Magnavox 19md357b REPAIRED!!!
  • soulripper
    • Aug 2011
    • 22
    Re: Magnavox 19md357b REPAIRED!!!
    Thanks I will be starting Shortly on Opening case and see what I got to deal with.
    • soulripper
      • Aug 2011
      • 22
      Heres a Summary of the task at hand,I have check all connections and other component for this TV all is in good condition no burnt cables connectors or any of the sort.except for some the one's listed on the Bottom list.
      I will fallow you're advice and replace all of them since I see they used low quality one's overall.Don't know when I will be able to buy since I am in very limited funds. Will keep as a prioroty since I am very excited about this.
      will go online to check now for the Price of the Products needed.
      C118 = Blown
      C107 = Good
      C176 = Good
      C102 = Good
      C502 = Good
      C112 = Blown
      C555 = Good
      C175 = Good
      C117 = Blown
      C503 = Half way Blown
      C114 = Good
      I have gone to Mouse web site made a Account. is United Chemi-Con a good Company for quality capacitors if not please help me pick one Brand that is good.Thanks in advanced
      Last edited by soulripper; 08-29-2011, 03:42 PM. Reason: Forgot an Important question
      • soulripper
        • Aug 2011
        • 22
        I have place my Order thru Big Pope for my Capacitors when I received them and install on the moment of thruth.Will post. thanks Dgtech and BigPope caught the misprint and is all good.
        • soulripper
          • Aug 2011
          • 22
          Well I started it seems unsoldering to old solder is really hard.oh will do because I am learning more than I realize definetly wanna see it thru.
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            Flow some new solder into the joint first. That will help melt the old solder.
            Ludicrous gibs!
            • soulripper
              • Aug 2011
              • 22
              Thanks I will this advice sounds like a good idea.
              • Marsh1
                • Sep 2011
                • 4
                #27
                How did you make out? I just replaced a few capacitors on a 26" Magnavox. Very simple. High school electronics came in handy. lol
                • soulripper
                  • Aug 2011
                  • 22
                  hoping the caps get here soon.Like i said in my previews post. when desoldering to old solder is was very hard but someone gave some great advice and solder new top of the old and that will make it simpler to extract. Name is dood and thanks to him a million.
                  • soulripper
                    • Aug 2011
                    • 22
                    Awesome glad it worked out for you kudos.
                    • Mike95inNJ
                      • Feb 2011
                      • 18
                      Hello everyone. This is my first post here. I googled Magnavox 19md357b and found this thread. I garbaged picked this same tv/dvd player combo this past Saturday. Plugged it in, came on for two seconds, saw a green line and heard a noise, then it went blank. This was my third attempt at repairing an lcd monitor or tv. I'm two for three after replacing three bulging and leaking caps.
                      All three were 1000 uf 10V. I replaced with 1000 uf 16V. A bonus was a dvd still in it of the movie " I love you man". Worked out well for my daughter who's 19" lcd tv had a bad speaker. Gave her this tv and replaced her 14" lcd monitor (previous repair 1 bad cap replaced) with her tv with the bad speaker.
                      Thanks to all for the info found here. Much appreciated.
                      Mike95 in NJ
                      • margo t
                        • Oct 2011
                        • 9
                        #31
                        OK, so I have most of the information I need to try to repair this TV. When I order the caps listed in the first post do I need to specify a brand or just this, for example: 10000uF 10V?
                        • Dgtech
                          E. Technician
                          • Apr 2009
                          • 1462
                          • Steeler
                          #32
                          You can order them from www.Badcaps.net to remove all doubt of what you're getting. He has low ESR caps here.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            You need to order "low ESR" caps. For a SMPS application, low ESR (ohms) caps are required.
                            A number of companies like Rubycon, United Chemi-con, Panasonic, and Nichicon make quality low ESR caps.
                            A complete list is here at
                            https://www.badcaps.net/forum/showthread.php?t=2280
                            Members here like Panasonic FR, FM, and FC (in order of lowest ESR). This immediately simplies your choice down to one company and a few series of caps. PlainBill has written instructions on how to order from digikey at
                            https://www.badcaps.net/forum/showpo...33&postcount=2
                            Or as Dgtech writes, you can order them from this site at
                            https://www.badcaps.net/pages.php?vid=26
                            --- begin sig file ---
                            --- end sig file ---
                            • margo t
                              • Oct 2011
                              • 9
                              #34
                              Thanks so much for the replies! I'll post pictures if/when I have the thing taken apart.
