LG service menu on a 55uh770v
  • adamp91gvm
    • Jan 2014
    • 699
    Hi all how do I get into the service menu on this tv using this remote I've tried a few ways but can not get in
  • Diah
    • Feb 2013
    • 6363
    Re: LG service menu on a 55uh770v
    LG had 2 kind of service engineering menu & one command for reset... all cant be access from your normal RC- need service RC or there on android apk can be used with any mobile set had build in IR
    so why you want to access to this menu?
    • adamp91gvm
      • Jan 2014
      • 699
      Screens flashing want to completely re boot it
      • adamp91gvm
        • Jan 2014
        • 699
        Think its Eprom error
        • adamp91gvm
          • Jan 2014
          • 699
          As per this pic
          • Diah
            • Feb 2013
            • 6363
            could be & could be other reason such LED BL..
            to reset eeprom and whole set to factory state need to send command IN_STOP following with code 0,4,1,3 we post over here many time apk for android or diy one on pc with .wave files
            • adamp91gvm
              • Jan 2014
              • 699
              I'll use my old samsung s5 and see if I can get it too work what's the best app
              • Diah
                • Feb 2013
                • 6363
                S5 would work perfectly search after Smart remote apk or lg service menu apk
                • alfatv
                  • Sep 2020
                  • 353
                  Anymote apk
                    LCD LED TV Service Menu Codes
                    ALL LCD LED TV SERVICE MENU CODES
                    Service Menu Code with Board Name
                    China Universal Board / Jumper Board Service Menu Code
                    Changhong Ruba Service Menu Code
                    Ecostar LED TV Service Menu Code
                    Orient LED TV Service Menu Code
                    Haier LED TV Service Menu Code
                    TCL LED TV Service Menu Code
                    Samsung LED TV Service Menu Code
                    LG LED TV Service Menu Code
                    Videocon LED TV Service Menu Code
                    Supra LED TV Service Menu Code
                    Toshiba LED TV Service Menu Code
                    Symphony LED TV Service Menu Code
                    Veste/ LED TV Service Menu Code...
                    10-31-2024, 03:58 AM
                  • intercepter
                    JVC LT-32CA120 service menu
                    by intercepter
                    I have JVC LT-32CA120
                    Board:Vestel 17MB171
                    I need rotate screen.It is possible in service menu and how to enter service menu?
                    Thanks.
                    12-10-2024, 10:29 AM
                  • sohail5307
                    I need how to open this Dell service menu option in dell latitude e6420
                    by sohail5307
                    I need to open service menu of Dell laptops like image in attachment
                    Ignore my English
                    I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
                    01-13-2023, 05:56 AM
                  • Daniel Valdez
                    Samsung UN70RU7100K halfway bricked after messing with service menu
                    by Daniel Valdez
                    Dear All,
                    FAFO is the correct definition of what happened with my Samsung UN70RU7100K TV, I was trying to change the region to enable samsung plus using the service mode, entered the mode mute 1 8 2 pwr, and started to dig in. Did some changes while having digital TV signal in the back instead of doing it in HDMI standby mode, I remember changing to a region different then mine but also had a different tuner $%&!. After rebooting the TV, it was all gone, now it shows the splash image and then no image at all. If i disconnect the lan cable from the back, a message is shown in the...
                    12-06-2024, 06:56 PM
                  • Storyteller12
                    QN55Q60R Service Menu Panel Help
                    by Storyteller12
                    I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                    I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                    I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                    the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                    01-13-2024, 01:57 PM
