Lg oled65e6p-u.buswljr
  • Diah
    • Feb 2013
    • 6437
    Re: Lg oled65e6p-u.buswljr
    Originally posted by Hink85
    If you log in service menu IN_START you will find the version of firmware of The ORG T-CON ( MICOM ), compare this info at time you have the replacements T-CON in place.
    • rplewis
      • Sep 2015
      • 82
      Hey Diah... I ordered the T-Con board and also an LG service remote control. I'll let you know when I get them.
      • Diah
        • Feb 2013
        • 6437
        good... if you received the T-CON before the LG SRC dont try to put in the set.. just wait for the remote to arrive
        • rplewis
          • Sep 2015
          • 82
          Ok... will do.
          Bye the way.. how are you getting the quote to be included in your reply post? The check box is grayed out on my screen.
          • Diah
            • Feb 2013
            • 6437
            Ok... will do.
            no idea.. you can ask the admin.
            • rplewis
              • Sep 2015
              • 82
              Diah.. While waiting on the OLED parts, let me ask a question about a Samsung I'm looking at. Model # UN55H7150AF. When I turn it on, the splash screen appears then goes to the apps screen. It stays on that screen for a min. then reboots. It's in an on/off loop it appears. Got any ideas?
              • Diah
                • Feb 2013
                • 6437
                it could be firmware corrupted or bad NAND chip sector
                for firmware issue :
                1 minute working its long windows time.. that you can during this 1 minute turn it off with RC to standby. from stand by log in service menu.. press in sequence
                Display/Info + Menu + Mute + Power when you are in service menu under "Option" you have there "Factory rest". choice it.
                BTW there is upgrade firmware for this set at samsung wen of date May 29 2020
                • rplewis
                  • Sep 2015
                  • 82
                  When I plug in TV the splash screen stays on for 2 sec. goes to app screen for 15 secs (not 1 min)goes black for 2 secs then back to the splash screen.
                  I tried the sequence you posted with no luck so I tried mute+1+8+2+power. I got in the Option menu and it stayed on for about 12 secs then went back to the loop. I couldn't move around in option menu at all. Is there a way to update firmware with TV doing as I describe?
                  • Diah
                    • Feb 2013
                    • 6437
                    now different story .. open new threat for this .. and upload photos on whole the back as well the mainboards and powerboards..
                    let yours photo focused and high resolution specially for the mainboards...to explorer the parts installed on it.
                    • rplewis
                      • Sep 2015
                      • 82
                      Hey Diah... Just posted new thread... Thanks for your help. Randy
                      • rplewis
                        • Sep 2015
                        • 82
                        Diah... got the T-Con board and a factory service remote. What's the next step?
                        • Diah
                          • Feb 2013
                          • 6437
                          on all original boards in place and sockets too... use the LG SRC to send Power Only.. and see the main boards turn on
                          • rplewis
                            • Sep 2015
                            • 82
                            Main boards did not turn on... no lights on board came on.
                            • rplewis
                              • Sep 2015
                              • 82
                              Tried again and heard relay on PS click, now there is a red LED on the main board. Checked voltages on PS... got all voltages except the 24 volt socket... it reads 1.231 volts
                              • Diah
                                • Feb 2013
                                • 6437
                                good so the mainboards wake up but still in protecting mode.. do the exact and report the result.
                                1- since you power on the set and you have the optical audio output led lid red... dont turn off the set with RC... just plug it off from wall socket.. and wait 10 seconds and plug it in wall.. tell if it turn on or not.. give time for the booting.
                                • rplewis
                                  • Sep 2015
                                  • 82
                                  No LED on main board. Didn't hear relay on PS. Did not use remote
                                  • Diah
                                    • Feb 2013
                                    • 6437
                                    so its now at standby????? if yes use original remote to turn on
                                    • Diah
                                      • Feb 2013
                                      • 6437
                                      please do only what i am asking you exactly.. and response here little faster
                                      • rplewis
                                        • Sep 2015
                                        • 82
                                        powered with original remote. LED on front is now out, the red LED on main board is on. All voltages on PS except 24 V socket. No image on screen panel.
                                        • Diah
                                          • Feb 2013
                                          • 6437
                                          okay...
                                          now we will try to reset the t-con "micom" firmware as we know from stand alone test it wasn't started and the main firmware too to clear all the previous errors you got before..
                                          while the set on, send with LG SRC IN-STOP follow it with 0 4 1 3 the set will goes to standby.. leave it in this STB state for at least 10 seconds then turn on the set FROM the SET POWER at the set ( Not from any RC ) give attention on the screen and test the 24V after it complete
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
                                          • BakaMonogatari
                                            LG 65UJ6300 no backlight unless TCON disconnected.
                                            by BakaMonogatari
                                            Full model of the TV is 65UJ6300-UA.BUSYLOR. TV was given to me by a relative as non-operational so I'm trying to get it working so I have a nice cheap upgrade for my living room. This is my first TV repair so if it sounds a little like I know what I'm talking about, I don't.
                                            TV turns on and has audio, but backlight doesn't turn on. Getting 230v from LED+ to chassis. Also can't see anything with flashlight test. Another forum suggested I replace the LED strips because that's the most common failure on LG TV's and the flashlight test doesn't always show results.
                                            11-04-2021, 12:36 PM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                          • ugamazing
                                            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                            by ugamazing
                                            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                            12-17-2024, 07:05 PM
                                          • maxim2511
                                            LG 55EC930V OLED - swich on swich of no screen
                                            by maxim2511
                                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                            Then I get an idea to take it apart and clean boards from dust.
                                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                            05-14-2021, 02:21 AM
