Thorn 65thl4kst1
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Thorn 65thl4kst1
    Connection or disconnection of any cables should always be done with the set powered off.
    The flat ribbon cables all have some form of clamping mechanism.
    The one in photo 1 of 2 above is to press in both sides of the connector, ie on the left and right side of connector which should release the connector allowing you to withdraw it without damage.
    Other than the backlights being on do you have sound or does the set respond in any way to the remote.
    • viewerau
      • May 2020
      • 305
      Hi
      I cannot hear any sound. The remote blinks to all the buttons, and the tv accepts the remote signals.
      Using the remote and pressing volume up I hear no hiss from the inbuilt speakers, or no indication/ flicker on screen changing channels/inputs etc.
      Signature:Seemingly hopeless tv fixer
      • viewerau
        • May 2020
        • 305
        Any more tips please?
        • viewerau
          • May 2020
          • 305
          Hi again...I'm wondering if I have placed this assistance post in the correct area, or if I should post it elsewhere?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            No, you have the right area but I am out of idea's. However there is the chance that others who may read this post can offer you further advice.
            • viewerau
              • May 2020
              • 305
              Thanks Dick .
              • viewerau
                • May 2020
                • 305
                • viewerau
                  • May 2020
                  • 305
                  I've determined that the telly has sound.
                  By the way, I just found this video, and although it is a different brand name, the symptons are all the same.
                  https://www.youtube.com/watch?v=SPLl...el=TightWadDIY
                  Lastly, the tcon board in Australia is here at this price
                  https://www.ebay.com.au/itm/254960031156
                  But I can get it at this much lower price from AliExpress
                  https://www.aliexpress.com/item/4000...archweb201603_
                  With my unprofessional eyes, I cannot see any difference between the original board, and the China one...all the numbers match up.
                  Is it worth trying a new T-Con board, or has what I have posted already, give any indications that my problem could be something else?
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    The pictures are not that good to do a miniscule comparison but they do look the same.
                    Have you checked that you have voltage on the tcon fuse both sides. It may be that the Tcon voltage is missing.
                    I would check that first before replacing the board.
                    • viewerau
                      • May 2020
                      • 305
                      Have you checked
                      Not good with a multimeter...don't know what to set it to, where the fuse is, and whether power should be on/off when checking.
                      Mine is an old meter, no sound either.
                      • viewerau
                        • May 2020
                        • 305
                        better picture
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #32
                          Turn your dial anticlockwise to 20 (10 O'Clock) and place red probe on the fuse and black probe on chassis. Power on the set.
                          Check the voltage read on the meter when you place the red probe first on the one point the arrow marks and then for the second point the arrow marks.
                          • viewerau
                            • May 2020
                            • 305
                            Thank you Dick...I REALLY REALLY appreciate the help.
                            It is dark now and the telly is in the back shed. I will do the check 1st up in the morning and report back with my findings.
                            THANK YOU
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #34
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                #35
                                Originally posted by viewerau
                                better picture
                                Better photo. Thanks
                                • viewerau
                                  • May 2020
                                  • 305
                                  Hi Dick,
                                  Sorry to be slow, however, both sides of the fuse gave a read out of 1983
                                  Does this help anything?
                                  EDIT...I also note that there is a blue led light on the main motherboard, that indicates it is also receiving power ok
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #37
                                    The reading with the power on should be around 12V dc. I do not know what the 1983 reading indicates. also you should have given two readings?
                                    • viewerau
                                      • May 2020
                                      • 305
                                      1983 was the reading on my Meter when checking both ends of the fuse
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        #39
                                        So you did the test with the red meter probe on one end of the fuse and the black meter lead on the chassis with the set powered up and then repeated with the red probe on the other end of the fuse?
                                        • viewerau
                                          • May 2020
                                          • 305
                                          Exactly as you advised me to
                                          I will repeat the test again and report back again.
                                          • Geeker007
                                            Friend messed up my laptop motherboard while working on my bench
                                            by Geeker007
                                            Hi All,
                                            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                                            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                                            I have not tried putting...
                                            06-16-2025, 01:40 PM
                                          • qwerty99
                                            Xbox 1.6 Motherboards and Polymer Capacitors
                                            by qwerty99
                                            Hello!
                                            I need to change the capacitors on my three original Xboxes.
                                            Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
                                            The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
                                            The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
                                            I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
                                            06-26-2022, 12:53 AM
                                          • Foetuss
                                            Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                            by Foetuss
                                            Hi all
                                            Hope this is in the correct place.
                                            I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                            Could use some double checking to see if I'm not doing something stupid .
                                            Pictures of the boards are attached.
                                            What I will be replacing with what : (planned)
                                            Soltek Golden ::
                                            4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                            6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                            01-18-2025, 11:44 AM
                                          • matthewmcconaughey
                                            I need help with my friend Sony GDM-FW900 24” CRT
                                            by matthewmcconaughey
                                            Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                                            I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                                            1. It started with a bright and greenish picture upon starting a cold monitor.
                                            2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                                            05-16-2023, 03:15 PM
                                          • Jackching
                                            Intel PC hooked to X90L television picture cut-off
                                            by Jackching
                                            I have my Intel PC hooked to my Sony X90L television and each time the power is cycled on the tv, the bottom of the PC screen gets cut-off. Only half of the taskbar shows until i go into display settings and cycle the display size and it'll work fine until the next time I power off the tv. I updated the drivers. The graphics is UHD 630.
                                            10-27-2024, 11:43 AM
