Soniq S49VT15A-AU stuck in standby
  • jazzeddie1234
    • Dec 2020
    • 11
    TV standby light is on but no response to remote or side buttons.
    I measure +0.23 on the +5SB pin (8 from top) and +5.2 on PS/ON (9) and nothing on other pins.
    There is 323v across the big cap on the hot side.
    I included pics of both sides of the PS, main board and of both together.
    Any suggestions greatly appreciated
    • 12152
    • U.S.
    Re: Soniq S49VT15A-AU stuck in standby
    Seems strange, unplug tv from power, unhook cable from powerboard to mainboard leave it unhooked, plug power cord back in, see if your 5 volt standby is there and steady.
    • jazzeddie1234
      • Dec 2020
      • 11
      My mistake in counting pins. 5.2V on the +5SB pin and I get 3.3 on the regulator on the main board next to the socket with the yellow and white wires
      • Diah
        • Feb 2013
        • 6363
        it sound there are no signal goes from Mainboards SPI flash to turn on the powerboards... locate the SPI Flash and freeze it with air cooler spray.. then try to turn on...
          https://www.badcaps.net/forum/attach...1&d=1611739562
          So what DCV do you have on PSON, BKON, ADJ with ref to cold circuit ground (SG GND)?
          • jazzeddie1234
            • Dec 2020
            • 11
            Ps/on 0.23v
            bk/on 0v
            adj 0v
              • 12152
              • U.S.
              Do you get those readings while in standby/tv plugged in but off AND when you hit power on?
              • jazzeddie1234
                • Dec 2020
                • 11
                Yes
                • Diah
                  • Feb 2013
                  • 6363
                  test the voltage on PIN1 & 8 on the SPI Flash IC , and write its label No of the chips
                    https://www.badcaps.net/forum/attach...0&d=1611739562
                    There are many 3-pin LDO Voltage regulators on the main board that you should at least check the Voltages on all 3 pins with ref to ground just to be sure they are OK.
                    I.E. I see at least two of them by the connector that goes to the power supply board, I cannot read the IC designators because it the picture is not clear enough for me to read.
                    • jazzeddie1234
                      • Dec 2020
                      • 11
                      Which one is likely to be the spi flash? And what test method - standard voltmeter ok?
                      • jazzeddie1234
                        • Dec 2020
                        • 11
                        The 3.3 regulator close to the connector with the yellow and white wires is the only one with voltage. 5.2 in 3.3 out. Can I check the others in circuit for a short (if that is their failure mode)?
                          So other LDO regulator ICs, all show 0V input? You have more than two on that main board.
                          • Diah
                            • Feb 2013
                            • 6363
                            SPI flash 8 Pins Chip.
                            • jazzeddie1234
                              • Dec 2020
                              • 11
                              All the others show 0V on input and output. There are 6 I can see. Some are 3.3 and others adj
                              • Diah
                                • Feb 2013
                                • 6363
                                it sound yours knowledge about SPI Flash not enough , so before you diving deeper with LDO ..... let do it in easy way...you need to write back MbootUpgrade.bin and main firmware MstarUpgrade.bin
                                download the files from here.. read the Instruction.txt. your USB should formatted FAT or FAT32 and no more than 2Gb.
                                • jazzeddie1234
                                  • Dec 2020
                                  • 11
                                  Thanks. Finding a USB that small will be the next challenge. I guess I can repartition a larger one
                                  • Diah
                                    • Feb 2013
                                    • 6363
                                    i am not sure partition a large usb will be good idea.. just try the larger usb stick be formatted to fat 32 will be fine if you dont have any other files on the usb root.. some windows or pc system after formatting leave hidden file as information
                                    • jazzeddie1234
                                      • Dec 2020
                                      • 11
                                      No response from TV when pressing CH+ for 10sec and then standby on TV (not remote)
                                      Some new info. The user reports that the TV became progressively more difficult to turn on. Finally requiring multiple power disconnects.
                                      And I have located the only 8 pin chip next to the cpu
                                      • jazzeddie1234
                                        • Dec 2020
                                        • 11
                                        SUCCESS!!! I restored the usb to full size, formatted as FAT32, copied the firmware files, and the TV installed them.
                                        It is now working
                                        You guys are awesome!
                                        • Eggbert43
                                          Soniq E40S12A-AU Stuck In Standby
                                          by Eggbert43
                                          Hello everybody,
                                          My Soniq E40S12A-AU (Australia) won't stay on when coming out of standby.
                                          Upon the power button being pushed to come out of standby, the red standby light starts flashing, then the Cinavision splash screen appears for a brief second before screen going black, & within another ten seconds the TV goes back into standby; with a solid red light.
                                          I have tried flashing the original & new firmware but upon completion I get the same behaviour as above, with the addition of an audio chime I assume to be notifying me of a successful firmware...
                                          04-02-2021, 02:55 AM
                                        • Loagz
                                          Soniq S55V14B-AU Stuck in Standby
                                          by Loagz
                                          Hi, I'm hoping someone can point me in the right direction....
                                          I have a S55V14B TV and it suffered a board failure. Main board part number: 222-655036003-30. I couldn't find a board with the exact part number so I've used what looks to be the same board however the part number is slightly different. 222-655036002-30.
                                          After installing the main board the stanby light came back on, however it wont turn on. I spoke to Soniq Australia and managed to get a copy of the firmware but no service manual. They don't have one. I asked about the different part numbers but they...
                                          11-15-2021, 02:13 AM
                                        • lepak06
                                          TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                          by lepak06
                                          Hello
                                          I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                          The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                          Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                          All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                          But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                          01-12-2023, 01:43 AM
                                        • samsonn
                                          Soniq S55V16A-AU stuck in standby
                                          by samsonn
                                          I've got a 55" Soniq LED TV which is stuck in standby mode (initiator LED on, but no picture/sound/backlight). It will intermittently start working again for a few days or weeks, but it has been months since the last time it turned on. I've seen a lot of similar issues with Soniq TVs that were fixed by updating the firmware, but I need to turn it on to update the firmware so no luck there.
                                          I've taken the back off and visually inspected it but everything looks fine. No exploded capacitors or signs of overheating etc. All of the 1117 regulators on the main board were outputting...
                                          06-28-2020, 02:33 AM
                                        • toty79
                                          Hisense LTDN50K220WSEU stuck in standby
                                          by toty79
                                          Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                          As per Hisense tv title LTDN50K220WSEU stuck in standby
                                          PSU rsag.820.5687 HLL 4855WF
                                          Main rsag 7.820.5842
                                          I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                          05-01-2022, 04:39 PM
