Magnavox 19md357b REPAIRED!!!
  • margo t
    • Oct 2011
    • 9
    #41
    Re: Magnavox 19md357b REPAIRED!!!
    Yep, they are! I just replaced them and the TV is working great!! I am totally jazzed that I was able to do this myself!!
    • margo t
      • Oct 2011
      • 9
      #42
      Quick follow-up: The TV still works great but the DVD player does not work. I wonder if anyone can suggest what I might have done wrong? The player is supposed to just sort of pull the dvd in when you put it into the slot but it doesn't anymore.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5041
        • New Zealand
        #43
        Might just be a mechanical problem with that part
        -David VanHorn
        • soulripper
          • Aug 2011
          • 22
          I am Back after Moving and all that comes with it finally found all the boxes that had all my Parts for the Magnavox 19md357b TV sat down and replaced all the Caps still need to find Screws for the stand lol jokes on me for now.will look for them in the next few days. Since I have to do some Glass Tile back splash for someones Kitchen the end will have to wait.I am really excited to see end results.
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            #45
            Just as a side note: Here is some quick pics of my backsplash project in a small kitchen.
            • soulripper
              • Aug 2011
              • 22
              Oh Wow Great Job Dgtech ty for sharing the Pic.
              • soulripper
                • Aug 2011
                • 22
                I need some Help please.
                this is the small Board on the DVD connection Base for the TV.
                Sorry I can't take Pictures no Camera and no money for now for it.
                Cables I have to be connected I will specified colors on the two 4 Pin connectors.
                One has this Colors. from ( Left )-- Red,Yellow,White,Black (Right)--
                Other is (Left)-- Black,Black,Red,Red--(Right)
                Hope this Helps on my need.
                BTW I did made a drawing on the Lay-out of Cables but that drawing was lost when I moved the whole notebook.
                • soulripper
                  • Aug 2011
                  • 22
                  Number on the Board I am talking about on Above Post is ((((715T2437 board ))))
                  • Dgtech
                    E. Technician
                    • Apr 2009
                    • 1462
                    • Steeler
                    #49
                    Sorry I could not get back to you sooner.
                    There are a couple ways to find out which one goes where. One way would be simply to look at the board. Sometimes there will be a notation of polarity as well as color code. There may just be a pinout of what each pin represents.
                    Example:
                    Lets say one that is (Black-Black-Red-Red)
                    On the top side of the board or the bottom may say (GND GND 12V 12V)
                    or some variation of that.
                    • soulripper
                      • Aug 2011
                      • 22
                      Oh wow thanks very much will get to work on that.
                      • soulripper
                        • Aug 2011
                        • 22
                        all the board specifies is 1---4 Pins and such things like that but no specifics about plus or minus for Voltages the schematics history u usually see on the Electronic Boards.
                        • soulripper
                          • Aug 2011
                          • 22
                          Originally posted by margo t
                          Thanks for the support!
                          Also, I found that there is a removable panel that makes this more accessible - that will make it MUCH easier. Posting a pic for other dummies like me!
                          Gently but firmly just pull it off.
                          Thanks for this Photo Margo I was able to finally know where some of the four pin cables orders need it to b at.
                          Now I turned it on and Power button lights up but just a plain Black Screen. Should I hook it up to a cable Box to see if it works.?
                          Or maybe is a just a big fail on my behalf.
                          • Deadbit
                            • Mar 2012
                            • 5
                            try plugging a cable into it and also check the other connection points to make sure they work as well. I had this same problem but my a/v jacks and HDMI port worked fine...svideo worked too but none of the other ports save for the 3.5mm audio jack worked. I can live with that personally as I'm only using it as a pc monitor via svideo and for my xbox/ps3 hd setup.
                            • Deadbit
                              • Mar 2012
                              • 5
                              no more than I post my previous reply, the Damn thing dies on me...this time I tried to turn it back on and the menu worked for half a second and then the thing became unresponsive...yay...back to square one for me.
                              • rda10002002
                                • Jul 2012
                                • 19
                                • usa
                                #55
                                Ok i am compleatly new to this and i need to replace the caps on my board. When i go to order the Caps i am at a loss for what ones to order. I was hoping i could get some help....It does seem like i need all of the ones from the first post. Any help would be appreciated
                                • Dgtech
                                  E. Technician
                                  • Apr 2009
                                  • 1462
                                  • Steeler
                                  #56
                                  You could either take the list from the original post to an electronics part store or use that list to buy from badcaps.net or digikey. It's pretty straight forward.
