LG 32LH20R No backlights
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    The CCFLs are not lighting up at any moment, when the fault occoured the lamps shut down and only sound still played, there's image on the screen, with a flashlight I tried turning energy saving off, no change, PWM_DIM signal is 0.2V, I isolated the pin and soldered a 3.3V regulator at it but it still does not work.
    All the main voltages 24V/5V/12V are ok, the mainboard is not sending enough PWM_DIM signal voltage.
    1~5 - 24V - 25.01V
    6~10 - GND
    11 - BRI - 1.54V
    12 - INV_ON/OFF - 5V
    13 - PWM_DIM - 3.3V (with an AZ1084 3.3V regulator)
    14 - ERROR - 0.04V
    The only signal left to manipulate would be BRI, but I do not know what voltage it's supposed to be.
    Disconnecting the ERROR pin does nothing.
    That floating IC next to the inverter cable is the 3.3V reg, currently disabled(no Vin).
  • Robinsosa
    • Nov 2013
    • 19
    • kenya
    Re: LG 32LH20R No backlights
    I had a similar problem. After confirming the CCFLs are good and inverter board is working. I changed the T-con board and TV displayed a picture.
    Check the training manual.
    • Biruslapio
      • Nov 2013
      • 552
      • Brasil
      Nothing suspicious with the t-con, no shorts, fuse is fine, since there is image and sound, I've managed to turn off energy saving and put backlights at 100, this way the PWM_DIM went to 2.6V. still no backlights.
      Disconnecting the t-con or just the panel changes nothing either, the "BR1" signal is ok according to this training manual for a similar model.
      Powering the PSU via resistor jumper only sends 24V to the inverter, 0V on pins 11~14, no backlights.
      • Robinsosa
        • Nov 2013
        • 19
        • kenya
        From your readings pin 12 INV on/off(P203) is 0v, hence the back light is OFF.
        it should be HIGH to switch the inverter circuit. The signal to turn inverter ON comes from the main board. When you were performing the test, the main board is not active since no power is being supplied.
        Try to do this:
        Disconnect power cable from power supply board to the main board since we want to check power supply and inverter circuit only.
        On connector P201 (on power supply board), Connect jumper 10k from pin 11 to pin 19 (PWR) AND pin 20 (INV ON/OFF). This will turn the power supply ON and also the inverter circuit ON.
        See attached picture.
        • Biruslapio
          • Nov 2013
          • 552
          • Brasil
          Yes the PSU does not produce any signals to the inverter, all the traces are straight from the main board to inverter and the PSU just acts as a bridge.
          With an 1k resistor INV ON/OFF gets 5V, still nothing happens.
          I have already inspected the board and tested the fuse, the four switching mosfets and transformer windings, they are fine.
          There's a 56 OHM resistance between the lamps output and ground, is that normal? Never messed with an inverter board before.
          • Robinsosa
            • Nov 2013
            • 19
            • kenya
            Check voltages on P203 on the inverter board per manual.
            Pin 1-4 = 24v
            Pin 12 inv on/off= High
            pin 15 error= 0v
            If there are correct then check connections from inverter board to CCFL and for dry joints. If you have CCFL tester you can check the lamps. If the lamps are faulty or the electrodes have blackened, they won't turn on and inverter will shut down.
            Does the ballast start Det LED turns on?
            If not, then inverter board is probably faulty.
            Check the continuity of the transformers, normally they go open on the legs of the transformer or develop dry joints. Also check the connectors for the CCFL they tend to burn or develop dry joints
            • Biruslapio
              • Nov 2013
              • 552
              • Brasil
              The pinout in that training manual is different from my TV, but the error pin is at 0V during PSU+Inverter only test, with the mainboard it is at 0.03V, basically zero.
              I did the dreaded thing and opened up the TV to check on the lamps, they are fine and no sign of bad soldering, it looks perfect, unfortunately the only other 32" LCD TV I have uses "U" shaped lamps, so no way I can test them.
              The inverter transformer does not output anything, it has one pulse at the startup and nothing else, like the controller detects an short or something, there's that low resistance to ground on the lamps output pins, is it part of the design of the board?
              • Biruslapio
                • Nov 2013
                • 552
                • Brasil
                Anyone has any idea? I'm stumped, the most out of order thing would be the PSU 24V rail measuring 25V, but that seems insignificant.
