Hisense H55A6500UK logo loading then black screen
    I have an issue with my tv and was wondering if anyone has had a similar issue and could advise me.
    As stated its a hisense H55A6500, when you power on the logo loads, dissapears then black screen stays, it seems to flicker and a small line appears moving around the screen as it flickers sometimes 1cm long sometimes a few inches and sometimes none.
    I have to pull the plug to turn it off as buttons are unresponsive.
    Feels like a corrupt firmware maybe to me. I have contacted hisense but no replys as of yet two days later. Only file for this model i can find is a russian version, if anyone has the file so i could try it that would be amazing.
    I have found two other people who had the exact same model and issue i have messaged them to see if they had a fix for the problem, One in a post said he went as far as replacing the power supply, tcon and main boards but the issue remained and he tried flashing the firmware but could not get it to load.
    I have opened it up and inspected the boards for damage or bloated caps but nothing obvious.
    The logo loads and then seems to glitch. Leans me towards firmware but im a novice
    Really appreciate any information.
    Re: Hisense H55A6500UK logo loading then black screen
    show us photo on the first screen logo startup
      Sorry if its a little dark.
        why dont flash the Russian one? Hisense firmware are for all region.. because from service menu can be changed if needed
          the one on 4pda suitable to all..
          version 1: UWTS all region
          HE55A6500UWTS_Hisense_E013_I0625.zip password: F2HW
          unzip until you have the last file in .pkg format, copy it on USB stick formatted with Fat32, insert it at any USB2 on tv. not usb 3 blue color while the tv plugged out from wall socket. press on RC power and keep pressing while you plug it in wall socket again.
            Thank you for your help.
            I just followed your instructions with your file but i cannot get anything to come up. I extracted it to the last file and out it on a formated 16gb usb in the not blue socket. When i hold the power button on the remote and then plug it in the tv wont power on unless i repress the button?
            I tried the other usb and using the tv button just incase but no luck. When it does come on it loads the logo then black screen that flickers
              let us clear one things..
              now with out any usb inserted in the tv..... when you plug the tv in wall socket did it start direct and it show the logo you posted over here?
                Yes if i plug it in and press the power button on either the remote or tv inself the logo loads, dissapears and a black screen follows that flickers with the occasional line horizontally. Same with the usb in
                  wrong this mean your TV was in standby mode...
                  1- the TV must hard OFF. mean when the TV display the logo, take it out from wall socket ( dont press power) so next time when you plug it in wall socket, it will start direct with out need to press power on remote or on tv.
                  2- your computer should shown at file option to show file extenstion and all hidden file. so you will be sure if you format the usb fat 32 will be realy empty no other file like system information... which windows great it... and to show the extension of file so you will be sure the file will have only one end .pkg not double .pkg.pkg
                  3- some USB stick they are not MBR style after formatting
                  if all points 1.2.3 correct... just plug the usb and press power on remote .. keep pressing then plug the tv in wall socket... as soon it will show upgrade screen remove yours finger from remote power....
                    Ok so i double checked everything.
                    1. Before i start every time the tv is unplugged from the wall.
                    When its on it wont respond to turning off at the button or remote control so this is a hard off right? Im a little confused.
                    2. I have checked hidden files and extentions and its as it should be
                    3. The usb is in MBR i checked in the partitions.
                    Its the same when i try.
                    Tv is not plugged in, usb in the not blue slot. Hold the power button on remote, plug into the wall still holding. Wait 30 seconds and the tv has not powered up just the red lights on.
                    If i press the power button again it will now load
                    I never get an upgrade screen
                      let do it in other way..
                      now do only what i wrote but answer me quickly as its late to me
                      1- let the TV solo nothings plug in any source such cable or hdmi.. only the tv set.... plug it in wall socket and tell me what do you have on the front led indicator and on screen
                        Everything has been removed from the tv when i have been trying.
                        Just the power cable. First photo is the led when plugged into the wall and nothing on screen.
                        Second picture is the logo appearing when i press the power button on remote.
                        Third picture is when the screen goes black after the logo.
                        Fourth is a picture of the lines that appear after, they move in flashes sometimes none sometimes tiny sometimes longer ect
                        Thank you for your time.
                          first picture mean your TV last state Standby... i send you PM answer me there
                            explain of Hard OFF & Stand by via last state option.
                            1- when the tv powered on and then pressing power on remote or on tv power key.. it will go to standby.. this mean if the set was in standby and you plugged out the tv from AC wall socket and later plugged it in at wall it will start as the last state in standby.
                            2- if you plugged out the tv from wall socket during the the Tv was powered on... any time you plug the set in wall socket it will start direct.. this is Hard OFF and this mode we need the set at it to apply flashing the firmware steps i explained early.
                              All Hisense Firmware from Customer Service
                              To all owner of Hisense here are the customer service Firmware archive
                              Password : Hisense1234
                              enjoy
                                Just to clear the result on this issue, which i didn't saw before.
                                following with him on other source contact , it come out he had flickering LED backlight. which they drop the 12V to main.
                                the owner didn't have any voltmeter or parts to use in order doing test.
                                with simple method, the BL are tow groups Only, each with LED+ & LED-
                                with test by unplug the LED- from sockets resulted one group was Open.
                                so what we can use.. and he didn't have either Resistor to test with and to avoid taking the panel apart as its 55 and could cracked under his hand ???
                                used Normal table lamp with filament lamp connected in series between LED- Open Group and the pins on the socket... TV started and can downgrade or update firmware.. but it remain reboot at normal screen starting... as i think the 12V remain not stable, but by upgrade and downgrade it show the process.
                                any repair shop owner in UK near to his place if they can offer repair the open LED to him.
                                  I just fixed one of them mine had the pulsing backlights flickering screen with the oldd white horizontal line appearing randomly, and on measuring voltages they seemed to pulse too.
                                  I thought it was the mainboard as once the logo came and went and backlights were pulsing I couldn’t turn off by the remote, it was like blocked out.
                                  It still did it, so I replaced psu and yes it still did it.
                                  Yes I was stupid not to test the backlights, one channel was o/c replaced one led and its now ok
                                    Having exactly same symptoms on exact same model TV.
                                    Any advice on removing the screen to replace leds?
                                    Lift screen from top or lift metal chassis from the rear?
                                    I know these larger screens are prone to easily breaking!
                                      I have exactly the same problem, the solution is to change the leds?
