Westinghouse WD55UDR101 bad picture goes black after a few minutes
  • MikeRWK
    • Jun 2017
    • 121
    TV will come on for a minute or so then go black, I have 12v coming into the tcon but the only test pads with voltage when this happens are 3.3v and 1.8v points, any of the points with higher voltage show 0 or close.
    When the tv is 'working' the voltages are reading higher than the points specify on pads with voltage higher than 3.3v. One point VSS2 should have been 11.6 when its 13.17v. The dc-dc converter pictured is fluctuating between 7-13v on the high side and a steady 1.18 on the low side.
    I'm looking for a firmware update to try first the board number is CV6488H-A.There should be a few brands with this board I know Seiki is one.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Westinghouse WD55UDR101 bad picture goes black after a few minutes
    If it has a tcon and you disconnect one ribbon cable going to the panel board do you have a clear half picture.
    It looks like you may well have a side tab issue problem seeing the multiple pictures being displayed.
    • MikeRWK
      • Jun 2017
      • 121
      I can only disconnect one side since the tcon is part of the screen on this model. It runs one side of the screen somewhat happily but the voltages still aren't stable. I've got it narrowed down to the driver ic, any voltages measured past that are wonky and the voltage to the ic is steady.
      I've ordered a new ic and a universal boost board, one way or another I'll fix it. Ignore the diode in the ic pic, I replaced it because it tested bad in circuit but was good once I measured it off the board.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Check for short circuit capacitors around the area you say the voltages are wonky.
        • MikeRWK
          • Jun 2017
          • 121
          I'm getting a short on all 4 of these capacitors only one way though.
          • MikeRWK
            • Jun 2017
            • 121
            With the tv on and the picture working they all read 1.17v I think it should be 3.3v. The 6R8 below the capacitors is hot to the touch.
            • MikeRWK
              • Jun 2017
              • 121
              Now after having the tv unplugged for a while the 4 caps aren't shorting, I fire it up for a minute and I tested immediately after shutting the tv off and they're shorting.
              Turns out they would read as shorted with the tv on standby but not with it unplugged.
              • Diah
                • Feb 2013
                • 6376
                Originally posted by MikeRWK
                Now after having the tv.
                do you have combo board all in one as main?
                • MikeRWK
                  • Jun 2017
                  • 121
                  It's got separate power main and tcon. The tcon is part of the screen like most chinese tvs. The main board is cv6488h-a
                  • Diah
                    • Feb 2013
                    • 6376
                    LOL.. so its all in one boards ( one board and panel ).. label cv6488h-a are nothings to me if you were not able to upload focused high resolution photo on the boards.
                    • MikeRWK
                      • Jun 2017
                      • 121
                      No , it's not an AIO board.
                      • Diah
                        • Feb 2013
                        • 6376
                        same story.. friend..
                        CON202 BL/ON measure it with ref to chassis let know the voltage while set plug in and picture out
                        • MikeRWK
                          • Jun 2017
                          • 121
                          I get 38mV on standby, 4.53V with tv on and screen working. I reseated the con202 and con201 connectors on the power board side and so far the tv is working but the tcon seems to be going between perfect picture and ghosting.
                          So I reseated the connectors on the main board side then the tv wouldn't come out of standby. I moved the connector pictured and this wire comes out along with another I secured them back into the connector but I might solder the wires directly to the board.
                          So the tv stays on now and the tcon is still a problem. It will start ghosting when I change channels but it stop after 10-15 seconds.
                          • Diah
                            • Feb 2013
                            • 6376
                            i dont think you have to worry on the t-con. focus on the mainboards .. try log in service menu to find option for hard reset the eeprom.
                              • 12199
                              • U.S.
                              If you can, go into settings and turn the backlights NOT brightness down, see if the "ghosting"/double image goes away or lessens, also turn any screen enhancements that might be on off, in settings, ambient sensors shit like that if equipped.
                                • 12199
                                • U.S.
                                I hope you found this tv at the curb or such, seems like mostly bad reviews:
                                https://www.canadiantire.ca/en/pdp/w...-3991291p.html
                                  • 12199
                                  • U.S.
                                  While you're at it, take the connector pictured in post #13 off both boards and check each wire from end to end for continuity, be careful not to stretch out the terminals with meter probe ends and check for burnt or discoloration of the connector ends.
                                  • MikeRWK
                                    • Jun 2017
                                    • 121
                                    Can you get into the service menu with a universal remote? Do you know the procedure the one I used says to hold vol- and input then press power. The tv won't do anything if I use the physical power button while holding those and it just turns on normally if i use the remote.
                                    I turned them down to 50, no difference.
                                    It was free.
                                    I removed the connector and soldered the wires directly to the board and glued them. There was no signs of burning or heat, the connectors are so cheap the terminals fall out of them and are loose even when they're properly assembled.
                                    • MikeRWK
                                      • Jun 2017
                                      • 121
                                      I found these 2 capacitors to be shorted, but most interesting I found this solder blob on the board that I'm 99% sure didnt come from me.
                                        • 12199
                                        • U.S.
                                        Ok, now you're getting somewhere, straighten out that blob, then see if the caps still read short, if still short remove one and test it, then test the other one while it's still on the board, one bad cap can make the others read short.
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • kerberos137
                                          Sony xbr-65x930e faded to black; now has backlight but no picture
                                          by kerberos137
                                          Hopefully someone can help me out. This tv was working perfectly until a few weeks ago. At some point, the TV just faded to black, but sound continued playing. It almost looked like smoke on the screen as it faded from the bottom left corner toward the top right. Took only a second or less, but wasn't instant. After restarting, it turned back on and worked fine for another day or two. Then it happened again more or less the same way, but in a slightly different direction, again with sound continuing. I thought it was working fine after another restart, but looked a bit dimmer than before. Then...
                                          11-29-2022, 05:40 AM
                                        • S14Sr20det
                                          Nec E557Q lines and fade to black picture FIXED
                                          by S14Sr20det
                                          Trash picked this tv from a local business, had a garbage image and would fade to black within second then cut off. It would get shorter and shorter every time.
                                          Narrowed it down to the right side of the panel by unplugging half the t con
                                          One side had a great picture the other was black and distorted still.
                                          Down to the buffer boards… found yet another set of two esd diode arrays. One leg had a 60 ohm short to ground and would get lower the more attempts made to turn the tv on.
                                          Soldering iron and some chip quick knocked both of them off and...
                                          06-17-2023, 02:55 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • EazyBone
                                          Element E4AA70R black screen shows picture
                                          by EazyBone
                                          On this TV I got black screen with with picture.
                                          Tested the LEDs and they work.
                                          Had a hunch that this was similar to a ONN tv thread I found and wanted to post about this to possibly help someone else.
                                          The capacitor by the LEDs is bulging, 450v 10 uf. I suspect this is the cause. Will post results after replacing the capacitor. You could just replace power board as well I assume.
                                          https://www.badcaps.net/forum/showthread.php?t=110615
                                          Will post results when capacitor arrives...
                                          10-13-2023, 05:07 PM
