Samsung UN55EH6000F Power issue
Re: Samsung UN55EH6000F Power issue
I'm now just guessing at things and tested this resistor RP820 and out of circuit it's 0.11 but I can not find a chart online that the colors work with. Under the scope it looks black, gold, black, gray, black. but this comes as an error on the calculators.Comment
The resistor is ok. That is the source resistor for the pfc mosfet.Comment
I don't have a schematic, I am using the pictures of the board. I would try grounding the BLU_ON/OFF pin CNM803 pin6 and see if the B5v and B13v stay up
It might be that the backlight drive circuit is killing the B13v?Last edited by R_J; 02-03-2022, 03:45 PM.Comment
So when the backlight circuit is turned on there is too much load on the supply, Back to post 1 where the two mosfets were replaced, It could be that they are being turned on hard and killing the supply. There are also a pair of dual diodes, DL851 & DL852, I would check them as well
This is a guess but it might be caused by open led's in the panel and the board is shutting down due to an over voltage on the led supply.Last edited by R_J; 02-03-2022, 04:05 PM.Comment
What voltage do you get on JP840 when the backlight circuit is enabled (BLU_ON/OFF ground removed) Does it jump up to 300vdc? or is it higher? If it jumps up higher, connect the backlights and check the voltage again.Comment
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by CookybabyHello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
Make: Samsung
Model: UN60ES6500FXZA
Power Supply P/N: BN44-00525A
Symptoms: The TV was... -
by Drewwol11Hi all,
My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the...08-31-2021, 09:32 AM -
by lp20thI have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
by mrtekHi
Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
Main fuse = OK
Back light LED = OK. Power them with aux power source
LED output = OK 156V
I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...07-20-2025, 08:06 PM - Loading...
