SONY KDL 43w805c does not accept commands
  • Dobsuk
    • May 2020
    • 127
    • England
    #61
    Re: SONY KDL 43w805c does not accept commands
    OK, guys. I did not have to time to play with this board in the last days but i bought one 43w807c with faulty TCON board. I had one spare and swaped it and it is working now. But i took its main board and put in that 43w805c and it was working fine. So, defenetly the problem is with the mainboard. I am a bit worried to cook that MainBoard, Diah, thinking about the plastic parts on it.
    • Diah
      • Feb 2013
      • 6341
      we know the issue BGA on mainboards ...also i am always against the cooking method.. so my suggestion always hot air or infrared heating source to users lack with equipment's and rework BGA ball for SMT Chip.
      so you need self to choice which source you can applying heat to the chip from the top side with temperature ca 280 degree for not less than 6 seconds.
      • Dobsuk
        • May 2020
        • 127
        • England
        #63
        OK. I will go for the heat gun again.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          #64
          Diahs been smoking way too much man still to this day........
          • Diah
            • Feb 2013
            • 6341
            If the demons came, the angels should flee LOL
            • Dobsuk
              • May 2020
              • 127
              • England
              #66
              OK, guys. I tried few more times with the heat gun for different time but still nothing I think i am gonna burn this chip if i keep the gun for longer.....
              What if i leave it to work without the heat sink for longer? Just to overheat it on itself?
              • Dobsuk
                • May 2020
                • 127
                • England
                #67
                I think that i tottaly fucked up that board after the last heating
ID:	2060230Click image for larger version
ID:	2060231Click image for larger version
                It looks i will have to lookiing for new one and now the queston is can i use the same board model even it is from TV with different sceen size?
                This is the cheapest option which i found, the same board model but accordin the descripriong is from KDL-65W855C.
                • Diah
                  • Feb 2013
                  • 6341
                  [ATTACH]228435[/ATTACH][ATTACH]228436[/ATTACH][ATTACH]228437[/ATTACH]
                  still not fucked lol
                  why dont use cheap way to buy Liquid Soldering Flux for example RF800 its less 3$ and push it around the chip with cool air to go on all pins then heat it once? you can see many video online.
                    • 12075
                    • U.S.
                    #69
                    These may be compatible models, check the sticker numbers NOT the board numbers of any possible candidates:
                    KDL-43W756C, KDL-50W755C, KDL-55W809C, KDL-43W805C, KDL-43W808C
                    • Dobsuk
                      • May 2020
                      • 127
                      • England
                      #70
                      Oh mate. Thank you for your patience First of all i do not have cool air. But could you share me some youtube video with the exact procedure i need to do? Thank you.
                      • Diah
                        • Feb 2013
                        • 6341
                        the flux like water.. you try to let it reach all joint points under the chip. cool air i mean like hair dryer at cool step just we use the air pressure to let the liquid go further deep under the chip... then you heat it very well one time as you did before..
                        i am sure here many good users from UK will help you by where and what to buy and how to use as they used it before over this forum
                        • Dobsuk
                          • May 2020
                          • 127
                          • England
                          #72
                          Do you think it is still software issue mate? Watching the photos i think some resistor or something is fucked now arround the chip.
                          • Dobsuk
                            • May 2020
                            • 127
                            • England
                            #73
                            There is no sticker on my board
                            • Diah
                              • Feb 2013
                              • 6341
                              it sound you know there are some SMD parts fly out round the chips..LOL
                              good you did picture before at yours post #26 to compare
                              • Diah
                                • Feb 2013
                                • 6341
                                if there no parts fly out...
                                my last advice before you go to buy main boards.. be brave and head up forward your kitchen LOL .. heat your oven and let one flat oven plate at the middle.. and preheat the oven to 275 ( dont use air option. just the top and down heater ) after it reach the temperature place the boards on the plate ( put heavy weight on the chips so all joint point to be sure have contact to the base ) close the door.. wait 10 minutes then just turnoff the oven and open the door leave it on the plate dont move it until cooling down
                                • Dobsuk
                                  • May 2020
                                  • 127
                                  • England
                                  #76
                                  Not sure how to protect the plastic parts?
                                  • Diah
                                    • Feb 2013
                                    • 6341
                                    hand made cups from kitchen aluminum foil to cover them
                                    • Dobsuk
                                      • May 2020
                                      • 127
                                      • England
                                      #78
                                      OK, Diah i coocked the board today and i could not see anything at the first try. Then i preformed hard reset. After that i saw the Sony logo twice and now it looks it stucked on the self diagnostic mode:
ID:	2060872Click image for larger version
                                      Is that mean I've got some success or the main board is totaly fu.ked
                                      • Diah
                                        • Feb 2013
                                        • 6341
                                        still virgin SET LOL
                                        with RC can you put it in standby?
                                        • Dobsuk
                                          • May 2020
                                          • 127
                                          • England
                                          #80
                                          Nope...neither with the back panel buttons. Only can switch it on with the RC
                                          • crackedprint
                                            Sony HCD-HX80R Amplifier Volume Control Problem
                                            by crackedprint
                                            I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                            I have tried a Cold Reset as per the service manual.
                                            I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                            I have looked all the way through the service manual and tried many online...
                                            01-21-2025, 12:18 PM
                                          • karthur
                                            Vizio D65x-G4 Volume changes on its own
                                            by karthur
                                            On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                            It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                            06-05-2025, 08:13 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • Ruptor
                                            Sony MHC 6600 volume clicking
                                            by Ruptor
                                            Has anybody had the problem of the digital clicking from the volume control coming through the speakers. I guess the mute should activate as everything seems to have a mute from the analogue switch LC7822 to prevent output of stuff on the speakers but the mute circuits are really complex. The pcb is very badly manufactured as if it is over etched and not cleaned properly before being screen printed because I have fixed one fault but a wide track lifted off real easy with very little heat requiring extra repair. I dread touching the board so would like to go straight to the problem if someone has...
                                            05-21-2023, 05:32 AM
                                          • jason123
                                            Sony STR-DN1030 Distorted audio when Volume adjusted
                                            by jason123
                                            New to Audio equipment. Received this 7.2 Surround Sound system - had a blown channel and fixed that (0.22 ohm resistor, 2 transistors, and 1 100 ohm replaced)
                                            All channels now work. However, when I raise the volume with knob or remote, it doesn't work smoothly - you can heard distortion, and some speakers don't seem to work at max or somewhere in between..
                                            First thought was the actual audio switch - but then Remote volume control shouldn't have this problem, but it does.
                                            Second thought was the ribbon cable from front display to control board (V-Flex,...
                                            06-05-2022, 12:54 PM
