I can't find anything in the service menu that allows me to flip the screen. I've included a picture of the tcon incase theres a jumper or something.
Westinghouse WD40FW2610 replaced tcon now screen is upside down.
Re: Westinghouse WD40FW2610 replaced tcon now screen is upside down.
upload photo for the original T-CON, try to located the SPI on it and compare it with replacement one.. could be the t-con for different model.
i think this TV had mainboards All in One. if you can find firmware to downgrade or upgrade could help too -
The spi flash? I had a mishap that left it inoperable.Comment
I managed to dump the eeprom from the new tcon, I don't know how to change anything though.Attached Filesif you find these attachements useful please consider making a small donation to the site
again... dump the original T-con and compare it with the new via HEX editor, or you can flash the old on the new one.Comment
by Daren87Hello everyone,
I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the... -
by ChrissygizmoHi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
Ive eventually managed to get it on and working but it's very temperamental...
The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...05-26-2024, 12:05 AM -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by Yehuda170original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
with original broken screen i can see in device manager touch screen in human interfaces
but with the new screen it's not showing in device manager
is it lenovo blocking it? is it driver missing?
I²C is a headache -
by alltvrepairsHi,
i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
Appreciate your help....2 Photos - Loading...
