Un50mu6070 Mainboard issue
  • Storyteller12
    • Jun 2020
    • 625
    Re: Un50mu6070 Mainboard issue
    I bought a new programmer and didn’t do the mod.
    Model listed by Lotas.
    Rt809f
    • crym1111
      • Feb 2022
      • 20
      #62
      Hi lotas,
      I have a motherboard from Samsung UE49MU6202, code BN94-12424C and don't have stand-by led active, attached 25Q40 that probably need to be fixed.
      Can you help me?
      • crym1111
        • Feb 2022
        • 20
        #63
        Forget to tell you, i have RT809H programmer...
        • lotas
          • Jan 2016
          • 4744
          • Russia
          #64
          Originally posted by crym1111
          Hi lotas,
          Can you help me?
          Ok, I'll try, you are familiar with the status of the register, what needs to be set, without it the firmware will fly off again when you turn it on for the first time.
          • crym1111
            • Feb 2022
            • 20
            #65
            I see that you write in the post:
            In the program:
            1. Click "Detect Chip" and select W25Q40CL and "Select IC".
            2. Click "Unprotect".
            3. Click "Erase IC" and "Yes".
            4. Click "Open File" and select your corrected Dump.
            5. Press "Program IC" and "Yes".
            6. Click "Verify IC".
            7. Press the down arrow to the right of "Unprotect" and select "Edition SREG", put a check mark on S7, S3, S14, S9 and press "Write" and "Yes"
            7. Close the program. Ready.
            • crym1111
              • Feb 2022
              • 20
              #66
              On RT809H interface must be set anything in tab Protect when you read W25Q40 ?
              Because i see your info when you have to click to programming IC's...
              • lotas
                • Jan 2016
                • 4744
                • Russia
                #67
                https://www.badcaps.net/forum/showpo...1&postcount=17
                Try
                • crym1111
                  • Feb 2022
                  • 20
                  #68
                  Hi Lotas,
                  I deactivate protection and erase two ic's, tested as blank.
                  Write each of versions that you fixed for me and protect both ic's...no one was working...
                  Any ideea?
                  • lotas
                    • Jan 2016
                    • 4744
                    • Russia
                    #69
                    Write down any dump (you need to look with which one it will start, it can start with any) after recording, set S.R. 0x88, 0x42 and hit "write".
                    And it is not clear why you are erasing two microcircuits, what else have you erased? There is one chip 25Q40.
                    • crym1111
                      • Feb 2022
                      • 20
                      #70
                      I erase two ic's and write each of them with those two versions received, set SR as you recommend you, tested one by one but no stand-by led active...
                      • lotas
                        • Jan 2016
                        • 4744
                        • Russia
                        #71
                        In the program:
                        I wrote this instruction for CH341A (AsProgrammer and NeoProgrammer)
                        • lotas
                          • Jan 2016
                          • 4744
                          • Russia
                          #72
                          Now you can read the Dump after installing it on the board, and post it here again, I'll take a look at the contents.
                          • lotas
                            • Jan 2016
                            • 4744
                            • Russia
                            #73
                            Do you have two new 25Q40 chips or one native second from a donor?
                            • crym1111
                              • Feb 2022
                              • 20
                              #74
                              One of ic's that i tested, attach read file.
                              • crym1111
                                • Feb 2022
                                • 20
                                #75
                                i don't have new pieces but i can erase and are checked as blank.
                                • lotas
                                  • Jan 2016
                                  • 4744
                                  • Russia
                                  #76
                                  Try
                                  • crym1111
                                    • Feb 2022
                                    • 20
                                    #77
                                    kind regards, i will tested soon.
                                    • crym1111
                                      • Feb 2022
                                      • 20
                                      #78
                                      again, no...
                                      • crym1111
                                        • Feb 2022
                                        • 20
                                        #79
                                        i'm so sorry about all your effort
                                        • Diah
                                          • Feb 2013
                                          • 6435
                                          lotas modifying are correct , the problem with active STBY LED indicator are HW issue not SW.
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • Stephen
                                            A2991 Logic Board issue, 20volts 0 amps help!
                                            by Stephen
                                            Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                                            09-10-2025, 03:16 PM
                                          • Stephen
                                            A2991 logic board issue, 20volts 0 amps help!
                                            by Stephen
                                            09-10-2025, 03:15 PM
                                          • notallbad
                                            TCL 55RP620K power board issue
                                            by notallbad
                                            Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                                            0% p_dim at 1.65v and a_dim at 1v
                                            50% p_dim at 3.3v and a_dim at 1.65v
                                            100% p_dim at 3.3v and a_dim at 2.88v
                                            Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                                            Leds are 2 rows of 15 6v leds.
                                            On inspection of the power board found diode MBR3200 shorted so replaced with...
                                            07-12-2025, 05:45 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
