Philips 42PFL5432D/37 power supply issue no 12v
  • Ifixstuff9
    • Jul 2017
    • 120
    I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
    After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector to the main board:
    Pin 1 +24v --------------- 24v
    Pin 2 +24v --------------- 24v
    Pin 3 +12v --------------- 490mv
    Pin 4 +12v --------------- 490mv
    Pin 5 Brightness Adj ----- 0v
    Pin 6 Inverter ON/OFF --- 0v
    Pin 7 GND ---------------- GND
    Pin 8 GND ---------------- GND
    Pin 9 GND ---------------- GND
    Pin 10 Stand By ---------- 0v
    Pin 11 GND --------------- GND
    Any thoughts on why I have 24v but not 12v?
    Also I was able to find the service manual for this TV here:
  • R_J
    • 9550
    Re: Philips 42PFL5432D/37 power supply issue no 12v
    IC907 is the drive ic for the 12 volts, Start by checking if it has VCC on pin 1 (You must use hot ground for your negative meter lead) and check if it has Drain voltage on both sides of R951.
    Or you can start by checking R974, R976 and Q906
    • Ifixstuff9
      • Jul 2017
      • 120
      I checked IC907 and got 1.53v on pin 1, and 160v on both sides R951
      • R_J
        • 9550
        So the VCC is way too low, this could be due to a shorted ZD908, or the ic could be bad, The ic has a startup cell so make sure C957 is ok and not open. Then Check R974 to make sure it is not open.
        • Ifixstuff9
          • Jul 2017
          • 120
          I tested ZD908 in circuit and it's not shorted. Checked C957 and it's not open, neither is R974
          • R_J
            • 9550
            It's likely IC907 that is bad, you have 160vdc on R951 which supplies the ic pin8, internally the ic will produce a startup vcc of approximately 4vdc, If the ic starts and gives a pulse to Q908, it will drive the transformer primary and the feedback winding and D908 will charge C957 to about 11vdc. and then the ic will start operating.
            You could check that nothing on the secondary side is shorted, such as D927
            • Maalobs
              • Jun 2016
              • 120
              • Sweden
              See here about downloading the service manual.
              • Soulzink
                Samsug washing machine. Power supply DC41-00189a board issue
                by Soulzink
                I am trying to fix a samsung washinmachine power supply main board.
                I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                The power supply board reference is the following: DC41-00189a
                I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                04-19-2025, 06:26 AM
              • KYBOSH
                Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
                by KYBOSH
                I have a floodlight-security camera that recently died on me.
                its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
                Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
                07-01-2024, 06:54 AM
              • Cookybaby
                Samsung UN60ES6500FXZA Power Supply Issue
                by Cookybaby
                Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                Make: Samsung
                Model: UN60ES6500FXZA
                Power Supply P/N: BN44-00525A
                Symptoms: The TV was...
                08-20-2023, 12:26 PM
              • lp20th
                Samsung Plasma TV Power Supply Issue
                by lp20th
                I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                11-28-2023, 10:28 AM
