Samsung un43ru7100f no picture, flashing backlight
  • a460guy
    • Oct 2013
    • 59
    • it's
    Hey guys, ive got a samsung un43ru7100f that when turned on, only the backlights flash every few seconds. The guy i got the tv from said he took it to a tv repair place and said it needed a new lcd panel. What are your thoughts?
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung un43ru7100f no picture, flashing backlight
    Flashing backlights on a Samsung is usually a sign of bad backlights. To confirm, unplug the cable between the power supply and main board and this will force the backlights on.
    • a460guy
      • Oct 2013
      • 59
      • it's
      I did this and the backlights come on and stay on.
      • neilc6
        • Nov 2015
        • 1550
        Second test is to only connect one side of the TV at a time and see if one side displays an image. Also see if the backlights stay on with both sides disconnected as well. Don't think this model has a tcon board so not sure what the outcome may be in models with integrated tcon boards.
        • a460guy
          • Oct 2013
          • 59
          • it's
          This model does not have a tcon board. When only one ribbon is connected i get solid backlight and sound but no picture. This works with either ribbon. If only one is connected i get solid light and sound......i found a main board on ebay for 30 bucks so i will try that. But i would like to find the fault. Any ideas?
          • neilc6
            • Nov 2015
            • 1550
            Could still be a bad panel. I've seen bad panels on models with integrated tcons that cause the TV not to turn on.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4539
              • Italy - Milan
              Don't buy main board, you are here to receive advices so don't take your own decisions please, this can end in board scarce availability for others. If i'm not wrong this behaviour is due to a bad capacitor on one panel's small board, you have to remove them all one at a time and test, after that you tested for short on them, it exists a C56 or C53 start with it..
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4539
                • Italy - Milan
                In today's samsung models tcon is integrated with main..
                • a460guy
                  • Oct 2013
                  • 59
                  • it's
                  Oh great! Yes i would rather find the fault. Here is a pic of the main board. Could you show me where the common fault area is?
                  • a460guy
                    • Oct 2013
                    • 59
                    • it's
                    Ok on the boards with the flex ribbon going to the panel.....i see...will check
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4539
                      • Italy - Milan
                      sorry , my cellular, i rewrite last sentence.
                      after that you test for short on them, if exists a C56 or C53 start with it..
                      To remove them if you don't have hot air then take a cutter with very sharp blade, put slow pressure on the basement of them and cut them away, very slow if not them flies away. Remounting of them's very easy, dont add solder only flux and use stilus iron.
                      • a460guy
                        • Oct 2013
                        • 59
                        • it's
                        What temp would you recommend for hot air? And thats pretty close to the ribbon cable....will that come loose if it gets hot? Also i checked all of them for short using the area in my pic marked red for ground. Is this not good enough to test? Or do i have to remove them and check there value? What should they be rated at?
                        • a460guy
                          • Oct 2013
                          • 59
                          • it's
                          Pic
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4539
                            • Italy - Milan
                            I don't have a professional hot air station, only a portable one that i've used few times, so i don't know, if i remember rohs tin melts at around 230 degrees european measure, for the ribbon you can mask it with aluminum foil, the area for gnd is ok but remember that not always shorts are revealed by a 3v lowcurrent tester, so you must remove them mandatory, the caps are 25v minimum, much probably them are those connected in parallel to Avdd tension of tcon so start with them, that are the biggest ones. Aftet each removing do a test of tv.
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • learnmore
                              Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                              by learnmore
                              Hello Community!
                              CASE DETAILS
                              Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                              13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                              Tried inserting firmware on USB and left it in for a few hours, but no change
                              03-03-2024, 09:49 AM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • Ierwin
                              by Ierwin
                              05-13-2025, 03:31 PM
                            • Fenzon
                              Samsung UE43NU7122 has Picture, but no Backlight
                              by Fenzon
                              Greetings fellow DYIers, the moment I discovered this community forum, nostalgia has hit me pretty hard, this early web 2.0 look and feel is close to home. I can't describe my happiness seeing active forums that survived today, and its not just yet another centralized propriety subreddit.
                              Before I describe my issue with this particular TV, I would like to let you know that I do have basic electronic competence, and some electronic component knowledge. I also am an electrical installation technician student, although we exclusively study alternating currents and our primary...
                              09-26-2023, 03:17 AM
