Samsung LE37B650 white screen
  • XPloRR
    • Sep 2023
    • Belgium
    Re: Samsung LE37B650 white screen
    Originally posted by Jovica123
    Thank you,fixed my samsung 37" by removing this ic (as34-g)
    Which of the 2 chips did you remove? If you look at the front of the TV, the left or the right one?
    • XPloRR
      • Sep 2023
      • Belgium
      Originally posted by xname
      Another case of white screen here, succesful case of repair by removing AS34-G. The question was which of them is bad, I desoldered first one and unfortunately it was good, therefore second disassembly and soldering first and desoldering second chip (with front view on the left) led to success. Thanks for THE ADVISE!!!
      • XPloRR
        • Sep 2023
        • Belgium
        Hello
        • XPloRR
          • Sep 2023
          • Belgium
          Originally posted by aczelkri
          Hey guys,
          Just thought I would share the details of the successful repair. I took the TV today to a local service facility. The guy told me that the issue with the TV is a very rare one. Still, maybe it helps someone.
          What did NOT fix the issue
          • Replace the AS15 chip on the tcon board
          • Swapping the full tcon board (or any other board) with another one
          • Replacing cables
          So now, let's skip to the chase: what DID FIX it. Both of the aforementioned "long boards" had an operational amplifier on them each (looks just another IC to me, see images). One of them turned out to be bad. The guy simply unsoldered it from the board and the TV immediately started to work perfectly.
          I was shocked to see how removing something and not putting it back can solve things, but the guy said that actually there's quite a few things he could remove from the TV set and it would still operate perfectly.
          He removed the chip on a hunch btw, so there were no measurements that could have indicated that it was bad. He just tried and bingo!
          Hope this helps someone.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4542
            • Italy - Milan
            it is not a call center here..
            • nomoresonys
              • 12331
              • U.S.
              #26
              Well turn it on and feel them, guess I would remove the hottest one.
              • thetron
                • Oct 2023
                • 6
                • Poland
                #27
                Hi, I have the same symptoms on my Samsung LE46B650
                I think aczelkri may have answered this in their reply already, but I will ask anyway:
                Is there a way to diagnose if the problem is with the AS15 gamma chip on the T-Con board OR if its a problem with one of the chips on the thin Column driver board?
                Also, How do you get access to the column driver board to desolder the other chip as your TV service person did? I've got the back off mine now, with Tcon board exposed, but the column driver board appears to be sandwidched between two pieces of sheet metal from the frame.
                TIA
                • nomoresonys
                  • 12331
                  • U.S.
                  #28
                  Some tvs are a lot harder to get to the driver boards, you probably have one more like this one, where he needed to take off the metal frame to get access: https://www.youtube.com/watch?v=EO2gHBJCvH0
                  • nomoresonys
                    • 12331
                    • U.S.
                    #29
                    Note: I don't recommend removing the panel with that particular technique, very easy to break it, specially the bigger ones. Just showing the teardown to the driver boards.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4542
                      • Italy - Milan
                      #30
                      sarch for the messages of tom66 and the word as15, then test the vgma testpoints with the panel disconnected..
                      • thetron
                        • Oct 2023
                        • 6
                        • Poland
                        #31
                        Thanks for the tip, that's very helpful. Shame I have to take a lot more apart, I was hoping these would be fairly easy to access and check at the same time as the T-Con board.
                        • thetron
                          • Oct 2023
                          • 6
                          • Poland
                          #32
                          Awesome, thanks.
                          • nomoresonys
                            • 12331
                            • U.S.
                            #33
                            Indeed most of the newer ones are much easier to access but those older ccfl tvs are made very well and have in my opinion much less trouble, also I like the picture quality much better than any edge lit led backlit tv I have seen.
                            • thetron
                              • Oct 2023
                              • 6
                              • Poland
                              #34
                              I've read up on testing the AS15 chip. I think it's probably not necessary as I did the 'put your finger on it while the TV is turned on' test and it gets bloody hot after a few seconds.
                              .... but to be doubly sure I'm going to go ahead and measure the voltages as well. I've found the test pads next to the AS15-U chip, but my question is: Should I have all the numbers from 1-22? My pads start at one, two, then jump up in twos to 10, then 11, 12, 13. then up in twos again and ends on VG22.
                              So in total the numbers go from VG1 to VG22 but there are only 14 pads. Is that normal? Can I still use the spreadsheet with these values?
                              • thetron
                                • Oct 2023
                                • 6
                                • Poland
                                #35
                                Well I don't have all the numbers but I think that's pretty conclusive.
                                Looks like it's soldering time
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4542
                                  • Italy - Milan
                                  #36
                                  go go..
                                  • KYBOSH
                                    • Oct 2011
                                    • 581
                                    • Unknown
                                    #37
                                    Unfortunately none of the pics are ahowing on this thread. I would have loved to see what was going on.
                                    • nomoresonys
                                      • 12331
                                      • U.S.
                                      #38
                                      I have read this thread and understood it, going from info. of post #16, it's my understanding that the problem is one of the components on the panel driver boards. So I would not be surprised if the as-15 chip replacement did not work.
                                      • nomoresonys
                                        • 12331
                                        • U.S.
                                        #39
                                        I think there's a few members here that do not bother to read the entire thread, hence jumping to conclusions. Not saying that the as-15 isn't bad, just that there is another possibility as explained in earlier posts.
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
