ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
  • Yehuda170
    • Jan 2015
    • 34
    • Israel
    original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
    replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
    now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
    with original broken screen i can see in device manager touch screen in human interfaces
    but with the new screen it's not showing in device manager
    is it lenovo blocking it? is it driver missing?
    I²C is a headache
  • mon2
    • 14666
    Re: ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI men
    Check if you have a secure boot option in your bios. If yes, disable it and boot again.
    This setting, if ON, will prevent new hardware from being enumerated.
    • Yehuda170
      • Jan 2015
      • 34
      • Israel
      disabled secure boot, didn't helped
      touch only works in bios menu
      • mon2
        • 14666
        See if this helps:
        https://pcsupport.lenovo.com/us/en/p...ror-windows-10
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • Gabriel Lucas
          microsoft surface pro 5 touch screen not working
          by Gabriel Lucas
          Hello everyone, I bought a Microsoft Surface Pro 5 and the touch doesn't work. According to what the previous owner said, the screen stopped working after an update. The screen has no physical damage, and the touch works for 1 second when it turns on and then stops working. I've tried updating the drivers, formatting, and returning to factory defaults, but nothing worked. Can you help me?
          02-18-2025, 09:24 AM
        • nejib01
          Asus et2002t touch screen issues
          by nejib01
          Hi , i get an old Asus et2002t touch screen , everything go good but i have geometric surfaces not responding touch (red colored bad surfaces , see image uploaded) , any help
          Thank you in advance...
          09-09-2025, 09:13 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
