dikom 22 lcd blown mosfet replacement
  • dellxps15
    • Feb 2014
    • 1591
    • italy
    hi all today i got this tv with 1 sec backlight and no lcd image. after open it i found one blown mosfet Q11. after remove itr and check value i see it was lcd vcc, so did a jump after turning tv on and image (without backlight) comes in.
    mosfet is mb9495e and cant find it anywhere. source was 5 volt, gate 5 volt and when i turn tv on gate goes to 0 , so it should be a n channel mosfet.
    any suggestion on wich common mosfet i can use on that ? it will power lcd a 22 inch.
    mainboard code is HD_D7102 rev 3.0 and its a common mainboard for low price tv-ready.
    if i can fix that mosfet for low price, i can go and change ccfl for around 30€ and bring that dead tv back to life
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: dikom 22 lcd blown mosfet replacement
    Check u19. It looks cracked.
    • dellxps15
      • Feb 2014
      • 1591
      • italy
      tnx for reply. u19 is ok. was just some thin dust or similar
        • 21191
        Its an N channel mosfet, theres many differet parts with that part number 9435A ,i did find a datasheet though BM9435A
        EDIT: see the attached Teac lcd221sd-service-manual. It has a different mainboard and the circuit may be different. Search for Q11 and 9435A
          5V on Source pin means it is P-CH, so for it to be on the Gate has to be about 3V < than Source pin, you have 0V when unit is turned on so that is correct.
          That MOSFET is for supplying switched Voltage for the T-CON.
          The link on post #4 is fine to use.
            • 21191
            Sorry budm,i did mean P-CH ,it was a typo .
              That's what I thought since you did find the correct MOSFET.
              • dellxps15
                • Feb 2014
                • 1591
                • italy
                wow tnx very much for the reply. so if i get a FAIRCHILD 9435 would also be ok right ?
                and if i use a normal p-channel that i have for notebook ?
                like this one http://aosmd.com/pdfs/datasheet/ao4407.pdf
                better stay safe and get that 9435 series ?
                  The 4407 looks to have the same pinout and handle more current and lower Rds, but the typ. Vgs is higher (-2.25V VS -1.5V).
                  You can try it out but you need to check the Voltage between Gate and Source to make sure it is at least 2.25V or more to make sure it is fully on.
                  • dellxps15
                    • Feb 2014
                    • 1591
                    • italy
                    when board is off i have 5 volt on gate and source. when power on the board i have 5 volt source and 0 volt gate.
                      Just to be sure, you need to measure between Gate and Source pin, not Ground.
                      • dellxps15
                        • Feb 2014
                        • 1591
                        • italy
                        hi all, today after first ship didnt arrived, i ordered a second time that mosfet and tv was giving image back, but i noticed some weird issue :
                        if tv start with backlight, i have no sound, and if i disconnect the backlight 12 volt connector that goes to the transfoermers, i have audio working fine, but as soon as i plug the backlight cable and got perfect image on lcd, audio dont work annymore.
                        what could be the cause ?
                        also that tv has an integrated dvd rom. if i playback a movie, i have no audio and after 5-10 mins the image start goin on and off and voltage measuring goes crazy, i didnt try the dvd video playback with the backlight cable disconnected to see if i have audio.
                        sometimes both audio and backlight were working, but audio was not 100% working, it randomly goes on and off.
                        • dellxps15
                          • Feb 2014
                          • 1591
                          • italy
                          i made some measurement and when i have audio, on red dot i have 11.5 volt, while when there is no audio, i have 5.12 volt.
                          sometimes i have 11.5-11.8 volt on that red dot with working backlight and audio too is working fine.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            That's the mute input pin to the audio amp. Check the headphone socket is in good condition.
                            Check connector J9 that the mute switch pin 7 is secure
                            • dellxps15
                              • Feb 2014
                              • 1591
                              • italy
                              ok i see that m/ss on similar schematic posted on N#4 . i tryied plug in headphone and as i plug them i ear sound on headphone, but inssert and remove headphone didnt give back sound to speakers.
                              also if i turn off tv, if tv start without backlight i ear sound, but if tv start with backlight, i have no sound
                              • dellxps15
                                • Feb 2014
                                • 1591
                                • italy
                                i dont have that j9. it must be a separate j pinout as i have 3 pin for ch+ ch- source menu vol+ vol- and power on/off.
                                also audio without touching anything sometimes work after a while sometimes goes off, on again.
                                other big problem is dvd play. as write on previous post, if i play a dvd rom, i have image but no audio and after 5-10 min video goes on and off and volts reading goes crazy.
                                im suspecting a big chip failure at this point.
