Thorn 65thl4kst1
  • viewerau
    • May 2020
    • 305
    Re: Thorn 65thl4kst1
    Good pickup... I am using my friends new Meter, but again, no beeper. Battery is strong, illuminating it's LCD screen very well. Today's measures are off this new device.
    Signature:Seemingly hopeless tv fixer
    • diif
      • Feb 2014
      • 6978
      • England
      #102
      I believe it's indicating it's out of range, those caps are higher than 200 ohm resistance, not shorted.
      Turn the range up to double check.
      • viewerau
        • May 2020
        • 305
        Thanks again.
        What setting would you recommend I use please?
        • viewerau
          • May 2020
          • 305
          I have been able to source a T-Con board at a very cheap price.
          On other threads that I have read, I have seen comment, not to attach a new T-con without checking that a faulty smd on the edge board is there, as this will likely blow the fuse on the t-con, rendering it faulty again?
          Can someone expand to me, as to what they reckon I could prove/determine without damaging the t-con?
          Thank you.
          • viewerau
            • May 2020
            • 305
            Researching some more, I believe that this television may be the same one?
            Can this help us any?
            Skyworth 65G9200 - 65 inch 4K Ultra HD Smart LED TV
            Looked familiar problem as mine, but I cannot understand what he actually did, other than reseat the ribbons?
            https://www.youtube.com/watch?v=b6sX-6J9npc
            • viewerau
              • May 2020
              • 305
              https://www.youtube.com/watch?v=Kt4pf0dW3Ss
              I see him at 4'30" measuring these.
              One time he has probes one way, at end the other way around.
              What way do I set up my meter to duplicate what he is doing, and would he be doing this with standby power, or totally unplugged?
              • diif
                • Feb 2014
                • 6978
                • England
                #107
                Measure with power off.
                If he's reversing probes then I'd guess his meter is in diode mode.
                • viewerau
                  • May 2020
                  • 305
                  Thank you.
                  Which is diode mode on this meter?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    #109
                    The one with the diode symbol.
                    • viewerau
                      • May 2020
                      • 305
                      Thank you,
                      I am trying hard...measurements just now
                      • viewerau
                        • May 2020
                        • 305
                        I have also found, that a "Skyworth 65G9200 – 65 inch 4K Ultra HD Smart LED TV" seems to be a clone of my tv....I hope this may help us somehow?
                        • viewerau
                          • May 2020
                          • 305
                          New second hand t-con made no difference...still white screen, audio only
                          • viewerau
                            • May 2020
                            • 305
                            Today's measurements, if any comment?
                            • viewerau
                              • May 2020
                              • 305
                              I also chased this down from numbers on the back of the panel.
                              • viewerau
                                • May 2020
                                • 305
                                Dead end is it?
                                • viewerau
                                  • May 2020
                                  • 305
                                  It appears I have stumped everyone with my issue.
                                  I guess some faults must be harder than others to give guidance on.
                                  • viewerau
                                    • May 2020
                                    • 305
                                    As there were no other hints I have put this away, until maybe someday, I read somewhere,that someone has a similar problem, and a fix is found.
                                    • viewerau
                                      • May 2020
                                      • 305
                                      I am about to play with this tv again
                                      Back to post 20, I put up these pictures, attached.
                                      The white screen when powered up, and a half screen with a t-con ribbon removed.
                                      Can anyone tell me, which t-con lead unconnected, would have given the half screen, as I can no longer repeat that when swapping ribbons, to connected or unconnected.
                                      Thank you
                                      • viewerau
                                        • May 2020
                                        • 305
                                        PLEASE...at 4.35 mark of this video...
                                        https://www.youtube.com/watch?v=Kt4pf0dW3Ss&t=299s
                                        How do you determine that it is this piece that was faulty.
                                        Do you have to test pins both ways to determine so?
                                        If you get the same reading by swapping your multi-meter prongs on opposite ends, and the reading is the same, does this determine it is bad?
                                        Thank you.
                                        • viewerau
                                          • May 2020
                                          • 305
                                          Ok you well learned persons, I now request your assistance again, please
                                          I now have acquired another exact same model model tv as my faulty one but it has a broken screen
                                          Knowing that my original tv is only showing backlights and no video ( please read all my earlier dialogue), which way would you go on me cannibalizing the parts from the broken screen one, and into my one which has backlights only .
                                          In my haphazard attempts previously, I have been told that faulty smd's on the 4 edgeboards may result in blowing replacement tcon boards, so what way should I reconnect everything to avoid such a mishap, and not end up shorting out the replacement bits that I now have....
                                          Thank you.....
                                          • Geeker007
                                            Friend messed up my laptop motherboard while working on my bench
                                            by Geeker007
                                            Hi All,
                                            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                                            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                                            I have not tried putting...
                                            06-16-2025, 01:40 PM
                                          • qwerty99
                                            Xbox 1.6 Motherboards and Polymer Capacitors
                                            by qwerty99
                                            Hello!
                                            I need to change the capacitors on my three original Xboxes.
                                            Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
                                            The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
                                            The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
                                            I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
                                            06-26-2022, 12:53 AM
                                          • Foetuss
                                            Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                            by Foetuss
                                            Hi all
                                            Hope this is in the correct place.
                                            I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                            Could use some double checking to see if I'm not doing something stupid .
                                            Pictures of the boards are attached.
                                            What I will be replacing with what : (planned)
                                            Soltek Golden ::
                                            4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                            6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                            01-18-2025, 11:44 AM
                                          • matthewmcconaughey
                                            I need help with my friend Sony GDM-FW900 24” CRT
                                            by matthewmcconaughey
                                            Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                                            I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                                            1. It started with a bright and greenish picture upon starting a cold monitor.
                                            2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                                            05-16-2023, 03:15 PM
                                          • Jackching
                                            Intel PC hooked to X90L television picture cut-off
                                            by Jackching
                                            I have my Intel PC hooked to my Sony X90L television and each time the power is cycled on the tv, the bottom of the PC screen gets cut-off. Only half of the taskbar shows until i go into display settings and cycle the display size and it'll work fine until the next time I power off the tv. I updated the drivers. The graphics is UHD 630.
                                            10-27-2024, 11:43 AM
