Lg oled65e6p-u.buswljr
  • rplewis
    • Sep 2015
    • 82
    Re: Lg oled65e6p-u.buswljr
    Originally posted by Diah
    okay...
    now we will try to reset the t-con "micom" firmware as we know from stand alone test it wasn't started and the main firmware too to clear all the previous errors you got before..
    while the set on, send with LG SRC IN-STOP follow it with 0 4 1 3 the set will goes to standby.. leave it in this STB state for at least 10 seconds then turn on the set FROM the SET POWER at the set ( Not from any RC ) give attention on the screen and test the 24V after it complete
    the SET POWER on the set is the main power button?
    • Diah
      • Feb 2013
      • 6436
      no lol
      its at the side panel of the tv or at the front it should be like joystick
      • Diah
        • Feb 2013
        • 6436
        if you dont find it now... use only the original RC to power on after In_STOP
        • rplewis
          • Sep 2015
          • 82
          no lol
          Yes... that's the one I'm referring to....LOL.
          • rplewis
            • Sep 2015
            • 82
            Just got back. Had a power outage right in the middle of our progress. I did the same as earlier to start TV.
            "powered with original remote. LED on front is now out, the red LED on main board is on. All voltages on PS except 24 V socket. No image on screen panel."
            Do I need to resume from what you said earlier?
            "while the set on, send with LG SRC IN-STOP follow it with 0 4 1 3 the set will goes to standby.. leave it in this STB state for at least 10 seconds then turn on the set FROM the SET POWER at the set ( Not from any RC ) give attention on the screen and test the 24V after it complete
            • Diah
              • Feb 2013
              • 6436
              of course you need to do this step..
              • rplewis
                • Sep 2015
                • 82
                nothing happening... acts like it doesn't recognize remote actions
                • Diah
                  • Feb 2013
                  • 6436
                  while its on plug it out from wall socket... wait 10 minutes then plug it back.
                  if it start at STB turn it on with Original RC.. wait it turn on then send INSTOP with LG SRC
                  • rplewis
                    • Sep 2015
                    • 82
                    no luck
                    • Diah
                      • Feb 2013
                      • 6436
                      no luck
                      what do you mean with no luck? set didn't start or you cant send instop???
                      • rplewis
                        • Sep 2015
                        • 82
                        My bad...LOL. It started in STB but didn't do anything when I pressed INSTOP with LG SRC remote.
                        • Diah
                          • Feb 2013
                          • 6436
                          i wrote to power it on with ORG RC if it start at STB then send instop .... waiting your result
                          • rplewis
                            • Sep 2015
                            • 82
                            I did start with original remote, forgot to say that in reply. Going to try it all again.
                            • rplewis
                              • Sep 2015
                              • 82
                              Unplugged from wall, waited 10 mins. Plugged back into wall and TV started in STB mode. Turned TV on with original remote. Pressed IN STOP on SRV remote. I didn't see any changes on TV and the voltage at the 24 volt socket is still 1.23 volts.
                              I'm assuming the TV is suppose to go back into STB mode when I press IN STOP?
                              • Diah
                                • Feb 2013
                                • 6436
                                did you put the code 0 4 1 3 after you send INSTOP ? LOL
                                • rplewis
                                  • Sep 2015
                                  • 82
                                  I did it all again.... but this time I entered code 0 4 1 3 after I pressed IN STOP on service remote. Still not seeing anything changing on TV.
                                  "Unplugged from wall, waited 10 mins. Plugged back into wall and TV started in STB mode. Turned TV on with original remote. Pressed IN STOP on SRV remote. I didn't see any changes on TV and the voltage at the 24 volt socket is still 1.23 volts."
                                  • Diah
                                    • Feb 2013
                                    • 6436
                                    ohhh man.... i am confused on your little focus on what i write & repair capabilities
                                    so please do exact next to avoid any dramatic end.. lets move forward to put the replacements T-CON in place.
                                    after unplug it from wall socket..
                                    1- discharge your body: naturalist yours hand by touching the TV chassis view seconds
                                    2- disconnect the sockets 12 &24V at t-con first followed disconnecting 2 LVDS then the 4 ribbon cable to panel
                                    3- put the replacements t-con in place and screw it
                                    4- connect the 4 ribbon first followed with 2 LVDS and at end 12 & 24V sockets
                                    5- plug back to wall if its didn't start straight, and use only ORG RC to power on.. let see what will you have on screen and measure carefully the 24V sockets
                                    • rplewis
                                      • Sep 2015
                                      • 82
                                      Sorry about the confusion. If you think I should try to do things again with original boards, I can and will. I'm not sure what I missing....LOL. I had to leave and come to town to take care of somethings so I'll be back this afternoon. Thanks for your patients!!
                                      Randy
                                      • rplewis
                                        • Sep 2015
                                        • 82
                                        OK... replaced T-CON exactly as you state... LOL.
                                        Waiting on next step.
                                        • Diah
                                          • Feb 2013
                                          • 6436
                                          5- plug back to wall if its didn't starting straight, ... use only ORG RC to power on.. let see what will you have on screen and measure carefully the 24V sockets
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
                                          • BakaMonogatari
                                            LG 65UJ6300 no backlight unless TCON disconnected.
                                            by BakaMonogatari
                                            Full model of the TV is 65UJ6300-UA.BUSYLOR. TV was given to me by a relative as non-operational so I'm trying to get it working so I have a nice cheap upgrade for my living room. This is my first TV repair so if it sounds a little like I know what I'm talking about, I don't.
                                            TV turns on and has audio, but backlight doesn't turn on. Getting 230v from LED+ to chassis. Also can't see anything with flashlight test. Another forum suggested I replace the LED strips because that's the most common failure on LG TV's and the flashlight test doesn't always show results.
                                            11-04-2021, 12:36 PM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                          • ugamazing
                                            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                            by ugamazing
                                            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                            12-17-2024, 07:05 PM
                                          • maxim2511
                                            LG 55EC930V OLED - swich on swich of no screen
                                            by maxim2511
                                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                            Then I get an idea to take it apart and clean boards from dust.
                                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                            05-14-2021, 02:21 AM
