problems with LG OLED 55EC930V, t-con board LC550LUD-LGP1
  • randaz81
    • Oct 2021
    • 9
    • Italy
    I have an LG OLED 55EC930V.
    The problem started a couple of days ago: tv working, but no video, only audio.
    I opened the tv and I checked the parts. The mainboard has the red led on, which means that it working correctly. The power board supplies 24V correctly.
    I focused my attention on the t-con board, LC550LUD-LGP1, I disconnected it to observe it carefully, no signs of damage. Then I mounted it again and I reconnected to the tv.
    After this, the tv started to show a different behavior: it turns on and then, after few seconds, it turns off. I cnanot hear the audio anymore.
    This happens in all the following different cases:
    1- t-con board is connected to the motherboard and the power supply, but all the four ribbon cables to the panel are not connected.
    2- t-con board is disconnected from the 24V power supply
    3- t-con board is disconnected from the 24V power supply and the main board.
    So my question are:
    A- do you think that this behavior is normal? i.e. on a working tv if I disconnect the oled panel from the t-con board, does the tv stays on, or it turns off automatically? Does the t-con board have a system to detect if the planel is connected?
    B- Can I safely assume that the only broken part is the t-con board? I'd be happy to replace it, but only if I am pretty sure that is the only broken part.
    Thank you for the help.
    Btw, can you recommend to me where I can find the replacement, besides eBay?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4462
    • Italy - Milan
    Re: problems with LG OLED 55EC930V, t-con board LC550LUD-LGP1
    Make one or two very sharp photos of the tcon possibly at sun light with readable serigraphs.
    • TeslaMichael
      • Oct 2020
      • 102
      The LVDS cable will check for panel. if you disconnect it, TV should turn on, but only with sound.
      • William1967
        • Nov 2017
        • 215
        • Netherlands
        With OLED TVs you can throw overboard all the tricks you use with an LED TV. The t-con has a protect circuit onboard that comes in quickly so that there is no image. Disconnecting cables between the panel and the t-con will always result in a shut down of the tv. The same goes for disconnecting the power to the t-con.
        There is a way to check whether the display or the t-con is the cause and that is to start the device in p-only mode, for this you need a service remote.
        If the t-con needs to be replaced remember that the t-con is programmed on that panel, the MURA clouding settings are in the t-con and need to be transferred to the replacement t-con. LG has a service tool for that. First the data must be loaded from the old t-con and than loaded into the new t-con.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4462
          • Italy - Milan
          is it available that LG tool?
          I've seen a detailed LG tcon photo, the power circuitry is almost the same as LCD tcon, same tensions, plus a bunch of new control signals..
          • William1967
            • Nov 2017
            • 215
            • Netherlands
            The tool is available (RAD33387801) but it's not cheap. The t-con from a Oled looks very similar like the "normal" t-con but it works a bit different.
            • randaz81
              • Oct 2021
              • 9
              • Italy
              @William1967
              I'm waiting to receive a service remote. Then, after starting the tv in p-only mode, how can I distinguish if the problem comes from the panel or from the t-con?
              Do you have any idea why before I was able to listen to the audio from the tv (with no video), while now I cannot anymore turn on the tv at all?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4462
                • Italy - Milan
                have you ruined the flat cables? Why don't you publish photos? are you able to repair at component level? Are there too the 24v? If you don't put pictures i cannot say you the points to measure, it is possible that supply converters that feeds the fpga doesn't work and without serial comm the software goes in protection..
                • randaz81
                  • Oct 2021
                  • 9
                  • Italy
                  Hopefully no, I tried to be very gentle with them... (Btw, this is just my curiosity: there are four flat cables from the t-con to the panel. Does it mean that the panel is divided into four independent sections?")
                  I attached some pics of the power supply board and the t-con board
                  I have good soldering skills, but I have no clue about what to replace... By visual inspection, I was not able to see anything damaged.
                  The only thing that I'm wondering about is one of the two large vertical heatsinks in the exact center of the power supply board. The one on the right is ~50degrees, while the one on the left is at room temperature (observed with a borrowed thermal camera). Anyway, the 24v lamp seems to turn on correctly, so I don't think I have a power supply issue...
                  Yes, there are. I found here in the forum a link describing a test with a small car lamp. I did it, attaching the lamp to the power supply and putting a jumper on the 24v enable pin, and I can confirm that the car lamp turns on.
