Westinghouse WD40FW2610 replaced tcon now screen is upside down.
  • MikeRWK
    • Jun 2017
    • 121
    I can't find anything in the service menu that allows me to flip the screen. I've included a picture of the tcon incase theres a jumper or something.
  • Diah
    • Feb 2013
    • 6374
    Re: Westinghouse WD40FW2610 replaced tcon now screen is upside down.
    upload photo for the original T-CON, try to located the SPI on it and compare it with replacement one.. could be the t-con for different model.
    i think this TV had mainboards All in One. if you can find firmware to downgrade or upgrade could help too
    • MikeRWK
      • Jun 2017
      • 121
      The spi flash? I had a mishap that left it inoperable.
      • MikeRWK
        • Jun 2017
        • 121
        I managed to dump the eeprom from the new tcon, I don't know how to change anything though.
        • Diah
          • Feb 2013
          • 6374
          again... dump the original T-con and compare it with the new via HEX editor, or you can flash the old on the new one.
          • MikeRWK
            • Jun 2017
            • 121
            I already said I dont have the original anymore.
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • Chrissygizmo
              samsung galaxy ao2s very temperamental after screen replaced
              by Chrissygizmo
              Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
              Ive eventually managed to get it on and working but it's very temperamental...
              The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
              05-26-2024, 12:05 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • Yehuda170
              ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
              by Yehuda170
              original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
              replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
              now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
              with original broken screen i can see in device manager touch screen in human interfaces
              but with the new screen it's not showing in device manager
              is it lenovo blocking it? is it driver missing?
              I²C is a headache
              07-14-2023, 01:29 AM
            • alltvrepairs
              Lg TCon test pins for screen test
              by alltvrepairs
              i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
              Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
              Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
              Appreciate your help....
              06-13-2025, 06:33 AM
