intergrated tcon board ic rt6939 vestel polaroid p55up0277a
  • Diah
    • Feb 2013
    • 6595
    Re: intergrated tcon board ic rt6939 vestel polaroid p55up0277a
    for this cheap sets / mainboards don't have extra video processing ICs also usually all signal come from Main IC direct via LVDS to the panel.
    if you could upload focused photos on the main boards and the LVDS sockets from up and down side if there any remark on the pins.
    • arizanotlari
      • Nov 2014
      • 158
      • Turkiye
      Originally posted by jimbofz
      hi did you trace the source of the enable voltage from the main board? as Diah
      sugested ?
      ive studied the circuit and cant see where the enable comes from
      can you help? thanks
      Diah misunderstands me. Your panel is short circuited. I replace this ic but still not working. I send tv to panel repair workplace and they replace cofs.
      https://yadi.sk/i/_6VKMJQ4rQYiAA This is circuit diagram of mb120.
      https://www.badcaps.net
      • Diah
        • Feb 2013
        • 6595
        i see,,, so you have DC to DC correct working before replace COF.
        the signal which come from main boards via R440 100R connect to lvds socket pin30
        • jimbofz
          • Apr 2013
          • 539
          • uk
          heres the pics ,
          ive studied cct vbyone/lvds options
          and found r440 shown as : L dim en pin 22
          on the main board socket for lvds pin 22 is earth
          and pin 30 doesnt appear to have any connections to it ?
          after removing main board and tracing pin 30 ?
          i must be missing something
          • jimbofz
            • Apr 2013
            • 539
            • uk
            i didnt realise that it was possible to replace cofs
            • Diah
              • Feb 2013
              • 6595
              heres the pics ,
              could you locate on boards the U12 the MFC SPI 4Mb ?
              • Diah
                • Feb 2013
                • 6595
                this set had 2 SPI U13 for MBOOT. at your case its function... and the other U12 for MFC this is i do suspected.. MFC the displaying of picture.. normally the SW of vestel before we do have 3 parts 1-MBOOT.bin 2-MFC.bin & 3-opertion firmware. if MFC corrupted no display as yours condition.
                • jimbofz
                  • Apr 2013
                  • 539
                  • uk
                  #28
                  on my 17mb120 theres a u11 and a u13 ,but no u 12?
                  but on the circuit diagram u 12 ie shown.
                  • arizanotlari
                    • Nov 2014
                    • 158
                    • Turkiye
                    #29
                    Yes. Tvs all functions working correctly jus missing same panel pcb voltages.
                    • Diah
                      • Feb 2013
                      • 6595
                      are you sure ? on the downside did you check too.. look on number of it in schematic and look after all SPI with 8 pins
                      • arizanotlari
                        • Nov 2014
                        • 158
                        • Turkiye
                        #31
                        U12 is spi of U14. Your chassis have single lvds option and don't have U14.
                        I insist on cof failure.
                        • Diah
                          • Feb 2013
                          • 6595
                          arizanotlari... the schematic you upload here are for ONE CHANNEL LVDS. as the set of OP. MFC SPI U13 not U14..
                          do you have recovery firmware of this set with 3 files???
                          i have MFC.bin used by vestel such 246009 & 240226 which used over most vestel.
                          • arizanotlari
                            • Nov 2014
                            • 158
                            • Turkiye
                            #33
                            if you check page 14 of document you can see 1&2 lvds options. U13 is Mboot SPI not MFC.
                            U14 is position code of MFC ic.
                            Vestel dont allow access to firmware of export products. I have full firmware of
                            QNDS2DN12 panel : https://yadi.sk/d/QyY2xVD8ghxQYw
                            all my respect.
                            • jimbofz
                              • Apr 2013
                              • 539
                              • uk
                              #34
                              sorry been away from pc .
                              does the last post from arizanotlari contain the correct firmware for my tv?
                              if yes can i install this via usb ,
                              considering i have no on screen graphics to enter correct menu
                              my panel type:ves550qnds 2d u12
                              • Diah
                                • Feb 2013
                                • 6595
                                are you sure this label related to Panel Type ? not BL strings Type?
                                • jimbofz
                                  • Apr 2013
                                  • 539
                                  • uk
                                  #36
                                  this is the label from inside tv
                                  • Diah
                                    • Feb 2013
                                    • 6595
                                    okay.. i am little confused.. where are yours MFC SPI ?
                                    can you tell how many SPI you have on boards .. 8pins with label No had part on it 25L ?
                                    • jimbofz
                                      • Apr 2013
                                      • 539
                                      • uk
                                      #38
                                      here are some pics of main board hope it helps thanks
                                      • Diah
                                        • Feb 2013
                                        • 6595
                                        good work... so U11 yours MFC SPI.. do you have programmer CH341A ?
                                        • jimbofz
                                          • Apr 2013
                                          • 539
                                          • uk
                                          #40
                                          sorry i do not have a CH341A ,
                                          should i put it on my Christmas list?
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • snimmits
                                            Polaroid P43D300 (vestel 17MB97) issues (bluetooth & various sw bugs)
                                            by snimmits
                                            Good afternoon,
                                            I have a Polaroid P43D300.
                                            It shipped with WiFi and Bluetooth.
                                            Two weeks ago, I ran through the first time installation.
                                            This did a full reset and went through the first time setup.
                                            Once complete, I went to settings > sound.
                                            selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
                                            search completes and doesn't find any devices.
                                            I have tried everything I can think of.
                                            Can someone provide...
                                            03-01-2024, 09:26 AM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
