Samsung un58tu7000fxza - Power cycles with no picture, only backlight
  • cheebster
    • May 2008
    • 374
    #41
    Re: Samsung un58tu7000fxza - Power cycles with no picture, only backlight
    Hello, just picked this same tv with the exact same behavior.
    I wonder, how do we actually find out whats wrong on the panel or panel pcb/cof, is there anything we can do to find out instead of randomly using tape?
    I tried checking various things with the meter, but no dice, missing some skills it seems.
      • 12276
      • U.S.
      #42
      you can test the capacitors on panel driver board, pretty simple:
      so you check for very low ohms, go ahead check in circuit, meter set to ohm scale put a probe on both ends of capacitor would expect well over 100 ohms, can check for shorts, meter set to diode/continuity mode, put a probe on both ends if you get 000 or close to it it is shorted, can also check by putting neg. probe on ground, pos. probe on either end of cap, one side will give a reading other side will read 000, if both sides read 000 or close to it it's shorted. THIS TESTING DONE WITH TV UNPLUGGED FROM POWER.
      • cheebster
        • May 2008
        • 374
        #43
        Hi there! Yes i already checked all caps for obvious shorts. What's next?
          • 12276
          • U.S.
          #44
          what were the results of test in post #32, does tv stay on, anything on display?
          • cheebster
            • May 2008
            • 374
            #45
            Yep, tv stays on. Also, taping a bit of the connector between the 2 pcb's on the panel going to the right side of it makes the tv work, but no display. Sounds works, and tv stays on
              • 12276
              • U.S.
              #46
              you have backlight? or the backlight comes on and stays on with cable from powerboard to mainboard unhooked?
              • cheebster
                • May 2008
                • 374
                #47
                Yep
                  • 12276
                  • U.S.
                  #48
                  so you have backlight with everything hooked up, just no picture?
                  • cheebster
                    • May 2008
                    • 374
                    #49
                    No, i have backlight and sound with the lvds disconnected from the panel, or with tape on the U connector going to the right side of the pcb at the bottom of the screen, taping a few pins.
                    How do we find out whats wrong on a panel, ive seen videos where they disconnect power going to the panel itself by cutting a trace or
                    removing a resistor, then injecting 3.3 or 1.8v on the proper line, then checking for heat on the PCB of the screen, finding then the bad component
                      • 12276
                      • U.S.
                      #50
                      its advanced, some can not be repaired, many of those guys on youtube really know their stuff, you need to do the voltage testing to see whats missing, then follow their directions, weather it be trace cutting or wired coff bypass whatever the case may be, the one guy even used 100 x magnification for some of the repairs but most don't need that much, many videos there on testing and expected voltages, it will be a challenge but very rewarding if you are successful, it's not brain surgery but seems very close.
                      • cheebster
                        • May 2008
                        • 374
                        #51
                        Yeah. Well ive already used similar techniques on iphones and ipad board to find shorts, injecting voltage and finding the heating source or heating component. I'd like to do the same on this panel. Can the COF chips be replaced, or it's impossible ?
                          • 12276
                          • U.S.
                          #52
                          Some on youtube claim success, others claim you need the bonding machine, I haven't tried such a task, looks very tedious, since my 20/20 vision is gone now, the stuff that takes keen eyesight I have to stay away from, I get a headache before I get 10 minutes into it.
                          • cheebster
                            • May 2008
                            • 374
                            #53
                            Well well, it seems a bit tricky to replace a such chip, definately a no-go. But are the chips really at fault ?
                            I noticed, on this one here these seems to be 5 test points, which i scratched (novatek nt30222h)
                              • 12276
                              • U.S.
                              #54
                              https://www.youtube.com/watch?v=8A1TPmJ4Eko
                                • 12276
                                • U.S.
                                #55
                                I usually just take it apart as much as needed to get to the boards then have a real close look at the cofs, most of the time I have had a bad cof it was visibly burnt or dark and mishaped, compared to the others, could be hotter or colder than the rest too.
                                • cheebster
                                  • May 2008
                                  • 374
                                  #56
                                  Yeah, i tought about this, check for burnt areas or heat, but since the panel doesn't stay on, my thermal camera doesn't show anything on the cofs.
                                  Here are additional pictures on this model, there are these test points, but idk how to use them
                                  • cheebster
                                    • May 2008
                                    • 374
                                    #57
                                    i see there testout-cof1,2,3 and lc1 lc2 vgh vss, ck1-8, clr, stv.. anyone has a clue how to check stuff on there ?
                                      • 12276
                                      • U.S.
                                      #58
                                      https://www.youtube.com/watch?v=DiW6nNk1TYA
                                      • pdsterns
                                        • Oct 2022
                                        • 28
                                        Update: After blocking many traces I was not able to make any differences with the screen. I did have the instruction voice speak some different phrases about setup but there was nothing I could do. I carefully looked over the tcon strips but could not see anything wrong with them, I flexed them and tapped them but nothing changed. I think I am snookered here. Does anyone out there know of anyone who tries to repair these tcon strips? I just hate to toss this 2 year old TV
                                        • cheebster
                                          • May 2008
                                          • 374
                                          #60
                                          We're at the same point it seems. Whenever i block traces, i get a black screen. It's like we are blocking lines that are needed. I'd really like to fix this one, not for the tv itself, but just for the heck of understanding what's happening.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • ohren
                                            by ohren
                                            09-08-2023, 05:24 PM
                                          • C152Heavy
                                            by C152Heavy
                                            Summary for TL-DR readers:
                                            • VCC pin (18) of PFC...
                                            01-11-2023, 02:53 PM
                                            09-07-2024, 05:50 AM
