philips 32pfl5403d/10 error code help
    good morning,this philips chassis q522.1e la
    no sound or pic .psu starts up with 12v -12v ,5.2v 24v.supplies
    no b/l
    then relay clicks off ,then on ,followed by protection mode :
    5 slow blinks then 3 fast blinks.according to manual:
    "a long blink indicates the decimal digit, a short blink indicates the units"
    before protect mode starts there is
    no volts on t con fuse.
    cant see from cct where the feed volts for t con come from ,possibly main board
    this uses ccfl with inverter board .
    checked caps in psu with esr meter ,replaced a couple that were borderline
    are there any philips specialists that could help please
    maybe point me in right direction
    Re: philips 32pfl5403d/10 error code help
    anybody?
      Error 53. This error will indicate that the PNX85xx has read
      his bootscript (if this would have failed, error 5 would blink)
      but initialization was never completed because of hardware
      problems (NAND flash, ...) or software initialization
      problems. Possible cause could be that there is no valid
      software loaded (try to upgrade to the latest main software
      version).
        slightly different model number but yes points at a faulty main board
        https://www.elektroda.com/rtvforum/topic872009.html
        it maybe worth trying a firmware update or you may have too source a secondhand main board if cost effective
          from philips website i downloaded software update its a "autorun22m.upg "file
          extracted and followed instructions ,
          sadly fault persists.
          im wondering if the update shown above is not a complete software ? just an update for existing software?
          also in the past i have been missled with error codes ,
          just wondered if it is f/w related ,would this account for no 12v supply to tcon ?
          i have spent time checking all other supplies derived from main board they seem ok
          the led responds to remote pressing but wont allow to switch into sby etc
            If you search for "philips error 53" in this category in the forum, you'll find previous questions about this error-code that probably relate to your situation.
            A good thing with these older models that you have, is that they have extensive service manuals, complete with circuit diagrams and fault-finding flowcharts.
            From this page you can download the service manual that covers your model:
            https://www.electronica-pt.com/esque...ileinfo/14452/
            Chapter 5 has what you need to study.
            Assuming that your main processor's BGA-chip hasn't warped itself off some of the pads underneath against the PCB after years of thermal cycling, you might have a worn-out flash chip where the Linux filesystems are stored.
            It can be a "computer error" of some kind like that, because the standby controller (an 8-bit microcontroller physically present inside the same BGA-chip as the main processor) fails in attempting to boot the main processor.
            I'd find a way to inspect the serial output from both the standby controller and the main MIPS-processor, and your model even has RS232 so you can listen in on the output from a COM-port, if you still have a computer with such a thing.
            The serial speeds on the QFU1.2E LA that I managed to get working, were 115200 8N1 on the main processor and 57600 8N1 on the standby controller, maybe it's the same on this one, but really there aren't that many speed alternatives, so just try them one by one.
            Use a terminal program with serial support like Putty or Tera Term to set the serial speed and to inspect the output from both processors.
            Plug in the serial connection while the TV is unplugged and have the terminal running, then plug in mains power to the TV; you should be getting output pretty much instantly.
            Leave it running until the TV starts blinking the error code.
            It will be screenfulls probably, but just save the outputs to text-files and search in the collected text for words like "error", "fail", "warning", "corrupt", etc.
            On my model the valuable information came from the main processor's TXD, but this is technically a standby-controller error, so you might as well look at that as well while you are at it, maybe it has some useful error message.
            Curiously, according to table 5-2 in your service manual, error 53 is an error state and not a protection state on your model, so the TV should not be in protected mode where several power rails have been turned off.
            Maybe it's a typo; if you don't have all rails present, then see section 5.2.1 and the corresponding figure 5-1 for instructions on forcing a hardware SDM (temporarily short the two SDM-pads together).
            This will leave all power rails on even in protected mode, so they can all be measured.
            After all; thou shalt check voltages, and maybe this is caused by a problem on one of the main processor power rails.
            Please post the serial output-files into the thread, if you are able to produce them from the TV.
              a BIG thankyou to maalobs
              for taking the time to post such detailed information
              you have certainly helped to point me in right direction,
              i still would like to find where the 12v supply to tcon comes from.
              there should be a" panel on" from the micro usually via a couple of fets
              which switches on the tcon 12v on the mainboard
                I think you're following a red herring; the TV set is giving you an error code, why not follow that symptom instead.
                Look at Figure 5-4 in the service manual where the "off to semi standby" flowchart begins.
                Read through it and into Figure 5-5 (part 2) on the next page, it explains everything that happens up to Code = 53, and everything that happens after that error, which includes shutting down various power rails:
                It appears to me at least that power rail states on the TCON board are unrelated to producing an error code 53.
                Error code 53 could instead be the reason that expected power rails are not present.
                If you do want to measure the power rails before addressing the actual error that the TV set is telling you, then activate the SDM.
                There is a warning in section 5.3 regarding SDM however, that FET 7U08 should be measured first to avoid destroying ICs powered by the 3V3 rail, but my interpretation is that this scenario only applies to error code 8:
                Code:
                5.3 Stepwise Start-up
                There are two possible situations: one for protections detected
                by the stand-by software and one for protections detected by
                the main software.
                When the TV is in a protection state due to an error detected by
                stand-by software (and thus blinking an error) and SDM is
                activated via short-circuiting the pins on the SSB, the TV starts
                up until it reaches the situation just before protection. So, this
                is a kind of automatic stepwise start-up. In combination with the
                start-up diagrams below, you can see which supplies are
                present at a certain moment. [B]Important to know is, that if e.g.
                the 3V3 detection fails (and thus error 8 is blinking) and the TV
                is restarted via SDM, the Stand-by Processor will enable the
                3V3, but will not go to protection now. The TV will stay in this
                situation until it is reset (Mains/AC Power supply interrupted).
                Caution: in case the start up in this mode with a faulty FET
                7U08 is done, you can destroy all IC's supplied by the +3V3,
                due to overvoltage. It is recommended to measure first the FET
                7U08 on short-circuit before activating SDM via the service
                pads.
                Maybe I'm right, maybe I'm not.
                Either way, the FET is located here on the SSB top side:
                Better to be safe than sorry I suppose; check that FET for short circuits before forcing the power rails to the ON state with SDM.
                  thanks again i will update soon
                    How far are you getting in the boot sequence? must be quite far if you are getting to the error codes.
                    When you remove the logic board from the tv how are the heatsink pads? are they dry and crispy or wet and oily?
                    Successfully completed Repairs:
                    Current repairs:
                      sorry been busy with other repairs ,
                      i assume you mean the main board?
                      which has no heatsink pads that are removable
                      nor does the t con board?
