Sound and picture but no backlight
  • JCdes
    • Feb 2013
    • 91
    Re: Sound and picture but no backlight
    It has 5 led strips consisting of 14 leds each. I dont know the value of each led. The tester starts from 0v increasing the voltage to the strip and it lights up very dim at around 70v and stops increasing at 83v full brightness. Tried disconnecting the "adj" wire on the board and that did not work, just wanted to try and see if it made a diff.
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      are all led circuits same voltage on your tester ? must have connector unplugged from power board .
      if they are plug it back in and see if magic happened . dont know what it is with my tester but 2 sets still running after doing just that .maybe i got lucky . been a couple of months at least now .
      thinking about it though voltages from the supply and tester were not a lot different .
      • JCdes
        • Feb 2013
        • 91
        Yup all same voltage, same amount of leds on each strip. I did test unplugged from board.
          You have 5 LED strings and each string has its own Cathode return line through MOSFET Q201, 205, 206, 207, and 208.
          The red wires are the Anode wire for each string which are connected together and fed by one Boost converter.
          All connectors in place, set the TV to OFF, keep black probe on the chassis, red probe on any one of the LED+, then turn on the TV while watching the meter (meter set to 200VDC) to see how high it goes up to then wait 10 seconds to see how low it goes to, turn the TV OFF, the repeat the same test using the red probe on all 5 LED - pins at a time.
          • JCdes
            • Feb 2013
            • 91
            59.8 on stdby 62.4v turned on. It does spike to 72 for a second then back to 62, power off is back to 59.8. Same behavior on all connections.
            • JCdes
              • Feb 2013
              • 91
              While I was at it, I saw 0v at the leg closest to the backlight header, gnd in center and .5v at the other leg on all q201,207,205,208 and 206. Both stdby and on. R255 had 67 on one side and climbs very slow to 12 on the other, R239 had 0v on both sides. I made a messy picture of a few measurements. D1a and D1b had -0v on anode and 5 on cathode side when powered on. D204 has 0v at all times.
              • Diah
                • Feb 2013
                • 6355
                i think yours measurements points not as the points other suggested.. you need the measurements on the LED SOCKETS
                • JCdes
                  • Feb 2013
                  • 91
                  Those were taken at the led sockets, plugged and unplugged same results.
                  • Diah
                    • Feb 2013
                    • 6355
                    if so are you sure you got 59.8V when set on STBY ????
                    • JCdes
                      • Feb 2013
                      • 91
                      Yes
                      • JCdes
                        • Feb 2013
                        • 91
                        Stdby 59.8 and 62.4 turned on. When I turn it on it spikes to 74 after 6 seconds or so then back down to 62. Turn off then back to 59, unplug and slowly goes down to 0...
                        • Diah
                          • Feb 2013
                          • 6355
                          measure please the V on CON4 PL_ON pins when set on and STB
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            #33
                            Can you measure the voltage on the pins of U200. It may give some insight into what the problem could be.
                            • JCdes
                              • Feb 2013
                              • 91
                              I did measure that but cant remember if it was 4.9 I should have taken notes... I'll measure again when I get home. But it does go to 0 when turned off with power button.
                              • JCdes
                                • Feb 2013
                                • 91
                                Will do... I guess I'll have to juggle a bit since it is under the board. Can I measure just plugged in to the wall or do I need all connections to make it more accurate?
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  #36
                                  I'm not sure what you mean by all connections.
                                  Are you able to turn the board over and rest it safely on an insulated pad to make the measurements.
                                  • JCdes
                                    • Feb 2013
                                    • 91
                                    All connection I mean main board and led plugs... Yes I have insulation...
                                    • JCdes
                                      • Feb 2013
                                      • 91
                                      On my way back... I'll post measurements in about an hour..
                                      • JCdes
                                        • Feb 2013
                                        • 91
                                        11.2 on leg 1
                                        4.6 on leg 8
                                        1.7 on leg 7
                                        6 on leg 6
                                        2,3,4,5 0v
                                        All cables connected
                                        • JCdes
                                          • Feb 2013
                                          • 91
                                          BL-On 4.8
                                          Adjust 4.9
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • DKWS89
                                            Sony XBR 49x900E - Sound and backlight on but no picture
                                            by DKWS89
                                            Hey Guys,
                                            So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                            All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                            12-14-2023, 04:30 PM