                • R_J
                  • 9588
                  Does the led on the inverter board light when the tv is first turned on?
                  • Biruslapio
                    • Nov 2013
                    • 552
                    • Brasil
                    Wow thanks, I can't believe I forgot about the LED, I've seen it and kept ignoring for some reason, it does not light up at all, there's 1.65V forward voltage on it.
                    Does the inverter means that no LED = Bad? Since it has all the necessary voltages to operate.
                    • Biruslapio
                      • Nov 2013
                      • 552
                      • Brasil
                      Reading that training manual with more attention this time, the board in it is very similar, just different layout and main IC, it points that the led should start as the Inverter (or Ballast) is on the boot up process, and when the backlights were supposed to work, it would turn off, the one on this TV never emits light, so I will order a replacement board.
                      • Robinsosa
                        • Nov 2013
                        • 19
                        • kenya
                        If you check post #6 I asked you “Does the ballast start Det LED turns on?
                        If not, then inverter board is probably faulty” The training manual shows clearly where the LED is situated.
                        Anyway good luck.
                        • Biruslapio
                          • Nov 2013
                          • 552
                          • Brasil
                          Fixed, just replaced the inverter board, it was very cheap and effective.
                          When the TV powers on the LED lights up bright blue, unmistakable if you know it should be lit during startup.
                          • Robinsosa
                            • Nov 2013
                            • 19
                            • kenya
                            Nice of you to give us feedback of your success
                            • TVAddict
                              • Jan 2022
                              • 76
                              • Caribbean
                              Hi everyone, apologies for reviving this old thread but i have the same exact issue with the same model LG tv, i would appreciate any guidance.
                              Basically i've tried the procedure outlined in post #4 but i can't seem to grasp the results which shows 0 volts on pwm-dim , 0 volts on error and about 1.5 volts on inv on/off the other voltages are present (24v, 12v) the 5v which is where i soldered one end of the 10k resistor to drops off to 1.5 - note p201 pin configuration on my board seems slightly different to the connector shown in post#4
                              As was the case with the member Biruslapio i too have not seen that led on the ballast board light up at all.
                              Do you guys think i've done the procedure correctly??
                                • 12276
                                • U.S.
                                Looks like same issue, Vis-à-vis acording to advice and post #11 quote from manual, it probably needs a replacement inverter. Led of inverter never lights up. I think another clue is the inverter on/off voltage seems too low.
                                • TVAddict
                                  • Jan 2022
                                  • 76
                                  • Caribbean
                                  Inverter on/off stays at 4.9v with everything hooked up, just no backlights or the ballast led. should i take a risk and replace the ballast board, if i can find one??
                                  • lotas
                                    • Jan 2016
                                    • 4753
                                    • Russia
                                    There are also PWR_DIM and BRI (brightness) commands.
                                      • 12276
                                      • U.S.
                                      I think I would, there should be a fuse on the inverter that you can test for continuity. Had a bad one a few times.
                                        • 12276
                                        • U.S.
                                        If you do you'll want to be careful, good policy is never work on inverter with tv plugged in. these ccfl backlit tv inverters can put out over 1000 volts and can kill instantly. Leave it unplugged a few days before replacing.
                                        • disorder
                                          HP 2311 display, 3.3v regulator fried, need help to replace
                                          by disorder
                                          hello,
                                          i have a hp display 2311 to repair, totaly dead
                                          on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                                          i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                                          thank you
                                          07-27-2025, 04:34 AM
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                        • bpcannan
                                          VIZIO M557-G0: Backlights or ???
                                          by bpcannan
                                          'Morning,
                                          I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                          Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                          I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                          I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                          10-29-2023, 06:36 AM
                                        • bilux
                                          uP0109: 2A Ultra Low Dropout Linear Regulator equivalent substitute
                                          by bilux
                                          I want to find a replacement for uP0109 8pins, and i found this parts:
                                          uP0109 is "2A Ultra Low Dropout Linear Regulator"
                                          RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
                                          FP6137C is "2A BUS TERMINATION REGULATOR"
                                          can replace uP0109​ by RT9199 or FP6137C ?
                                          11-01-2024, 12:00 PM
                                        • jesterace
                                          Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                                          by jesterace
                                          Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                                          However, I am in a dilemma.
                                          I tested the backlight outputs with the lights disconnected...
                                          10-20-2024, 10:15 AM
