intergrated tcon board ic rt6939 vestel polaroid p55up0277a
  • jimbofz
    • Apr 2013
    • 539
    • uk
    #61
    Re: intergrated tcon board ic rt6939 vestel polaroid p55up0277a
    Originally posted by Diah
    since you dont have programmer tools so nothings you can do.. , i would encourage you buy replacement MB as it show at your country Ebay cheap so you can invest at it..
    ok thank you for all your help i will order main board
    • jimbofz
      • Apr 2013
      • 539
      • uk
      #62
      here is pic of screen the only thing you can see is my reflection in my workshop the light from window reflected
      the tv is upside down on workbench
      screen has very dark blue with no picture image
      • arizanotlari
        • Nov 2014
        • 158
        • Turkiye
        #63
        unplug lvds socket and take a picture please.
        https://www.badcaps.net
        • jimbofz
          • Apr 2013
          • 539
          • uk
          #64
          heres pic with lvds unplugged ,it looks just the same
          • arizanotlari
            • Nov 2014
            • 158
            • Turkiye
            #65
            Why leds shining blue?
            unplug lvds socket. Turn on tv and plug a dvd or receiver via scart. if you hearing sound panel is faulty. if still same...good luck.
            • jimbofz
              • Apr 2013
              • 539
              • uk
              #66
              i dont know why display is blue
              the backlights seem very bright viewed from the back of tv.
              i use satellite box i/p via scart . no sound,since f/w update.
              so is this important
              your f/w is
              :QNDS2DN12
              MY PANEL is type :VES550 QNDS 2D U12
              could it be the f/w is not the same ,would this explain why ,since f/w update i have no sound?
              • Diah
                • Feb 2013
                • 6605
                before you write FW the tv was installed so you can switch input to hear sound. complete firmware you did flashed the tv will be back to first installation page so no way to switch input. you can by pass it as blind way by pressing OK several time on RC and EXIT too.
                • jimbofz
                  • Apr 2013
                  • 539
                  • uk
                  #68
                  well than you once again with your help i now have sound via scart again
                  • geokyri
                    electronist
                    • Nov 2012
                    #69
                    Does anyone have some information about this capacitor, on the same t-con board from the discussion above ? Thanks !
                    • SolarFlare
                      • Jun 2022
                      • 7
                      • India
                      #70
                      sorry to waking this post again... I have the exact same issue and my tcon has the same components -RT6939 GQW. Its an MI tv and even I thought it was a cap that was shorted but now after reading this post I learn that its a fuse. Did you find a solution to this? I need help urgently.
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • x_orange90_x
                        TCL 50S535 bad tcon or panel issue?
                        by x_orange90_x
                        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                        03-29-2025, 11:02 PM
                      • advant
                        by advant
                        02-03-2020, 12:25 AM
                      • snimmits
                        Polaroid P43D300 (vestel 17MB97) issues (bluetooth & various sw bugs)
                        by snimmits
                        Good afternoon,
                        I have a Polaroid P43D300.
                        It shipped with WiFi and Bluetooth.
                        Two weeks ago, I ran through the first time installation.
                        This did a full reset and went through the first time setup.
                        Once complete, I went to settings > sound.
                        selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
                        search completes and doesn't find any devices.
                        I have tried everything I can think of.
                        Can someone provide...
                        03-01-2024, 09:26 AM
                      • Hakuu
                        by Hakuu
                        Hi There,
                        More Details
                        TV Model - LG OLED77G1PUA
                        07-12-2023, 02:37 PM
