Samsung UN55EH6050F power supply short
  • ggil44
    • Aug 2011
    • 105
    Hello, I have a Samsung UN55EH6050F TV that suddenly quit and upon inspection, I found the fuse in the power supply was blown. I removed the board and I replace the fuse and plugged in the power supply board by itself and immediately, the fuse blew again. The power supply board is BN44-00499A / PD55AVI_CHS. I used a capacitor checker and found all but the 450v 100uf capacitor to check out good. I removed the 450v cap and rechecked it, and it checked good out of the board, so I re-soldered it back into the board. I then checked the diodes, which seemed to check good. I carefully inspected the board, but I can't isolate the problem and there are no burn't components or bulging caps or any visual indication to guide me to the faulty component. Any help you can offer would be greatly appreciated. I would include a picture, but it looks no different from the stock BN-00499A / PD55AVI_CHS power supply board.
    Thank you in advance for your help,
  • lotas
    • Jan 2016
    • 4877
    • Russia
    Re: Samsung UN55EH6050F power supply short
    It looks like your fault.
    https://www.badcaps.net/forum/showthread.php?t=82862
    • ggil44
      • Aug 2011
      • 105
      Your right, it IS my fault. I bought the TV.
      Thanks for the reference link.
      • R_J
        • Jun 2012
        • 9624
        Check if VX801S is shorted.
        • ggil44
          • Aug 2011
          • 105
          Hello R J, I checked VX801S both in and out of circuit and got a 900 meg ohm reading so I don't think that is the culprit or as "lotas" would say, fault.
          Thanks for the suggestion though.
          Regards,
          • ggil44
            • Aug 2011
            • 105
            From the link I got from Lotas, I checked QL801 and QL802, after uncovering them from the white silicone covering their identifiers and found them to be shorted just like in the link he gave me. Now I am waiting for the replacement mosfets to replace the bad ones.
            Thanks again Lotas!
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4541
              • Italy - Milan
              You bought the tv?? It is different model! VX is a varistor i think, it must sign OL..
              QL801/2 what signs?
              • ggil44
                • Aug 2011
                • 105
                Hello Davi P. I'm not sure that I follow your post. The TV is a Different model, but the power supplies appear to be the same and have the same board numbers as the UN50EH5300F, which is BN44-00499A.
                Regards,
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4541
                  • Italy - Milan
                  "Your right, it IS my fault. I bought the TV. " ... what do you mean?
                  • ggil44
                    • Aug 2011
                    • 105
                    Hello Davi.P, OK, I was just bantering with lotas because in my original post I had said "...guide me to the faulty component. Lotas picked up on that and said "It looks like your fault." He is right since it is my TV and there are "faulty" components, it is my (problem), "fault" that I need to fix. I was just joking around with lotas. Hope that clears it up.
                    Regards,
                    • ggil44
                      • Aug 2011
                      • 105
                      OK, I finally got the 2 mosfets (QL801 and QL802) and checked them a soldered them into the board, held my breath and plugged in the board. It immediately blew the fuse again so evidently the mosfets were the casualty not the cause. I ended up taking the same route as neilc6 and getting another power board and the TV works fine but I would still like to know what is causing the short in the old power board. Any other suggestions?
                      Thanks,
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4541
                        • Italy - Milan
                        VX801 is the varistor, it must mark open, not 900Mohm, remove it and test the board again
                        • ggil44
                          • Aug 2011
                          • 105
                          Hello Davi.p, I did remove the varistor and tested it out of circuit. I found it to test open as you suggested.
                          Regards,
                          • R_J
                            • Jun 2012
                            • 9624
                            Thanks,
                            If the mosfets were shorted, it is very likely the gate drive diodes or resistors are defective or maybe even the gate drive transformer may be open.
                            When the mosfet shorts drain to gate, it will supply the full 165v to the gate and destroying the gate drive circuit
                            • ggil44
                              • Aug 2011
                              • 105
                              Thanks R_J. The mosfets were indeed shorted so I will check the "gate drive diodes & resistors" and also the transformer. I appreciate the help.
                              Regards,
                              • ggil44
                                • Aug 2011
                                • 105
                                With all the festivities surrounding Christmas, I have decided not to search for the failed components on the power board. I did get a working board and the TV is working fine.
                                Thank you all for your good suggestions and help. Wishing you all a happy Christmas season.
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                  After all of...
                                  07-13-2024, 08:14 PM
                                • Nicktronic
                                  Samsung Power Supply Board BN44-00874F
                                  by Nicktronic
                                  Hey everyone,
                                  This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                  Anybody...
                                  03-17-2025, 06:20 AM
                                • repair-it
                                  Need advice testing a samsung power supply board with scope
                                  by repair-it
                                  I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                  07-12-2025, 11:00 AM
                                  Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                  I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                  The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                  Found shorted diodes on main controller relays there are 3 of them that...
                                  01-07-2023, 05:43 PM
