Lg oled65e6p-u.buswljr
  • rplewis
    • Sep 2015
    • 82
    Re: Lg oled65e6p-u.buswljr
    Originally posted by Diah
    1- discharge your body: naturalist yours hand by touching the TV chassis view seconds
    2- disconnect the sockets 12 &24V at t-con first followed disconnecting 2 LVDS then the 4 ribbon cable to panel
    3- put the replacements t-con in place and screw it
    4- connect the 4 ribbon first followed with 2 LVDS and at end 12 & 24V sockets
    5- plug back to wall if its didn't starting straight, ... use only ORG RC to power on.. let see what will you have on screen and measure carefully the 24V sockets
    plugged in wall.. TV went to STB. With original remote I pressed power button, heard relay on PS but no light on main board or 24 volt on 24 volt socket. I do have 12 volts on 12 volt socket and correct voltages on the PS to main board plugs.
    • Diah
      • Feb 2013
      • 6357
      do you have 24V on the mainboards socket ??
      did you checked the t-CON are same your original ?? compare with label no
      • rplewis
        • Sep 2015
        • 82
        I do have 24 volts on main board socket. The T-Con board looks to be the same as the original. All numbers are exactly the same.
        • Diah
          • Feb 2013
          • 6357
          unplug ut from wall and re plug.. if its start STB power it on with LG SRC power only... see if you have the mainboards turn on optical led indicator
          • rplewis
            • Sep 2015
            • 82
            Started in STB when I plugged in. Powered on with P-only on SRC. Heard the relay on PS but no lights on main board. Not in STB since I pressed P-Only on SRC.
            • Diah
              • Feb 2013
              • 6357
              how about the screen did it light dimm?
              • rplewis
                • Sep 2015
                • 82
                No... screen totally blank.
                • rplewis
                  • Sep 2015
                  • 82
                  Are you refreshing your screen or do you get notification when I respond?
                  • Diah
                    • Feb 2013
                    • 6357
                    i use refreshing,
                    we need back to first test you did..
                    turn off the set from wall socket..... disconnect the mainboards from powerboards and t-con.... do the first test you did before 3 bridge between 3.5V and PWR-ON / DRV-ON / 12VT_ON
                    then plug on and see what you will have on the screen.
                    • rplewis
                      • Sep 2015
                      • 82
                      i use refreshing,
                      Jumped everything like first time. Got 24 volts on 24 volt socket and 12 volts on the 12 volt socket. Nothing on the screen.
                      • Diah
                        • Feb 2013
                        • 6357
                        T-CON fuses of 12 & 24V are fine? i sent you pm
                        • rplewis
                          • Sep 2015
                          • 82
                          Fuses check good.
                          • Diah
                            • Feb 2013
                            • 6357
                            yours original T-CON better than this rubbish replacement.. but we do have other issue with panel maybe ... let see how we enclose this of 100%...
                            • rplewis
                              • Sep 2015
                              • 82
                              After much trouble shooting and with the help of Diah, we finally got TV working. It ended up being the main board. See attached photos.
                              • AK_777
                                Sony KD-65A1 Repair – 4 Red Blinks Error
                                by AK_777
                                Hi everyone!
                                I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                02-20-2025, 04:15 PM
                              • BakaMonogatari
                                LG 65UJ6300 no backlight unless TCON disconnected.
                                by BakaMonogatari
                                Full model of the TV is 65UJ6300-UA.BUSYLOR. TV was given to me by a relative as non-operational so I'm trying to get it working so I have a nice cheap upgrade for my living room. This is my first TV repair so if it sounds a little like I know what I'm talking about, I don't.
                                TV turns on and has audio, but backlight doesn't turn on. Getting 230v from LED+ to chassis. Also can't see anything with flashlight test. Another forum suggested I replace the LED strips because that's the most common failure on LG TV's and the flashlight test doesn't always show results.
                                11-04-2021, 12:36 PM
                                ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                09-07-2024, 04:30 AM
                              • maxim2511
                                LG 55EC930V OLED - swich on swich of no screen
                                by maxim2511
                                My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                Then I get an idea to take it apart and clean boards from dust.
                                In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                05-14-2021, 02:21 AM
                              • ugamazing
                                by ugamazing
                                12-17-2024, 07:05 PM
