Philips 60pfl6008k/12 NVM needed
  • Alschepmist
    • Jul 2018
    • 70
    Hello guys i have problem with a philips 60pfl6008k/12 .
    The problem was a corrupted nand i have reprogrammed the nand with a generic qfu 1.2e la dump and the tv now works but i have a problem with the standby processor has anyone then NVM file backup from a working set? ?
  • William1967
    • Nov 2017
    • 217
    • Netherlands
    Re: Philips 60pfl6008k/12 NVM needed
    You mean this one?
    • Alschepmist
      • Jul 2018
      • 70
      I dont know i have to test it do you mean that will solve my standby problem?
      • William1967
        • Nov 2017
        • 217
        • Netherlands
        No, that file is to reset the NVM , the optionnumbers are set to a standard number where the tv can start up with, after starting up the optionnumbers must be re-aligned. I don't think the stand by problem will be solved, the stand by problem is known to me and came with repaired mainboards from a big German reseller. I think that problem comes from the NAND software.
        • janos6662000
          Philips 47PFS7509/12 LCD TV problem
          by janos6662000
          Hi
          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
          When i applied cable signal to check image, i had normal picture, but TV was restarting.
          I downloaded original firmware and applied the update, but the problem remained.
          From a colleague i received a "factory package software" which is a lot bigger.
          I made another firmware update, but still did not solve the problem.
          Somewhere on the way the error got worse, because at the moment the...
          08-12-2025, 12:54 PM
        • courtcircuit
          Philips HTS8000 home cinema noise problem
          by courtcircuit
          Hello
          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
          Removed each of tyhe boards
          02-08-2025, 08:22 AM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • bohaboha
          PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
          by bohaboha
          Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
          how to fix it thanks
          02-05-2025, 09:23 PM
        • rattlesnake
          Voltage issues SY-5SSM, where's the problem? Help needed
          by rattlesnake
          I'm trying to fix this SY-5SSM motherboard (Socket 7).
          When the PSU is connected it powers on by itself but there's nothing on the POST card, no beeps.
          The BIOS EEPROM is ok (latest BIOS was flashed).
          All the jumpers are set ok.
          All the 1000µF 6.3v (14) and 1500µF 16v (2) caps are in spec.
          There are two 76129D MOSFETs (datasheet). I took them out and tested them and they are ok (no continuity from drain to source) in off state.
          But the voltage in the gate of the second 76129D fluctuates between 1.468-1.649,...
          01-26-2025, 11:26 AM
