Blinky
                                        • Jan 2022
                                        • 87
                                        Thank you RJ!!!!
                                        • dholley
                                          Mr. Blinky
                                          • Jan 2022
                                          • 87
                                          Can you tell me what the black area is at the 6 pin IC? Is it a kind of epoxy? Does it help in the removal heat? Some of it was removed when I de-solder the IC. Is it important to replace? If yes, can you tell me where to purchase. Picture attached.
                                          • electron_jj
                                            Panasonic TH-L42D25A checking the PSU output voltage
                                            by electron_jj
                                            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                            08-29-2021, 08:13 AM
                                          • David Miteff
                                            NM-D521 rev. 2.0 output voltage on CPU coils seemingly low
                                            by David Miteff
                                            Hello, guys!
                                            As the title says - the board is NM-D521, on the input of the CPU coils I read 1.2-1.3V, which should be normal, but on the output I read around 0.6-0.8V. The laptop bootloops with no picture.
                                            As of right now I don't have a thermal camera, so I can't confirm a shorted or partially shorted CPU chip. Do you have any other suggestions as of why the output voltage might drop like that?...
                                            12-30-2024, 07:02 AM
                                            MT3608 Step-Up Converter IC Datasheet
                                            The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                                            Internal soft-start results in small inrush current and extends battery life.
                                            The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                                            10-07-2024, 05:02 AM
                                          • Ri5ux
                                            Playstation 5 2 Second BLOD, F3501 Voltage Output Question
                                            by Ri5ux
                                            Hi there, just wondering if anyone out there who has a semi-working or working PS5 board could check the output voltage on F3501's buck converter for me, with and without power. I have 12V on the input, fuse not blown, no output voltage on that IC, with or without power, and no shorts present.
                                            Symptom: 2 Second BLOD
                                            Testing: All other rails seem present. APU, SSD, South Bridge, and RAM confirmed to be powering up using a thermal camera. Monitoring the current draw of the 12v rail shows a somewhat normal boot cycle of the south bridge. Jumps up to 300ma, and down to 0....
                                            09-09-2023, 06:57 PM
