LG service menu on a 55uh770v
  • adamp91gvm
    • Jan 2014
    • 706
    Hi all how do I get into the service menu on this tv using this remote I've tried a few ways but can not get in
  • Diah
    • Feb 2013
    • 6614
    Re: LG service menu on a 55uh770v
    LG had 2 kind of service engineering menu & one command for reset... all cant be access from your normal RC- need service RC or there on android apk can be used with any mobile set had build in IR
    so why you want to access to this menu?
    • adamp91gvm
      • Jan 2014
      • 706
      Screens flashing want to completely re boot it
      • adamp91gvm
        • Jan 2014
        • 706
        Think its Eprom error
        • adamp91gvm
          • Jan 2014
          • 706
          As per this pic
          • Diah
            • Feb 2013
            • 6614
            could be & could be other reason such LED BL..
            to reset eeprom and whole set to factory state need to send command IN_STOP following with code 0,4,1,3 we post over here many time apk for android or diy one on pc with .wave files
            • adamp91gvm
              • Jan 2014
              • 706
              I'll use my old samsung s5 and see if I can get it too work what's the best app
              • Diah
                • Feb 2013
                • 6614
                S5 would work perfectly search after Smart remote apk or lg service menu apk
                • alfatv
                  • Sep 2020
                  • 353
                  Anymote apk
                    LCD LED TV Service Menu Codes
                    ALL LCD LED TV SERVICE MENU CODES
                    Service Menu Code with Board Name
                    China Universal Board / Jumper Board Service Menu Code
                    Changhong Ruba Service Menu Code
                    Ecostar LED TV Service Menu Code
                    Orient LED TV Service Menu Code
                    Haier LED TV Service Menu Code
                    TCL LED TV Service Menu Code
                    Samsung LED TV Service Menu Code
                    LG LED TV Service Menu Code
                    Videocon LED TV Service Menu Code
                    Supra LED TV Service Menu Code
                    Toshiba LED TV Service Menu Code
                    Symphony LED TV Service Menu Code
                    Veste/ LED TV Service Menu Code...
                    10-31-2024, 03:58 AM
                  • Robby-Gr
                    TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                    by Robby-Gr
                    I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                    However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                    The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                    Additional issues:...
                    09-27-2025, 12:02 AM
                  • intercepter
                    JVC LT-32CA120 service menu
                    by intercepter
                    I have JVC LT-32CA120
                    Board:Vestel 17MB171
                    I need rotate screen.It is possible in service menu and how to enter service menu?
                    Thanks.
                    12-10-2024, 10:29 AM
                  • alltvrepairs
                    Jvc Lt-65VU3000 reduce backlight from service menu
                    by alltvrepairs
                    I have just replaced led set of this vestel tv due to age.
                    I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
                    Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
                    Thanks again....
                    09-20-2025, 05:03 AM
                  • sohail5307
                    I need how to open this Dell service menu option in dell latitude e6420
                    by sohail5307
                    I need to open service menu of Dell laptops like image in attachment
                    Ignore my English
                    I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
                    01-13-2023, 05:56 AM
