Sony KDL-40BX450 LCD. Thermistor gets too hot 10 seconds after turning on the TV
  • Diah
    • Feb 2013
    • 6540
    Re: Sony KDL-40BX450 LCD. Thermistor gets too hot 10 seconds after turning on the TV
    Originally posted by Quantum IC
    When I press the power button for the first time after plugging in the TV, the voltages are present for about 1-2 seconds and then drop to 0V, except for the STBY 3.3V and AC OFF DET 3V voltages, which are always present.
    Then when I press the power button again the TV turns on and all the voltages are present.
    common man.. did you read about Sony firmware it can register failure account.. what the eeprom will do if the sectors space are full...it will try to shutdown then delete the last one and turn on again normal.. log in SM and clear this register.
      • 12328
      • U.S.
      That sounds right to me Diah, I do believe you are correct sir.
      • Quantum IC
        • Sep 2021
        • 20
        How can I log in SM and clear the register?
        I don't have the remote and the owner of the TV lost it.
        • gabiz_ro
          • Mar 2011
          • 171
          • Romania
          That called thermistor is an NTC and is wide used in SMPS as inrush current resistor.
          On older designs there was a resistor from bridge rectifier to main capacitor,but since even a little value generate some power loss , they switched to NTC.
          When cold have some low ohm value to limit inrush current when connected to main voltage then heat up,resistance decrease to almost 0,no voltage drop across NTC,no power loss
          • Quantum IC
            • Sep 2021
            • 20
            I replaced the thermistor with a 2.2Ω 7W ceramic resistor because I couldn't find a similar thermistor and just as a test to rule out if the thermistor was faulty.
            This resistor also gets very hot in about 1 minute.
            I can't figure out why, if when I take the amp reading through the thermistor or through the resistor, I don't get a high draw.
            • R_J
              • 9622
              That's because a RESISTOR is not a NThermistor. the resistor never changes to 0Ω it is always 2.2Ω and the voltage drop will case heat. Remove the resistor and replace it with a NTC THERMISTOR
              • dskall
                • Oct 2016
                • 2905
                • usa
                #27
                A thermistor will get hot. Look up temp. specs. on it. It will burn your fingers.
                • dkneyle
                  • Dec 2013
                  • 445
                  I think you're wrong. Of course, 250W is too much, it's even above the consumption marked on the label of this television.
                  But I got 600~700mA (0.6~0.7A) and if I'm not mistaken that means around 66~77W.
                  Mi line voltage is 110V.
                  The label on this TV says a power consumption of 158 W.
                  It's an LCD TV. Its backlight is by CCFL lamps.
                  Apologies - you are right about 110VAC - I calculated wrong.
                  • dkneyle
                    • Dec 2013
                    • 445
                    CCFL TV will have an inverter circuit. I'd still be looking closely there for a problem.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #30
                      Training manual link
                      https://www.manualslib.com/products/...50-491425.html
                        • 12328
                        • U.S.
                        #31
                        • nmbb
                          Can not find Model/Value of Thermistor.
                          by nmbb
                          Machine: Autoclave.
                          Brand/Model: SANYO MLS-3780
                          Manual: (Sorry search option not working on this PDF)
                          Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                          06-02-2022, 05:55 PM
                        • zklgfs
                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                          by zklgfs
                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                          08-11-2025, 02:14 PM
                        • twonk9098
                          Lenovo Legion 5 high fan spin turns off after 34 seconds
                          by twonk9098
                          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                          I have tried a few new bios but exactly...
                          07-14-2024, 11:19 AM
                        • liquidzorch
                          Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                          by liquidzorch
                          Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                          10-18-2024, 05:19 PM
                        • Rick_1234
                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                          by Rick_1234
                          Good evening, gentlemen.
                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                          Things I tried
                          - Bought a new AC adapter thinking that was the problem but the problem...
                          06-22-2024, 04:44 PM
