TCL 55C803 - Powers on, good picture, then shuts off
  • R_J
    • 9535
    Re: TCL 55C803 - Powers on, good picture, then shuts off
    The cathode of the diodes is the side with the white band. The voltages can't be correct if you are getting the backlights to flash on for a moment. This voltage should be a lot higher
    If the anode of D630 goes above 1.7vdc it tells the U601 backlight driver to shut down.
    • jason123
      • Oct 2015
      • 1060
      Yes but its a very fast turn on then off the voltage doesn't register on the dmm before it shuts off.
        What did you use for ground for the meter?
        • jason123
          • Oct 2015
          • 1060
          I used the GND pins on one of the edge connectors on the cold side. Tried multiple GND points on the cold side and same results
            Must be very very slow DMM.
            • jason123
              • Oct 2015
              • 1060
              the flash of the backlight, is very quick I think .. DMM doesn't have a max hold feature unfortunately. What is this saying though? I tested the diodes between the transformers and backlight.. caps seem ok.. anything I can try??
              • jason123
                • Oct 2015
                • 1060
                Anyone with Schematics for this board so I can understand how it works?
                40-L14H4-PWG1CG
                08-L141W54-PW210AB
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  40-L14H4-PWG1CG
                  08-L141W54-PW210AB
                  I think you've missed a digit and it's a 40-L141H4-PWG1CG.
                  • jason123
                    • Oct 2015
                    • 1060
                    Thank you.. Yes, I did miss a digit
                    • jason123
                      • Oct 2015
                      • 1060
                      Ok, general question here for those who know TCL TVs well. This PS came out of a 55C803 TV. It's configured for 4 CH, from what I can see on the schematic. Would you expect the LED1, 2, 3 and 4 paths on the connector to the LEDs to have wires coming out of them? Trying to understand the 2 CH, vs. 4 CH reference on the Schematic.
                      I got a replacement PS board, and the TV is buttoned up, working fine. I'm testing this PS board on 55S403 setup with the original PS set for 2 channel. So it makes sense that this PS in the 55S403 wouldn't work, right? since 55S403 is a 2-CH setup and this board is configured for 4-Ch
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • sergio_av
                        Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                        by sergio_av
                        Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                        Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                        When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                        Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                        01-01-2025, 05:27 PM
                      • KYBOSH
                        Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                        by KYBOSH
                        Saved this beast from the landfill this weekend.
                        Manfactured July 2013 in Mexico.
                        I love working on plasma TVs.
                        Its been a while but I was lucky enough to find 2 this week.
                        The TV powers on and stays on but no picture. Havent checked for sound yet.
                        No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                        Will start troubleshooting tonight.
                        10-17-2024, 01:17 PM
                      • lowpost99@gmail.com
                        Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
                        by lowpost99@gmail.com
                        I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
                        09-03-2024, 02:57 PM
                      • Tr0ll
                        by Tr0ll
                        Original T-con:
                        First replacement T-con:
                        10-07-2023, 07:48 PM
