intergrated tcon board ic rt6939 vestel polaroid p55up0277a
  • Diah
    • Feb 2013
    • 6599
    Re: intergrated tcon board ic rt6939 vestel polaroid p55up0277a
    Originally posted by jimbofz
    sorry i do not have a CH341A ,
    should i put it on my Christmas list?
    its cheap and useful,
    about U11 check first all V. on its pins , then try freeze it or heat before you turn on the set.
    • arizanotlari
      • Nov 2014
      • 158
      • Turkiye
      #42
      sorry been away from pc .
      does the last post from arizanotlari contain the correct firmware for my tv?
      if yes can i install this via usb ,
      considering i have no on screen graphics to enter correct menu
      my panel type:ves550qnds 2d u12
      Try it.
      https://www.badcaps.net
      • jimbofz
        • Apr 2013
        • 539
        • uk
        #43
        heres the voltages on U11 :
        1 3.38v, 2 3.38v, 3 3.4v ,4 0v,
        5 ov, 6 3.38v 7 3.26v, 8 3.26v
        no change with heat or freeze before turning on,tried a few times ,no change
        • Diah
          • Feb 2013
          • 6599
          compare the V. with U13
          • jimbofz
            • Apr 2013
            • 539
            • uk
            #45
            heres voltages from u13:
            1 3.25v, 2 3.2v, 3 0v, 4 0v,
            5 0v, 6 0v, 7 3.1v, 8 3.1v .
            so no volts on pin 3 and pin6 compared to u11
            • Diah
              • Feb 2013
              • 6599
              are you sure the info you wrote on yours photo below are 100% correct, both SPI had same No.25L1606E ?
              try the firmware from Arıza Notları
              while the tv ON, plug it from wall socket.. put all files on usb drive and insert it at any usb ports, press OK on the RC and keep pressing while you plug the tv in wall socket again... hope your screen will show progress
              • jimbofz
                • Apr 2013
                • 539
                • uk
                #47
                do the 3 files have to be in a folder,
                or do i load them on to usb
                as 3 separate items?
                ive double checked the voltages on U11 and U13
                and as you say i would expect them to be the same?
                • Diah
                  • Feb 2013
                  • 6599
                  all files on the root of the usb drive
                  about SPI.. my bad english.. i am asking if the both SPI lable are the same as you wrote 25L1606E on the paper
                  • jimbofz
                    • Apr 2013
                    • 539
                    • uk
                    #49
                    thanks your english is very good much better than my german
                    both SPI are the same 25L1606E.
                    i have downloaded and extracted the files ,
                    do they have to be in a folder or do i create a folder ? put the files in then send to usb?
                    • Diah
                      • Feb 2013
                      • 6599
                      i did answer before... no folder just all files copy them on the usb root LOL
                      • arizanotlari
                        • Nov 2014
                        • 158
                        • Turkiye
                        #51
                        Extract 4 files to USB (file sytem of usb drive must be fat32)
                        Plug USB Drive to USB 1 port of tv.
                        Press and hold OK button from rc and plug in ac cable.
                        Hold OK button until led blinking fast.
                        • jimbofz
                          • Apr 2013
                          • 539
                          • uk
                          #52
                          theres 3 usb skts, one is blue usb3.
                          the other 2 are not marked
                          looked on back cover and on pcb
                          i tried the usb next to the scart skt and followed your instructions
                          holding down OK button waited 5 minutes no fast blinking
                          so powered off and tried the side usb ,no change
                          only now when i removed the usb and powered on i cant get sound from scart i/p which i had before so now im confused
                          just looked on cct there labelled side usb, back usb, and usb3 which is the correct one?
                          • arizanotlari
                            • Nov 2014
                            • 158
                            • Turkiye
                            #53
                            Usb 1 is cn16.
                            Unplug lvds cable and try again.
                            • jimbofz
                              • Apr 2013
                              • 539
                              • uk
                              #54
                              Usb 1 is cn16.
                              ok tried with lvds cable disconected
                              using the usb next to the scart skt which is cn16
                              when fast blinking pauses
                              i remove power
                              reinstall the lvds and unplug usb
                              tv will come in and out of sby as before,
                              but cant get any sound via scart i/p
                              and pic just the same as before no osg or pic info
                              • jimbofz
                                • Apr 2013
                                • 539
                                • uk
                                #55
                                ok back to basics when the main board is working normally
                                it provides a enable voltage to turn on the dc/dc converter ics
                                on the intergrated tcon board .
                                now after trying to install the f/w
                                we still have no enable voltage on pin 22 or 30 of the lvds
                                neither of these pins are s/c or low resistance to deck .
                                if i could find out which is the enable pin in the two ics RT6939 AND RT6935 these ics are made by RICHTEC and their website has info on hundreds of ics that they make except the ones used in this vestel panel.
                                i may have to wait until i can compare with a working vestel
                                • arizanotlari
                                  • Nov 2014
                                  • 158
                                  • Turkiye
                                  #56
                                  After upgrade led must go off.
                                  If tv going to standby mode chassis is not working.
                                  You write u13 voltages before, this voltage values showing tv is standby mode.
                                  first make sure the tv is working.
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    • uk
                                    #57
                                    i know the voltage is strange ,
                                    i dont understand why ,
                                    but tv was definately on when voltages were measured ,
                                    as the backlight was lit and i had sound via scart i/p.
                                    but i now have no sound ?
                                    i will try the upgrade f.w again tomorrow
                                    • jimbofz
                                      • Apr 2013
                                      • 539
                                      • uk
                                      #58
                                      tried again f/w update when fast blinking finally stops waited until backlight came on and red led went out.
                                      them unplugged mains ,removed usb stick and powered up.
                                      tv comes on as before (dark blue image backlight on)
                                      but now with no sound via scart i/p
                                      so i checked the voltages on u13 again
                                      and pin 3 has no volts ,on cct its shown as write protection .
                                      pin 6 also has no volts shown on cct as sclk clock
                                      any ideas ? should i try to buy a main board ?
                                      • Diah
                                        • Feb 2013
                                        • 6599
                                        since you dont have programmer tools so nothings you can do.. , i would encourage you buy replacement MB as it show at your country Ebay cheap so you can invest at it..
                                        • arizanotlari
                                          • Nov 2014
                                          • 158
                                          • Turkiye
                                          #60
                                          Can you add photos of screen.
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • snimmits
                                            Polaroid P43D300 (vestel 17MB97) issues (bluetooth & various sw bugs)
                                            by snimmits
                                            Good afternoon,
                                            I have a Polaroid P43D300.
                                            It shipped with WiFi and Bluetooth.
                                            Two weeks ago, I ran through the first time installation.
                                            This did a full reset and went through the first time setup.
                                            Once complete, I went to settings > sound.
                                            selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
                                            search completes and doesn't find any devices.
                                            I have tried everything I can think of.
                                            Can someone provide...
                                            03-01-2024, 09:26 AM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
