Hitachi 55" TV dead after 18 months (Vestel 17MB100)
  • Ruptor
    • Sep 2021
    • 35
    • GB
    I couldn't find any other thread that matches my TV problem but have been told it is a common fault. The fault is a flashing LED as if it is in upgrade mode that happens after a few seconds and stays forever. I can't remember all the tricks that have been tried like holding the select button when powering on but nothing worked. The shop sent me a flash drive to plug in a USB port but that did nothing either and they said it was dead which is disgusting for a piece of solid state electronics. I took the back off eventually after removing 34 screws to check for blown caps but everything looks new as you would expect for only 18 months use. The board is a Vestel 17MB100 and I think it died when it was doing an upgrade because the TV screen came up then it checked for an upgrade turned off the screen and stayed with the flashing LED for over half an hour.
    I have some questions to start.
    1) Is the flash drive meant to be bootable (mine isn't) or just a bunch of files?
    2) Can a serial lead be plugged in to see a boot up log like some other TVs?
    3) Any ideas on how to fix it or find out what is wrong?
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: Hitachi 55" TV dead after 18 months
    Your tv its probably a vestel. You need to flash the correct firmware for your tv using a usb stick. You just throw a bunch of files into the usb stick, a working remote control and you are good to go. A blinking led light dosent necessarily mean that its a bad firmware, but a firmware update solves the problem 90% of the time.
    • petehall347
      • Jan 2015
      • 4437
      • United Kingdom
      normally first format drive as fat 32 . but that should have been done .
      • Ruptor
        • Sep 2021
        • 35
        • GB
        I have a USB from Hitachi with the appropriate files that reads on a computer. When they first sent me the USB I tried it in both USB ports and held the Button on the back of the TV but it didn't change the LED blinking.
        It is still the same now but with the back of the TV off I can hear a faint hiss from the power supply that seems to tick as if the switching part of the PSU is on is this normal? I would have thought the standby or even flashing LED wouldn't start any of the heavy supply running or is the blinking LED state a turned on PSU state?
        • yokoono
          • Apr 2010
          • 505
          If it is Vestel:
          1. format a stick (preferably 4-8 Gb) with FAT32
          2. unzip and put the files directly on the stick
          3. Unplug the TV
          4. insert the stick in the tv. Preferably usb next to CI card
          5. press and hold the OK key on the remote control
          6. Plug in the TV.
          7. The left LED on the TV will flash slowly at first and, after a few seconds, faster
          8. release the ok key
          9. wait for it to finish. It can take 3-10 minutes
          • Ruptor
            • Sep 2021
            • 35
            • GB
            Re: Hitachi 55" TV dead after 18 months (Vestel 17MB100)
            I tried that with the remote OK instead of the button on the back of the TV but no change. The flash drive sent to me by Hitachi with appropriate files looks like the picture. Any more suggestions?
            • ducky29
              • Dec 2015
              • 369
              • Europe
              Try a smaller capacity usb drive (2.0). Format the usb stick and copy paste 5 files.
              • Ruptor
                • Sep 2021
                • 35
                • GB
                I can try and fudge a smaller capacity SD card in a USB adapter but why would Hitachi send me a USB stick that wouldn't work because it is too big for their TV?
                • yokoono
                  • Apr 2010
                  • 505
                  Hold down the OK key for a longer time. It can take up to 1 minute.
                  • ducky29
                    • Dec 2015
                    • 369
                    • Europe
                    My bad, I thought Hitachi sent you the files and not the usb stick. Try holding ok for a bit longer or keep pressing ok button repeatedly.
                    If it dosen't take firmware then it might be a hardware problem or a problem that can't be solved just with a usb stick.
                    • Ruptor
                      • Sep 2021
                      • 35
                      • GB
                      I held the OK button & the button on the back of the TV for 2.5 minutes but no change. I just found a 2 GB SD card I can use but won't bother given your last post. Pressing the button lots of time made no difference either.
                      What about the faint hissing and ticking coming from the PSU does that point to any thing? In this LED flashing mode should the PSU be fully on?
                      • ducky29
                        • Dec 2015
                        • 369
                        • Europe
                        Probably a mainboard (firmware) related issue that can't be solved using the usb so you might need further help from a technician. You might need to reprogram or replace the emmc, but you never know, its not that easy diagnosing through a forum.So I don't know about faint hissing but I think its constantly trying to start up the mainboard.Your best bet is to get it fixing under warranty but I guess your warranty is voided becouse you already opened the back, but you can give hitachi a call and ask them.
                        Your tv model maybe 55HK6T64U or 55HGW69; so I checked for a mainboard replacement but I might need more info to get you the correct replacement, otherwise get a board and then update the firmware sent from hitachi.
                        • Ruptor
                          • Sep 2021
                          • 35
                          • GB
                          Our TV is 55HK6T64U and had a 1 year warranty that is why they said buy a new one when the USB stick didn't fix it. Can you point me to a circuit diagram of the PSU that I can replace parts on if it is faulty and any information on the Vestel CPU board? I found a manual that appears to cover a lot of boards but it jumps from 95 to 130 with no mention of my 100 board that seems to be an oddball.
                          • lotas
                            • Jan 2016
                            • 4744
                            • Russia
                            Service manual hitachi 55hk6t64u
                            • Ruptor
                              • Sep 2021
                              • 35
                              • GB
                              Thanks a lot I have a chance of finding where the fault is now. I will report my findings and solution if one is available.
                              • ducky29
                                • Dec 2015
                                • 369
                                • Europe
                                It must be a faulty mainboard not a faulty PSU.
                                • Ruptor
                                  • Sep 2021
                                  • 35
                                  • GB
                                  If a board is 17MB100 and it looks the same as mine can I use my Hitachi USB and change it for my TV?
                                  My Main Board 23348885
                                  New Main Board 23306084
                                  • ducky29
                                    • Dec 2015
                                    • 369
                                    • Europe
                                    They look the same but the screen is different. The image might be ok or it might be flipped, solarized.You never gonna know until you try.
                                    Probably even the remote might be different. You might need to flash the firmware from Hitachi again but you need a toshiba remote control to flash it.
                                    There are few listings for your board on ebay...
                                    • Spitz
                                      • Oct 2010
                                      • 95
                                      Did you buy it using a credit card? Some credit cards will double the factory warranty if purchased through them.
                                      • Ruptor
                                        • Sep 2021
                                        • 35
                                        • GB
                                        Yes maybe but it failed over 9 months ago and I was so disgusted with it I put it out of sight to stop me from smashing it up.
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • massimomax
                                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                          by massimomax
                                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                                          Post in English !!!
                                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                          02-28-2025, 07:27 AM
                                        • Bazilwrc164
                                          Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                                          by Bazilwrc164
                                          I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                                          The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                                          I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                                          If anyone can provide:
                                          • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                                          • Or a compatible EEPROM dump
                                          07-23-2025, 12:15 PM
                                        • EnricoS92
                                          Hitachi 43HAE4251 - Vestel 17MB171 - Displays logo and reboots
                                          by EnricoS92
                                          I have a problem with this tv Hitachi with vestel 17MB171 board.
                                          I turned off a couple days ago and the next morning when I turned on it had the issue, i tried to left the power unplugged for several hours but nothing.
                                          The tv turns on shows the logo picture and after a few seconds reboots, and start over again.
                                          I was able to connect via uart to the tv and grab the log I attached, it has logged 3 reboots.
                                          I believe it is a corrupted software, but I could not find any online, does anyone has it, or where to download....
                                          12-08-2021, 05:59 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
