Westinghouse EW50T5KW no backlight
  • speter
    Been around the
    • 77
    I'm having a great week, I've checked my storage for a replacement TV to replace the 55" Vizio my daughter smashed, the first was the LG curved(panel failure?) then the TCL 55 (bad LED strips) The the Samsung 60" (shorted LEDs again) Now I'm looking at a Westinghouse EW50T5KW with a power supply problem. When it is plugged in all I get is the blue power light, I can't really see a picture with a flashlight, so I'm not sure if it is booting up
    I have 5V & 12V with the LED connectors unplugged and BKon jumpered to 5v and PSon jumpered to VSb I only get 5v at the backlight connectors, sometimes the PS will slowly pulse as though it's being dragged down, with BKon jumped. without BKon jumped the 5v and 12v are rock solid.
    I also have 5v and 12v with everything connected properly just plugged in.
    Nothing burnt, or bulged, nothing gets warm. i have checked for shorts on almost all of the semiconductors, without seeing anything.
    Goshen NY, USA
  • speter
    Been around the
    • 77
    Re: Westinghouse EW50T5KW no backlight
    I think I found it, Q203 seems to be shorted, it is hidden under the heat sink by the control connector, something weird is the schematic says SOT, but it is a TO220 style case, the number is hidden, the whole heat sink has to come off to change the device.
    Goshen NY, USA
    • speter
      Been around the
      • 77
      I was mistaken, it ended up the"shorted" device was D204 which is 2 diodes which are strapped together in parallel , so no short there, I was finally able to read the number to verify it, so it was good after all.
      Goshen NY, USA
      • speter
        Been around the
        • 77
        I've run out of ideas on this one, there is no activity on the HV part of the supply, and I can't find anything open, pr shorted. I'm giving up on this one...
        Goshen NY, USA
        • R_J
          • 9556
          You likely have a bad led string in the panel causing the led boost circuit to shut down. With the led's disconnected there will be no boost voltage due to no current being drawn. same as an open string.
          Monitor the voltage across EC202 when the tv is first turned on.
          Check if R151 is ok.
          Check the voltage Across EC104, this is the PFC_Vcc
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            What voltage do you have at LED_Vcc of Q102. With the power off, what is the resistance from LED_Vcc to HOT ground ( eg negative leg of EC101)
            Check D1, D2, D3, D4 and D123 connected to T103
            • speter
              Been around the
              • 77
              I am going back to it in a minute, I never see more than 5v across the LED strips or connectors, plugged in, or not, the caps upper right first pic, never charge. I'll get back with the other info shortly.
              Goshen NY, USA
              • speter
                Been around the
                • 77
                R151 reads .3 Ohms, no voltage across EC202, EC104 is .06v without BKon jumpered to 5v 1- 8V pulsing with it jumpered.
                12v and 5v are also pulsing 40%? with BKon jumped, but solid when BKon is not jumpered. Q102 LED VCC is 5 - 9V pulsing with BKon jumpered, .05 when not.
                Q102 LED VCC reads open to ground.
                D1,2,3 and 123 check good, D4 is not used on this board
                I found another thread on this board, or a very close cousin, I will read through that as well
                https://www.badcaps.net/forum/showthread.php?t=54024
                It seems as though when Q110 is turned on Vcc drops causing things to go crazy, Checking R109
                Goshen NY, USA
                • speter
                  Been around the
                  • 77
                  Well. it wasn't R109...
                  It cycles drawing 0 then 19w repeating if Bkon is jumpered
                  Goshen NY, USA
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    What voltage do you have across the two pins of EC101 and EC107 with and without Backlight jumpered?
                    I think the PFC is not working. PFC_Vcc should be typically 12V
                    • speter
                      Been around the
                      • 77
                      EC101 pulses between 250-320v with BKon jumpered 161v not jumpered
                      Ec107 pulses between 4.5 and 8v with BKon jumpered 13.3 not jumpered
                      R135 never has voltage across it, so it's never trying to power T103
                      There is no voltage at pin 6 of u103 when BKon jumpered
                      Goshen NY, USA
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        The 13V at VCC (EC107) looks good so with the set powered off what is the DC resistance of U102 between Vcc (Pin 8) to GND (pin 6)
                        With the power on and no backlight jumper what are the voltages at Q102 & Q110 emitter, base & collector.
