JVC TV Model LT-65N675- No picture
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Hi guys,
    This set has no image. The back lights are running but the TCON seems dead.
    The fuse on board is ok, 12V is present. The problem seems as if there are voltages missing but due to weird markings I cannot see VGH clearly. Anyway, I disconnected both ribbons feeding the panel to see if my voltages come up but they don't. Up to know I was looking to purchase a complete used tcon board but they are not available.
    Can anyone who knows these sets guide me so that i can diagnose the fault. I believe it to be the DC to DC buck converter.
    I have a image not to good quality but now that I know that i need to repair it i will remove it and zoom into its design.
    I think JVC might be similar to your RCA products
    Any help would be greatly appreciated.
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Re: JVC TV Model LT-65N675- No picture
    The chip RT6931 below has 5 solder spots marked CPOUT, UH, UL, LH and LL and there is 0V on all 5 when set is running.
    Is the UH actually VGH???
    Check photo
    • angelos
      • Dec 2012
      • 573
      • South Africa
      Any help anybody?
      • angelos
        • Dec 2012
        • 573
        • South Africa
        I measured some voltage points and these are the results
        VONE = 0V
        STV2 = 0V
        VIN_1.2V = 1.23V
        VL = 0V
        UL = 0V
        LL = 0V
        VH = 0V
        The pico fuse has 12V on both sides
        The big chip in the centre reaches 50 degree celsius in 2 minutes.
        All these voltages were taken with both panel ribbons disconnected.
        I measured resistances on all SMD caps and could not find any shorted ones.
        This board is unavailable and on the web i find this board but it is for a Sony TV. I doubt the software will be the same and thus i will not order it.
        I guess this tv is going to the landfill.
        • angelos
          • Dec 2012
          • 573
          • South Africa
          What a dead forum!!!
          • yokoono
            • Apr 2010
            • 502
            "VIN_1.2V = 1.23V"
            VIN is the supply voltage of the t-con and must be 12V. The fuse is blown or the motherboard does not power the t-con. If the safety is burned, you have an excessive consumption on t-con.
            • R_J
              • Jun 2012
              • 9581
              There is a solder spot labeled HVIN3_12V (next to ICB1?) do you have +12 volts there?
              • angelos
                • Dec 2012
                • 573
                • South Africa
                Hi, yes i will check that on saturday and get back to you
                Regards
                • angelos
                  • Dec 2012
                  • 573
                  • South Africa
                  Originally posted by yokoono
                  "VIN_1.2V = 1.23V"
                  Hi there,
                  I don't understand your reasoning. The label says 1.2V and i am getting 1.23V so that is spot on.
                  • yokoono
                    • Apr 2010
                    • 502
                    VIN is the supply voltage and is 12V not 1.2V. Measure at both ends of the fuse (F1) and see if you have 12v.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Originally posted by angelos
                      Hi there,
                      Perhaps inspect that marking with some magnification. It's a via not a.
                      • angelos
                        • Dec 2012
                        • 573
                        • South Africa
                        Ok, I will take a proper photo of it and also test it tomorrow when I am back in office.
                        Thanks so far.
                        • angelos
                          • Dec 2012
                          • 573
                          • South Africa
                          Hi Guys, i did further tracing around the voltages that are missing on the TCON and i noted the following. When mains power is applied to the tv the TCONs ribbon supply voltage from the main board is a steady 12V if the set is on standby or ON. This tells me that something else must switch on the 12V when picture is required. I have made some marking on the photo i sent you to explain properly.
                          ICA1 i assume is either a mosfet or a dc to dc converter, i dont know. What i do know is that when i removed the ICA1 i saw that 4 circuit tracks are common as the 12V input and one is on the output called HVIN_12V. The last pin is a bias pin or enable pin and is driven directly from the RT6931GQW IC.
                          I was monitoring the HVIN_12V pin when applyuing main power and it shot up to about 3.3V and dropped to zero. It never came up again.
                          If i measure ohms from HVIN_12V to ground i get 38.5 k ohms so there is no short there.
                          So here is my conclusion either RT6931GQW is faulty or goes into protection or who knows maybe there is no data from the main being detected by this chip so it does not start up???
                          The TV lies open awaiting your help.
                          Thanks so far.
                          • angelos
                            • Dec 2012
                            • 573
                            • South Africa
                            here is the picture!
                            • yokoono
                              • Apr 2010
                              • 502
                              Problems where it is surrounded by red?
                              • angelos
                                • Dec 2012
                                • 573
                                • South Africa
                                Thanks Yokoono,
                                I saw those coils.. The plastic tops have cracked or perished. Probably from heat. So you agree with me the RT6931 chip might be the problem? So I will order it and hopefully it fixes the issue.
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  The IC next to the damaged coils also looks damaged as does the component above it.
                                  • R_J
                                    • Jun 2012
                                    • 9581
                                    Those coils are not plastic but powdered iron (or similar) The side of the ic looks damaged as well, this is not from heat but from something striking that part of the board.
                                    • angelos
                                      • Dec 2012
                                      • 573
                                      • South Africa
                                      I will replace that chip and see what happens! Will take months for the part to arrive.
                                      • angelos
                                        • Dec 2012
                                        • 573
                                        • South Africa
                                        Or maybe order a complete board via Ebay and hope it works.
                                        Just a question, if the board arrives and I fit it and there is something wrong like the picture is flipped upside down or some other issue. I remember somebody telling me that there is a program loaded into the tcon. If so then would it be fair in saying that i could unsolder the old eprom and solder it into the new one and it could then work?
                                        I think the eprom could be part "ICE11" or is it loaded into the big square chip in the centre?
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • netgearnetgear
                                          TCL 43S423 TCON OR PANEL FAULTY???
                                          by netgearnetgear
                                          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                          08-20-2025, 06:04 PM
                                        • iglitare
                                          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                          by iglitare
                                          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                          Backlight seems to work, Sound (Setup menu after reset) works.
                                          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                          With my small knowledge i would think at least the cables are good.
                                          Can this happen because of a bad tcon board?
                                          Or is it always a bad/shorted...
                                          09-04-2025, 07:13 AM
                                        • Fripacks
                                          No picture LG model 50PT350
                                          by Fripacks
                                          Hi guys,
                                          I have problems no picture with LG model 50PT350, first of all, I change the 2 buffer boards who was no good, the TV working 2 weeks and today same problem, I check and I found Zsus board defect now, I change it for a new one and no picture, I check VS VA and 5 volts , all this voltage are there, I disconnect the upper buffer board, no picture, I disconnect the lower buffer board, no picture, what I have to check now?...
                                          05-19-2023, 12:06 PM
                                          HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:27 AM