                                ive found a similar board with different brand for 20€, but dunno if it will work fine, will last fine and even more dunno if that tv is worth the repair ( its not even hd ready.. selecting a dtv hd channel it say not supported)
                                • dellxps15
                                  • Feb 2014
                                  • 1591
                                  • italy
                                  update: after some time tring to figure out wat was wrong, i ear a noise from psu when backlight and audio were both working. i measured psu volts (its external 12v 5A) and measured 12volt when tv is powered off. when i power on tv volts goes down to 6 volt then back to 10-11.5 volt max and psu was getting really hot.
                                  i tried with bench psu and each time i got stable 12 volt ofcourse and Ampere were going from 0.11 in standby to 4.5 when tv was powering on and go to a stable 4.04A when tv was on with both backlight and audio working on each power on off try i did.
                                  today i opened the psu and found the 120uf 400volt capacitor blown, another 1000uf 16v blown. ill replace all caps in here and post results tomorrow.
                                  • dellxps15
                                    • Feb 2014
                                    • 1591
                                    • italy
                                    update of today: i replaced the caps on psu and now tv is working fine and in all function
                                    tnx for the help
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      Thanks for the follow up.
                                        • 12206
                                        • U.S.
                                        Nice work, many times an audio problem as you described is a good indication of a bad cap/s. I would have suggested it but I guess I assumed that you already looked them over.
                                        • nubie
                                          Rosewill Tokamak 1200w blown mosfet 5R199P
                                          by nubie
                                          Rosewill 1200w blown APFC? Mosfet.
                                          I got this with a blown fuse. Replaced fuse and the APFC mosfet blew.
                                          Removed the mosfet and got 5VSB, then when I connected PWON to ground the Fuse blew again.
                                          So do I need to replace the mosfet? Or should I be looking elsewhere? Thanks.
                                          According to a review of the 1500w unit there is an option for 4 transistors instead of 3 and they are different: https://www.tomshardware.com/reviews...su,4823-3.html
                                          07-02-2024, 05:33 PM
                                        • FriedFred
                                          ASUS ROG STRIX G713IC-HX041W, Mainboard G513-MP-GBM, battery shorted out
                                          by FriedFred
                                          6050A3249305-MB-A01
                                          2021-11-05
                                          Hello, everyone!
                                          I have some trouble with the G513-MP-GBM board, it's from an ASUS ROG STRIX G713IC-HX041W.
                                          The total current consumption was about 200mA. The 0.8 Volt rail at the CPU was correct working.
                                          But the power button has not been pressed...
                                          I found some spurious solder between the pads 6 (VRA_SVT) and 7 (APU_PWR_EN) of the PWM-controller, "U66000".
                                          Which can explain why this power rail has been starting without...
                                          01-19-2025, 09:00 AM
                                        • DoOm86
                                          Dual mosfet replacement help
                                          by DoOm86
                                          Hello.
                                          I have a notebook with a shorted mosfet, it's a E6930 GA8125.
                                          It seems to be a 30V dual asymmetric N-channel AlphaMos.
                                          Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
                                          And here is where I need help!
                                          It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
                                          I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
                                          Thanks!...
                                          10-31-2023, 12:03 PM
                                        • davidebaldini
                                          ATX power supply keeps blowing PFC mosfets — Cooler Master RS-550-ACAA-E3
                                          by davidebaldini
                                          This is an ATX PSU rated for 550W powering 24/7 a computer load of about 200W, fed by a line-interactive 1500VA UPS. Mains is 230V.
                                          1. First issue: the PSU blew a mosfet on what I think is the active PFC boost converter, shorting its G D S pins together causing a short across the + and - lines produced by the rectifier on the 230V mains. The surge protector of the house tripped. When this happened I found that the UPS was unexpectedly disconnected from the wires of its battery. The UPS wasn't damaged, but I suspect this spontaneous detachment of a battery wire caused a condition that blew
                                          01-25-2023, 02:23 PM
                                        • tofik
                                          MOSFET equivalent K8A60DA
                                          by tofik
                                          Hello guys,
                                          I have a shorted MOSFET K8A60DA with the following characteristics:
                                          Type Designator: TK8A60DA
                                          Marking Code: K8A60DA
                                          Type of Transistor: MOSFET
                                          Type of Control Channel: N -Channel
                                          Maximum Power Dissipation (Pd): 45 W
                                          Maximum Drain-Source Voltage |Vds|: 600 V
                                          Maximum Gate-Source Voltage |Vgs|: 30 V
                                          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                                          Maximum Drain Current |Id|: 7.5 A
                                          Maximum Junction Temperature (Tj): 150 °C
                                          Total Gate Charge (Qg): 20 nC
                                          Rise Time (tr): 25 nS
                                          Drain-Source
                                          07-19-2023, 05:18 AM
