JVC LT-40C860 stuck on logo
  • ioanban
    • Dec 2020
    • 47
    • uk
    Hi guys,
    I have a JVC LT-40C860 stuck on logo.
    I have tried all sorts of resets but nothing seems to help.
    I have checked the fuses on the main board and power supply and capacitors everything seems ok.
    From what i was reading on the forum I tend to believe it's a firmware problem.
    Now the question, is anyone who can give me the firmware so that i can put it on a usb drive and see if it solves my problem ?
    Tried contacting JVC but i got no reply.
    I've attached some pictures with the boards in case anyone wants any extra info.
    Thank you,
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: JVC LT-40C860 stuck on logo
    Is U13 an MX25L512 EEPROM or equivalent. If so I would freeze it with freezer spray and make cerain it gets really cold (set powered off) and then attempt to reboot the TV. You may have a failing EEPROM
    • ioanban
      • Dec 2020
      • 47
      • uk
      It is KH25L1606E. I'm just going to buy a spray and I'll give it a go
      • ioanban
        • Dec 2020
        • 47
        • uk
        I have frozen the EEPROM and it went over the logo but got reseted in a few seconds.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          if you cant find a firmware dump this maybe be your board maybe worth sending the seller a lower price offer
          https://www.ebay.co.uk/itm/234098833...EAAOSwpL5g-Jxy
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Try freezing it again and allow the EEPROM to get really cold. Give it several good blasts. Very often the inside of the IC hasn't become cold enough.
            • ioanban
              • Dec 2020
              • 47
              • uk
              I'll try gain, thank you
              • angelos
                • Dec 2012
                • 571
                • South Africa
                I saved a tv like that. I desoldered the chip off the board and fit it in my eprom reader. Then i sprayed it ice cold and started the read process. During the read i sprayed it again. I got a data image. Saved it, and dumped it into a new blank chip and viola. It worked , tv went out back to customer, fixed.
                • ioanban
                  • Dec 2020
                  • 47
                  • uk
                  Unfortunately the freezing didn't work for me and i don't think it's worth me buying a eeprom reader. I was looking for a firmware to use with an USB drive but no one seems to have one . I'm thinking on getting another main board.
                  • arizanotlari
                    • Nov 2014
                    • 158
                    • Turkiye
                    try this : https://yadi.sk/d/_zlpfQXu5tD28w
                    https://www.badcaps.net
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      The EEPROM reader/writer is dead cheap and worth having in your tool box.
                      • ioanban
                        • Dec 2020
                        • 47
                        • uk
                        Originally posted by arizanotlari
                        I have tried with this file but nothing happens, doesn't start updating
                        • ioanban
                          • Dec 2020
                          • 47
                          • uk
                          I have just ordered an EEPROM reader/writer . Thank you
                          • ioanban
                            • Dec 2020
                            • 47
                            • uk
                            Hi guys,
                            I have ordered an eeprom reader/writer but i couldnt get a working driver to be able to access the info on the eeprom so I bought a replacement main board and got it in. Tv is working perfect now.
                            If any of you has a reliable software for win10 that i can use with the eeprom reader/writer please share'it with me !
                            Regards,
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Which EEPROM reader/writer did you buy?
                              If it was the CH341A then here are a few progs that should work.
                              • lotas
                                • Jan 2016
                                • 4618
                                • Russia
                                Here is another program for CH341A.
                                • ioanban
                                  • Dec 2020
                                  • 47
                                  • uk
                                  I bought the CH341A.
                                  I'll try the progs you've given me.
                                  Thank you
                                  • Daniel Larsson
                                    Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                                    by Daniel Larsson
                                    My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                                    I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                                    During these seconds the function button is not working...
                                    Yesterday, 10:29 AM
                                  • mr.Data
                                    Macbook A1990 stuck on logo
                                    by mr.Data
                                    This Macbook Pro 2018 boots up and then gets stuck on the logo.
                                    All the normal methods of resetting this Macbook have been tried but do not work.
                                    I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
                                    Any help would be greatly appriciated....
                                    04-18-2024, 11:51 PM
                                  • platinumsteel
                                    Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                                    by platinumsteel
                                    Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                                    03-18-2024, 05:16 PM
                                  • digtalhd
                                    Dell Inspiron 7490 Stuck on Dell Logo
                                    by digtalhd
                                    Hi!
                                    Anyone hepl me! My laptop stuck Dell logo after I clear ME.
                                    Dell Inspiron 7490
                                    S/N: 28760285127
                                    LA-H451P Rev: 1.0
                                    Thank!...
                                    11-13-2024, 10:17 PM
                                  • Raymond red (mon)
                                    Brother J2730-DW stuck on Brother Logo
                                    by Raymond red (mon)
                                    hello, I have this Brother J2730-DW printer that was brought to me by a friend, it was supposed to be converted to continues ink but the printer wouldn't turn on completely. The printer powers on and plays a tune but it gets stuck in the brother logo. Upon checking, the printer was infested by many small cockroaches. I do checked the board cleaned and tested some corroded capacitors but all seems to be fine, I couldn't find any short circuit or any missing component on the board. Also checked the power supply and it was working fine.
                                    please help.
                                    11-08-2024, 09:19 AM
