Soniq S49VT15A-AU stuck in standby
  • Diah
    • Feb 2013
    • 6435
    Re: Soniq S49VT15A-AU stuck in standby
    so dont tell next time didn't work if you did some things wrong LOL.... enjoy
    • Eggbert43
      Soniq E40S12A-AU Stuck In Standby
      by Eggbert43
      Hello everybody,
      My Soniq E40S12A-AU (Australia) won't stay on when coming out of standby.
      Upon the power button being pushed to come out of standby, the red standby light starts flashing, then the Cinavision splash screen appears for a brief second before screen going black, & within another ten seconds the TV goes back into standby; with a solid red light.
      I have tried flashing the original & new firmware but upon completion I get the same behaviour as above, with the addition of an audio chime I assume to be notifying me of a successful firmware...
      04-02-2021, 02:55 AM
    • Loagz
      Soniq S55V14B-AU Stuck in Standby
      by Loagz
      Hi, I'm hoping someone can point me in the right direction....
      I have a S55V14B TV and it suffered a board failure. Main board part number: 222-655036003-30. I couldn't find a board with the exact part number so I've used what looks to be the same board however the part number is slightly different. 222-655036002-30.
      After installing the main board the stanby light came back on, however it wont turn on. I spoke to Soniq Australia and managed to get a copy of the firmware but no service manual. They don't have one. I asked about the different part numbers but they...
      11-15-2021, 02:13 AM
    • lepak06
      TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
      by lepak06
      Hello
      I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
      The TV is faulty with stuck in Standby RED LED. Can't power the TV.
      Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
      All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
      But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
      01-12-2023, 01:43 AM
    • samsonn
      Soniq S55V16A-AU stuck in standby
      by samsonn
      I've got a 55" Soniq LED TV which is stuck in standby mode (initiator LED on, but no picture/sound/backlight). It will intermittently start working again for a few days or weeks, but it has been months since the last time it turned on. I've seen a lot of similar issues with Soniq TVs that were fixed by updating the firmware, but I need to turn it on to update the firmware so no luck there.
      I've taken the back off and visually inspected it but everything looks fine. No exploded capacitors or signs of overheating etc. All of the 1117 regulators on the main board were outputting...
      06-28-2020, 02:33 AM
    • toty79
      Hisense LTDN50K220WSEU stuck in standby
      by toty79
      Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
      As per Hisense tv title LTDN50K220WSEU stuck in standby
      PSU rsag.820.5687 HLL 4855WF
      Main rsag 7.820.5842
      I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
      05-01-2022, 04:39 PM
