Sound and picture but no backlight
  • JCdes
    • Feb 2013
    • 91
    Re: Sound and picture but no backlight
    Top side
      There should be printing on the body of Q201.
      • JCdes
        • Feb 2013
        • 91
        A couple of posts back I said theres no voltage at gnd
        • JCdes
          • Feb 2013
          • 91
          D669 I think...
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            The argument has been removed, do not resume it.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • JCdes
              • Feb 2013
              • 91
              D669A is the part#
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #67
                They look like transistors. Data sheet.
                http://www.datasheetq.com/datasheet-.../Iscsemi/D669A
                • JCdes
                  • Feb 2013
                  • 91
                  I noticed there's 0v at d204
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #69
                    Have you check D204 with your meter set to diode mode?
                    JP8 whicjh is a 0 ohm resistor is on the other side of the board close to this diode. I would check that it hasn't gone open circiut.
                    I would check all the 0 ohm resistor in that area
                    • JCdes
                      • Feb 2013
                      • 91
                      Will do right away
                      • JCdes
                        • Feb 2013
                        • 91
                        Jp8, jp5, jp16 are all ok...
                        • JCdes
                          • Feb 2013
                          • 91
                          Got continuity both ways on d204 but then all resistors underneath do connect them. I would have to pull it out tomorrow to test it.
                            D204 has a bunch of low Ohms (2R20) resistors connected in parallel with it so it will show conduction in both directions.
                              BTW, are you getting the 380 ~ 400 VDC PFC Boosted Voltage on main filter cap EC101 ( measured between the two legs) when TV is turned on?
                              What are the Voltage rating of the caps EC11/12/201/202?
                                They are too cheap to use the typical MOSFET for the PWM control of the constant control (LOW side control).
                                • JCdes
                                  • Feb 2013
                                  • 91
                                  For ec101 I'm getting 376v, ec11 and 12 are 100uf 100v... 201 and 202 are 47uf 160v.
                                    OK, the PFC Boost Voltage is working.
                                    Next, meter set to 20Vdc, all connectors in place, black probe on the chassis, red probe on 1 of 3 pins of Q201 at a time then turn the TV on while watching the meter to see how high it goes up to then turn off the TV then repeat the same test on the other 2 pin of Q201.
                                    BTW, look at the spec sheet, post #67, of the Transistor so you can see which pin is Base and Emitter, middle pin is Collector (Connected to the Cathode of the LED string). Emitter is connected to resistor R244 (5R10), the other end of the resistor is then connected to circuit ground via D204//with resistors (R246/A, 247/A, 248/A) to complete the current path for the LED string, as you can see, the Cathode of the LED strings are not connected directly to circuit ground so if the transistors are not turned on then the LED strings will not light up.
                                    R212 (1K) is connected to the FB pin 5 of the IC to monitor the Vdrops on D204//with resistors (R246/A, 247/A, 248/A) for maintaining the constant current through the LED strings.
                                    BTW, what is wattage of the 100 Ohms resistor you have? We can use that to bypass the Cathode return of one of the LED string to circuit ground via 100 Ohms resistor just to find out if the LED string will try to come on or not.
                                    • JCdes
                                      • Feb 2013
                                      • 91
                                      I get 0 on pin 1, 0 on pin 2 and .64 on pin 3. Nothing changes when I turn it on. I can check the wattage on the resistors I got tomorrow.
                                        0.64V on pin 3 (Base) is on border line of Bias Voltage to run it on since the Emitter is connected to the Diode to ground.
                                        Can you put the 100 Ohms resistor to the middle (Collector) pin of Q201 or on the LED connector pin that goes to the middle pin of Q201, the other end of the resistor will be connected to the circuit ground (chassis), you should see the one of the LED string try to come on, just watch out for the resistor may be over heated but it is just for testing only. Do not leave the TV on for too long.
                                        • JCdes
                                          • Feb 2013
                                          • 91
                                          I can do that tomorrow. I got all the tools and goodies in my hobby shack outside the house. I'll do it and report back tomorrow. I really appreciate all the help. Resistor to center leg and to chassis right?
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • DKWS89
                                            Sony XBR 49x900E - Sound and backlight on but no picture
                                            by DKWS89
                                            Hey Guys,
                                            So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                            All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                            12-14-2023, 04:30 PM