                  About the voltages for the logic... I have no idea about which voltages should I check. Do you have any info on that?
                  Thank you a lot!!
                  • randaz81
                    • Oct 2021
                    • 9
                    • Italy
                    Just a silly question, since I have never seen this type of flat cables. Can you confirm that the closed position is correct? I just placed the cable in position and closed the slot, without trying to force the cable inside any further.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4462
                      • Italy - Milan
                      i have asked only tcon photo with READABLE serigraps... only component side.
                      • randaz81
                        • Oct 2021
                        • 9
                        • Italy
                        ok, sorry... I'm having bad times trying to make a clear single photo of the whole board with my phone.
                        So I did several pics, from left to right. Please tell me if it is ok... I can eventually try to use photoshop to assemble all the pics together but I'm not very familiar with it and it will take a while...
                        Thank you a lot
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4462
                          • Italy - Milan
                          Next time= horizontal board> Horizontal cellular...
                          test in volt these points respect to GND: 2.5v, 1.15v, 1.8v burk, Vpred, L8, VDD, C1528, C1554, F3 (both terminals), C1516, VGH, D44...
                          The questions:
                          1) I think No.. from what i see, each half of tcon: 1 conn. for video data , sync, etc... 1 conn. for power supply, gamma lines or clock lines, i don't see..
                          2) the flat cables and connectors seem right in place..
                          • randaz81
                            • Oct 2021
                            • 9
                            • Italy
                            Hi! Here the results:
                            1.15v, ok
                            2.5v, missing!!!!!!!!!! (0v)
                            L8, 3.2V
                            Vpred, 6.56V
                            1.8v ok
                            1.8v burk, ok
                            C1554, 23v
                            C1516, 11.34v
                            VGH 23v
                            C1528, 16v
                            D44, 6.56v
                            VDD, 16v
                            F3 (both terminals), 11.33v
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4462
                              • Italy - Milan
                              Is there a VGL test point? i can't see..
                              Near 2.5v test point (6.jpg) measure C1606, then measure EVSS_Con_out
                              • randaz81
                                • Oct 2021
                                • 9
                                • Italy
                                hi again, last week I was traveling. Here are the measurements:
                                C1606 = on one side I measured GND, the other side seems to be 0v/floating (maybe like the 2.5V test point?)
                                about VGL, I found a test point called VGL_SENSING at 1.9V, and a test point called EN_VGL which seems to be 0V/floating.
                                On EVSS_Con_out I measured GND.
                                Thank you
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4462
                                  • Italy - Milan
                                  about 2,5v the U772 must be a linear voltage regulator for the near emmc supply, but on C1606 i think there must be the input voltage and i don't know why it is not present, i think that 2,5v is built probably by a 3,3v, you have 3,3v on L8 but i don't see the capacitors connected to it, so maybe there a switch transistor between 3,3v and U772, or it comes from another place, try to test in volt C1615 on top of 7.jpg, near L9... For the VGL the points you found are not the right points but probably is L9 or i don't know where it is..
                                  • randaz81
                                    • Oct 2021
                                    • 9
                                    • Italy
                                    I measured C1615, it is 1.509V. The other side of L9 has a similar value, 1.52V.
                                    U772 seems to be powered through R7590, one of its sides is also connected to C1608, where I can measure 5.1V.
                                    The very bad news is that I bought a T-CON board from ebay and this does not work either. I also tried to test the 2.5V and also in this case I cannot measure anything.
                                    Therefore there is a chance that maybe the 2.5V is enabled by something that is somewhere else and it is not working, I don't know :-(
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4462
                                      • Italy - Milan
                                      Don't consider 100% spare parts are good, better to investigate, there are 2 ways, with multimeter check C1606 where it is connected to in the board, or input a 2,5v externally.., before doing this check in ohms the 2,5v to gnd for possible short..
                                      • Hakuu
                                        by Hakuu
                                        Hi There,
                                        More Details
                                        TV Model - LG OLED77G1PUA
                                        07-12-2023, 02:37 PM
                                      • advant
                                        by advant
                                        02-03-2020, 12:25 AM
                                      • m1ch43lzm
                                        by m1ch43lzm
                                        05-12-2025, 08:37 PM
                                      • maxim2511
                                        LG 55EC930V OLED - swich on swich of no screen
                                        by maxim2511
                                        My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                        Then I get an idea to take it apart and clean boards from dust.
                                        In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                        Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                        05-14-2021, 02:21 AM