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #57
                                    You should really list the caps you have on your board to make sure you have the same values. You should buy panasonic FM or FCs to replace.
                                    NOTE - if you use the list there is an amendment to the first item.
                                    • Deadbit
                                      • Mar 2012
                                      • 5
                                      Well..I know it's been a while but I FINALLY got around to replacing some of the caps. Replaced 3 of the 1000uF 10v caps and the tv works fine...mostly. I've decided to completely refurb the tv to sell on ebay. As of right now the volume + button doesn't work but all of the other top buttons work. The dvd also plays fine but none of the buttons work for it. I had to dismantle the drive to retrieve the dvd. Will not eject or anything. I don't have an esr meter to test the caps but could one or more of the caps be the culprit?
                                      • Deadbit
                                        • Mar 2012
                                        • 5
                                        Well...I decided to just replace all the capxon caps. Gotta wait for my 330's to arrive...I was out of stock on them. There's one other problem I forgot to mention. When trying to turn off the tv, it goes off for about 2 or 3 seconds and then turns itself back on. Any way to remedy this (without using my sledge hammer, lol)?
                                        • Dgtech
                                          E. Technician
                                          • Apr 2009
                                          • 1462
                                          • Steeler
                                          #60
                                          This sounds like a very bad experience selling this one on ebay. First, you're not going to get much for a refurb let alone that it's only 19 inch. Then add on that it has issues like the volume control and DVD. You'll be selling it for $20 and it will cost about $10 to ship it.
                                          • tonybig10
                                            Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                                            by tonybig10
                                            Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                                            the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                                            03-07-2025, 01:03 PM
                                          • chronic519
                                            Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                                            by chronic519
                                            Hello.
                                            GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                                            Found issue with a RAM block
                                            Replaced, green lines gone.
                                            Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                                            Used a good card to test and same results low errors 32+.
                                            I am just search for some form of command to do a full test on the GPU.
                                            I just ran the mats command with my good GPU and passed after roughly 40 min.
                                            The repaired one, ran...
                                            05-20-2025, 07:56 PM
                                          • Stephen
                                            A2338 M1 Not turning on - Repaired slightly but still having issues
                                            by Stephen
                                            Repaired a customers computer, had a faulty APL 1097 chip and replaced, all well, not shorted anymore, however I am finally getting 12.28Volts on PPBUS_AON, however it stays at 12.28 and doesn't increase to the normal 12.60 Volts. I read that this is the cause
                                            • If the voltage is approximately 12.28-12.35V, it may indicate a communication issue between the SOC and PMICs, or corrupt firmware.
                                            ​Can someone point to me what would be the next step to fix this. I can feel we are getting close to fixing this board, however this is a data recovery and we need to fix the computer to recover the data....
                                            02-26-2024, 02:25 PM
                                          • pappothar
                                            Lenovo legion 5-15ach6h IT8227E-192 CXA shorted, repaired but no screen / no boot
                                            by pappothar
                                            hi
                                            i bought a defective legion, tested it had the IT8227E-192 CXA shorted.
                                            I ordered on aliexpress, carefully changed it under microscope, and now when i plug the dc in, keyboard flashes in all colors in loop, on button is white, and nothing more
                                            The battery led is charging, it seems is the only thing that works
                                            Screen is off, nothing, not even the backlight
                                            could it be a non programmed IT8227E ?
                                            Awaiting for your feedback
                                            Thank You
                                            Stefano
                                            09-15-2025, 08:37 AM
                                          • gurj1979
                                            MacBook Pro 820-01987- condensation damage repaired but has sensor issue
                                            by gurj1979
                                            Hi guys.
                                            Got a customer MBP 2020 which has a dad of corrosion from condensation, resulted in no power at all.
                                            I replaced the corroded components and repaired the traces. Restored power and now Iccan get to login screen.
                                            But when the CPU gets warm (not hot) and fan gradually starts spinning faster and then MBP turns off. Pressing power button turns it back on for couple of seconds then it turns off again.
                                            Seems sensor related, but it won't even let me get as far as running the built-in ASD.
                                            I can get back to you later with the components...
                                            08-01-2023, 02:38 PM
