Un50mu6070 Mainboard issue
  • petersor
    • Feb 2020
    • 43
    Got it. Thanks for the clarification. I'll give that a try today.
    Rich
    • petersor
      • Feb 2020
      • 43
      No shorts on the data lines. With the jumper in place, the behavior of the TV is the same with both LVDS connected, left connected only, right connected only and both disconnected . . . 1-2 second flash of the standby light with about 15 ~ 18 seconds between flashes. Same as before.
      Rich
      • lotas
        • Jan 2016
        • 4711
        • Russia
        #123
        Disconnect the wi-fi module, also check these contacts for resistance to ground (LAN).
        • petersor
          • Feb 2020
          • 43
          No change with WiFi disconnected - The jumper is still installed on the LVDS - should I remove that?
          The LAN IC (0524P) doesn't have any shorts (except the center pin 3 which is the ground pin . . .
          • petersor
            • Feb 2020
            • 43
            I hooked a 13V power supply up to the main board and measured voltages on the coils - some are steady and some drop to 0 as the board power cycles. . . . The board was not connected to the TV when I took the measurements. Not sure if this is helpful
            Click image for larger version  Name:	Coil Voltages.jpg Views:	0 Size:	3.12 MB ID:	3570111
            • petersor
              • Feb 2020
              • 43
              One other possible clue - The audio amplifier IC (TAS5749M) has a warm, not hot, spot in one corner . . . .that comes and goes as the board powers up and down.
              • petersor
                • Feb 2020
                • 43
                lotas - Anything else I can try on this board or is it unrepairable?
                • lotas
                  • Jan 2016
                  • 4711
                  • Russia
                  #128
                  Check with this table (voltage / resistance), the problem may be in the eeprom 24C512 firmware or in the eMMC, maybe in the processor itself, I'll dump dump 25c512 for diagnostics...
                  Only your dump (24C512) must be saved.
                  • petersor
                    • Feb 2020
                    • 43
                    Thanks. I'll take a look tomorrow.
                    • petersor
                      • Feb 2020
                      • 43
                      here are the voltage and resistance reading I measured:
Name:	Voltage & Resistance Results.jpg
                      • lotas
                        • Jan 2016
                        • 4711
                        • Russia
                        #131
                        The measurements were made without a jumper (no t-con output voltages)?
                        • petersor
                          • Feb 2020
                          • 43
                          Correct - no jumper.
                          • lotas
                            • Jan 2016
                            • 4711
                            • Russia
                            #133
                            It is necessary with a jumper to see the remaining voltages.​
                            • petersor
                              • Feb 2020
                              • 43
                              OK. I'll add the jumper back and test again. Thanks for your patience.
                              • petersor
                                • Feb 2020
                                • 43
                                Voltages and resistances are the same with the jumper in place.
                                • Diah
                                  • Feb 2013
                                  • 6427
                                  from yours measurement and test with Jumper and with out, it tell you have cut off of the I2C from the SoC. its 99% BGA. need to refllow
                                  • lotas
                                    • Jan 2016
                                    • 4711
                                    • Russia
                                    #137
                                    What panel do you have, number CY-xxxxxx?
                                    • lotas
                                      • Jan 2016
                                      • 4711
                                      • Russia
                                      #138
                                      This chassis also had problems with the crystal falling off the substrate, remove the radiator and blow on the crystal with a soldering station for 30 seconds at a temperature of 200-250C.
                                      • petersor
                                        • Feb 2020
                                        • 43
                                        I'll check the panel number when I get back to the house tomorrow. I'll try reflowing the crystals first and if that doesn't help, I'll try the main processor . . .
                                        • petersor
                                          • Feb 2020
                                          • 43
                                          Panel number is CY-GK050HGAV5H
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • Stephen
                                            A2991 Logic Board issue, 20volts 0 amps help!
                                            by Stephen
                                            Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                                            09-10-2025, 03:16 PM
                                          • Stephen
                                            A2991 logic board issue, 20volts 0 amps help!
                                            by Stephen
                                            09-10-2025, 03:15 PM
                                          • notallbad
                                            TCL 55RP620K power board issue
                                            by notallbad
                                            Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                                            0% p_dim at 1.65v and a_dim at 1v
                                            50% p_dim at 3.3v and a_dim at 1.65v
                                            100% p_dim at 3.3v and a_dim at 2.88v
                                            Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                                            Leds are 2 rows of 15 6v leds.
                                            On inspection of the power board found diode MBR3200 shorted so replaced with...
                                            07-12-2025, 05:45 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