                              • margo t
                                • Oct 2011
                                • 9
                                #35
                                I know I should probably have more training and experience to try this but figure I have little to loose; the tv won't work and I'm not going to pay to have it fixed.
                                So -- I'm in the process of taking it apart and have the base unscrewed and the back of the monitor loose and I'm at the point where I need to detatch the small, delicate connections to the DVD player part. I can see how to detach them but how on earth am I ever going to get them reattached when it's time to put the whole thing together? It is such a small, tight space to work in.
                                • margo t
                                  • Oct 2011
                                  • 9
                                  #36
                                  A photo - probably does not help ..
                                  • Dgtech
                                    E. Technician
                                    • Apr 2009
                                    • 1462
                                    • Steeler
                                    #37
                                    They just slide out. Use needle nose pliers if you have them. If not, just give a little wiggle and out it comes.
                                    • margo t
                                      • Oct 2011
                                      • 9
                                      #38
                                      Thanks for the support!
                                      Also, I found that there is a removable panel that makes this more accessible - that will make it MUCH easier. Posting a pic for other dummies like me!
                                      Gently but firmly just pull it off.
                                      • margo t
                                        • Oct 2011
                                        • 9
                                        #39
                                        Look, see the bad caps? I'm almost ready to begin the repair - yay!
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          They look like Capxon brand? If yes, they make terrible caps and have a poor reputation for reliability.
                                          • tonybig10
                                            Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                                            by tonybig10
                                            Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                                            the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                                            03-07-2025, 01:03 PM
                                          • chronic519
                                            Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                                            by chronic519
                                            Hello.
                                            GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                                            Found issue with a RAM block
                                            Replaced, green lines gone.
                                            Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                                            Used a good card to test and same results low errors 32+.
                                            I am just search for some form of command to do a full test on the GPU.
                                            I just ran the mats command with my good GPU and passed after roughly 40 min.
                                            The repaired one, ran...
                                            05-20-2025, 07:56 PM
                                          • Stephen
                                            A2338 M1 Not turning on - Repaired slightly but still having issues
                                            by Stephen
                                            Repaired a customers computer, had a faulty APL 1097 chip and replaced, all well, not shorted anymore, however I am finally getting 12.28Volts on PPBUS_AON, however it stays at 12.28 and doesn't increase to the normal 12.60 Volts. I read that this is the cause
                                            • If the voltage is approximately 12.28-12.35V, it may indicate a communication issue between the SOC and PMICs, or corrupt firmware.
                                            ​Can someone point to me what would be the next step to fix this. I can feel we are getting close to fixing this board, however this is a data recovery and we need to fix the computer to recover the data....
                                            02-26-2024, 02:25 PM
                                          • iam5
                                            Intermittent USB-C / USB-A issues + Trackpad Freezes — T14s Gen2 (11th-gen Intel) — Seeking Board-Level Advice
                                            by iam5
                                            I’m looking for advice on board-level troubleshooting and potential component-level repairs for a Lenovo ThinkPad T14s Gen2 Intel (i7-1185G7) showing multi-domain instability. Hoping someone familiar with this platform (or the related X1 Carbon Gen9/Gen10, X13 Gen2, X1 Nano Gen1/2) can point me toward the right section of the board to inspect, and whether any of the known fixes apply. Symptoms:
                                            1. Trackpad (CS21 module) intermittently freezes during active use
                                            • Not tied to lid open/close
                                            • External USB mouse continues working
                                            • Sometimes recovers with sleep/wake
                                            • Looks like
                                            Yesterday, 09:29 AM
                                          • pappothar
                                            Lenovo legion 5-15ach6h IT8227E-192 CXA shorted, repaired but no screen / no boot
                                            by pappothar
                                            hi
                                            i bought a defective legion, tested it had the IT8227E-192 CXA shorted.
                                            I ordered on aliexpress, carefully changed it under microscope, and now when i plug the dc in, keyboard flashes in all colors in loop, on button is white, and nothing more
                                            The battery led is charging, it seems is the only thing that works
                                            Screen is off, nothing, not even the backlight
                                            could it be a non programmed IT8227E ?
                                            Awaiting for your feedback
                                            Thank You
                                            Stefano
                                            09-15-2025, 08:37 AM