                        • speter
                          Been around the
                          • 77
                          Pin7 of u102 gives pulses of up to 1.5v, my meter is not very fast, so it could be higher. Bkon jumpered
                          The gate of Q103 has similar readings
                          Resistance between pin 6 and 8 is open
                          Q110 Ebc 13, .4, .3
                          Q102 voltage less than .5v on c and b, 0v on E Voltages start at .5, and drop as the ps is on longer
                          I wish I had FLIR, something takes 20W during the cycle
                          I soldered a bleeder resistor across EC101 so the PS resets faster during power tests.
                          Goshen NY, USA
                          • speter
                            Been around the
                            • 77
                            Q103 is supposed to boost the voltage?
                            Goshen NY, USA
                              • 12206
                              • U.S.
                              Maybe check resistor R250 and the rest, diode checking video, just for anyone looking on
                              that may need it: https://www.youtube.com/watch?v=BXOS5czCb3Q
                              • speter
                                Been around the
                                • 77
                                It checks good, that whole area checks good, and is basically dead(voltage wise) always.
                                Thanks for the suggestion!
                                Goshen NY, USA
                                  • 12206
                                  • U.S.
                                  Maybe heat up your electrolytic caps with a hairdryer, can heat the ceramic caps too, see if the tv acts any different.
                                    Are you getting about 380vdc PFC Boosted Voltage when TV is turned on or when the board is forced on?
                                    • speter
                                      Been around the
                                      • 77
                                      When Bkon is forced on it attempts to boost, but only in cycles, it gets 250 - 320 in waves. and it drops 12v, and 5v while trying.
                                      When BKon is not forced, no boost at all
                                      Goshen NY, USA
                                        That means you will need to fix the PFC boost circuit or find out if something else is causing the PFC not to function properly.
                                        • Nicktronic
                                          Westinghouse W55UW4620 No Video
                                          by Nicktronic
                                          Ok, so I know I know, it's a Westinghouse....lol It's got the backlights but no video. Likely the panel, but I'd like to take some measurements on the buffer board with help from you experts to confirm. See the attached pictures. In pic #1, there's a nice pin reference to use to take some measurements. The large IC in pic #7 gets up to 60degC when the TV is on.
                                          So, backlights, no video, go! 🙂...
                                          06-03-2024, 03:21 PM
                                        • EBW
                                          Help Request - Westinghouse 32" Smart TV (Model: WD32HBR105)
                                          by EBW
                                          Westinghouse 32" Smart TV (Model: WD32HBR105) . Originally stuck on logo with no response from remote and no firmware file available to flash via USB. Westinghouse Support stated it would require service but that wasn't a cost effective option. I used dental floss to remove the motherboard processor heatsink to identify what make it was (Mstar). Unfortunately that knowledge didn't help with a solution. After the heatsink removal it only displayed a completely white screen. I then decided to replace the motherboard with a universal 3-in-1 board but the white screen problem continued. This...
                                          10-27-2022, 06:32 PM
                                        • Seville
                                          Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
                                          by Seville
                                          Hello all!
                                          Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
                                          I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
                                          10-10-2022, 07:31 AM
                                        • JayPoorJay
                                          Westinghouse Roku WR58UX4019.To be or not TV,,, That is the Question
                                          by JayPoorJay
                                          Hi All... Me again. Begging for help. The guy who now believes it's possible to fix a TV (one of the millions) one can find on the streets of NYC. I hate hate hate waste...
                                          Thanks to y'all's help I fixed and am happily watching a 70inch Sharp Aquos. Perfect. Learned a lot, replaced LEDs. Pulled screen/panel. Proud.
                                          This is a newer set. It's a Westinghouse Roku WR58UX4019. It was RIGHT outside my place literally, and I couldn't resist. 58in. 500$ new, but I'm not a rich man. So, I want to try.
                                          There is sound. It turns off and on. Screen is black. I can...
                                          03-17-2022, 05:27 PM
                                        • flashcoder
                                          Westinghouse DWM40F1G1 backlight blinks and turns off
                                          by flashcoder
                                          I got this TV (Westinghouse DWM40F1G1) that did not came on one day, blinked for a split second and turned off. I looked at it closer with flashlight and figured that the TV actually works, its just the backlight that does not.
                                          There is one PCB board - all of the components are on it: TP.MS3393.P85
                                          I took my oscilloscope and looked what is coming to the MOSFET that is switching current to LEDs - I could see that the PWM signal comes in but it cuts off almost instantly. I thought its the driver chip OB3350CP and so I replaced it.
                                          After that the...
                                          11-16-2021, 02:12 AM
