Jvc EM65FTR 65 No Standby light DEAD
  • Super360
    • Jul 2016
    • 243
    Hi all, I have a very nice 65 jvc tv with good ole component inputs. Its dead as it gets no power, no standby light. I know these tv's have issues with eeproms. Anyways here's some pics I cant find a eeprom for my board # on shopjimmy, kinda weird.
  • Super360
    • Jul 2016
    • 243
    Re: Jvc EM65FTR 65 No Standby light DEAD
    So this is what I need? That is for a vizio tv not a jvc though. I wonder if that would work?
    • Super360
      • Jul 2016
      • 243
      Nevermind found the right one right here. I'll keep you guys updated.
      • CapLeaker
        Leaking Member
        • 8352
        See if the main board gets stby voltage first place!
        • Super360
          • Jul 2016
          • 243
          I just check stby is normal. 19v
          • CapLeaker
            Leaking Member
            • 8352
            19v Stby? Really?
            • R_J
              • 9625
              19v Stby? Really?
              The power supply is an always on power supply that supplies 19v to the main board, The main board has the low voltage regulators.
              • R_J
                • 9625
                Shopjimmy has the correct eeprom for $15.00. If you have any freeze spray, Unplug the tv, Spray (freeze) the ic, wait 10~20 seconds and plug in the tv and see if it will turn on. Some times this trick will work indicating the eeprom is at fault and allows the tv to be checked. If this does not work, it could still be a bad eeprom.
                • CapLeaker
                  Leaking Member
                  • 8352
                  I don’t think the main IC runs on 19V. There must be a buck converter somewhere then on the main board.
                  • R_J
                    • 9625
                    On the main board, +19 supplies UP18?, which outputs +12v,
                    +19v supplies UP1? which outputs +5VSB. I will find the correct ic numbers, I believe they are up18 & up1
                    • Super360
                      • Jul 2016
                      • 243
                      Yea kinda weird right 19v standby like wtf where is the 3.3v, 5v, 12v standard.
                      • CapLeaker
                        Leaking Member
                        • 8352
                        Yeah RJ, I can't see that on my lil iPad. Next time I am going to buy the big one. Anyway... still same idea here, by checking the buck regulators that down convert the 19V to 5V STBY. If that buck converter is good, then its either the flash or the main CPU. You can try freezing the flash with a can of air upside down, then turn on the TV with the frozen flash IC. After that I would try backing the whole main board and see if that fixes it.
                        • jkb242
                          • Mar 2012
                          • 175
                          Not to beat a dead horse, but almost without fail the 5vdc reference/stand by voltage is produced on the power supply board. I’m not familiar with your set but in general, that’s pretty much standard throughout the industry. There maybe a 19v-5.0v regulator on the main board but its possible that 5v is for another purpose. Good luck.
                          • lotas
                            • Jan 2016
                            • 4899
                            • Russia
                            You need to check these power supplies, they correspond to your board
                            • Super360
                              • Jul 2016
                              • 243
                              So I soldered on the eeprom the correct way with the dot facing same direction and now tv is dead not even a red standby light anymore.
                              • R_J
                                • 9625
                                Are you saying you ordered and received a new eeprom? Dot facing same direction? same direction of what? pin 1 is marked on both the ic and the board
                                • Super360
                                  • Jul 2016
                                  • 243
                                  Yes the one I bought from on shop-jimmy on e-bay. I soldered it in and now no stanby light anymore.
                                  • Super360
                                    • Jul 2016
                                    • 243
                                    In all honesty I did accidentally muck up this ribbon connector. I ordered a new board from e-bay 30$.
                                    • CapLeaker
                                      Leaking Member
                                      • 8352
                                      If I would have known earlier that this board has an MSD main IC... that's your problem. 9 times out of 10 when I had a main board with the MSD main IC it was bad, not the eeprom.
                                      Looks like there is some questionable (re)soldering work around the MSD IC.
                                      • Super360
                                        • Jul 2016
                                        • 243
                                        It's funny with tv repair most of the time its easier to just replace boards then screw with all this mess.
                                        • mecha1166
                                          QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                                          by mecha1166
                                          I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                                          03-28-2024, 08:31 AM
                                        • esqmooo
                                          HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                                          by esqmooo
                                          Hello everyone.
                                          This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                                          Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                                          Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                                          I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                                          03-11-2025, 03:57 PM
                                        • wushumike
                                          LG 65UB930T - Standby Light can trigger but TV dead
                                          by wushumike
                                          The problem: When remote controller is press, the TV seems to wake from standby light goes off; but there is no backlight, image and sound. The relay did click on.
                                          I have removed the power board to check. Using 2 x 10K resistor from 3.5V to PWR_ON AND DRV_ON, all the voltages is correct.
                                          The main board has a red LED and is lited, but the optic link does not light up.
                                          The Power board after sometime will start to blink x 5 interval.... I would assume this is to indicate DRV_On not working.
                                          Any expert here came across the same problem? I...
                                          03-27-2023, 09:46 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • shagster
                                          TX-P50UT30B Dead - No Standby light.
                                          by shagster
                                          Hi, haven't been on the forum for a while. But I thought I'd ask here incase this has already been solved.
                                          Anyway, I have this Panasonic TX-P50UT30B. It's completely dead, no red standby light, nothing. I took off the back and had a look at the fuses. All of them are intact. No shorts when testing the mosfets of the Power supply either.
                                          And the capacitors look fine also.
                                          I'm guessing it's a main board issue. But I don't really know tbh. Maybe a corrupt firmware flash, dunno.
                                          02-27-2023, 10:07 AM
