Sony KDl-70R550A bad screen or backlight??
  • a460guy
    • Oct 2013
    • 59
    • it's
    Hopeing someone can look at these pics and tell me if this is a fixable issue. Thanks!
  • Wilderone
    • May 2018
    • 76
    Re: Sony KDl-70R550A bad screen or backlight??
    Seeing as this model is edge-lit it would seem one or more of the LED's have shorted.
      • 12332
      • U.S.
      The third picture doesn't have the darkness, so it isn't there all the time, correct?
      • a460guy
        • Oct 2013
        • 59
        • it's
        if the picture is bright and lots of color it is barely visible...but when there are dark colors it is very apparent.
          • 12332
          • U.S.
          Could be a tab bond issue.
            • 12332
            • U.S.
            Example there, if a little pressure applied to the tab bond clears up the picture then you may be able to shim it: https://www.youtube.com/watch?v=vCExlSnG4yY
              • 12332
              • U.S.
              Another example there with a sanyo, I did one a while back for myself, I only did the bad tab and only shimmed one side, NorCal did a thorough job on it there: https://www.youtube.com/watch?v=purk_SyiT44
              • HTR-Informatique
                by HTR-Informatique
                02-09-2025, 06:51 AM
              • frannyjunk
                Hisense 40H4F no backlight but turns off after splash screen
                by frannyjunk
                So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                TIA.
                09-24-2025, 10:59 AM
              • turmix
                AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                by turmix
                Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                During another reassembly, I made a mistake, and...
                01-29-2024, 03:48 AM
              • FallenOne008
                Asus G712L No Screen Backlight
                by FallenOne008
                Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                03-31-2025, 08:27 PM
              • Audeze
                Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                by Audeze
                I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                Does...
                10-06-2024, 08:54 PM
