Bad LCD panel? Samsung LE37A556
  • dominik0801
    • Feb 2018
    • 98
    • Hungary
    Hello.
    Today I got a TV. To be more precise, I bought some bad TVs to fix then resell. This one arrived today.
    The seller only stated to have a negative color. Pictures were not attached of it tho.. this is where I f..d it up. I still bought it.
    Well, the TV didn't even turn on. The LED just blinked. Taking it apart I noticed, that cables are cut, the TCON "shield" is gone, PSU is bent horribly, and the AS15 chip was missing from the TCON board...
    Fast forward, I managed to fix most of the problems, put an AS15 on the TCON too, popped it in, turned on the TV, and finally it worked (kinda), but the picture was as you can see on the attached picture...
    I understand, that the AS15 chip I used could be also bad, however, what could be those 2 vertical lines? Is it from the TCON? Or the LCD panel itself?
    Because if it's not worth my time, I am just gonna try to sell the working parts from it..
    Thanks in advance, Dominik.
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Re: Bad LCD panel? Samsung LE37A556
    im not an expert but i would guess issue could be the bonded tabs on the lcd panel..i dont think vertical lines are tcon related
      • 12323
      • U.S.
      Wonder if it could be a slight mis-alignment, try carefully cleaning and reseating the tcon ribbon cables and lvds cable from tcon to mainboard. Some use isoprophl alcohol or a pencil eraser, be careful they are delicate.
      • dominik0801
        • Feb 2018
        • 98
        • Hungary
        I put this TV on hold, because I have 2 another LED TVs that I want to fix. After those are done, I will come back to this one.
        However, I tried cleaning the LVDS and ribbon cables between the TCon and the panel. That didn't change anything.
        But i am stubborn so I can not give up..
        if nothing works out, im gonna try to fiddle around and check if a tab is bad.
        • shelby5041
          • Feb 2009
          • 1505
          my guess is the bonded tab is the issue in that area of the screen
            • 12323
            • U.S.
            Could be, hard to tell til you strip it down, inspect it, maybe put a little pressure on the tab, see if it changes any.
            • shelby5041
              • Feb 2009
              • 1505
              Yeah snd stripping down can be very time consuming and psin in butt...nowadays sometimes its just not worth it since used working lcd tvs have very little value...here in usa used 32inch lcd tvs may sell for 25-50$
              And a 50 in lcd may fetch 75$
              • dominik0801
                • Feb 2018
                • 98
                • Hungary
                oh, the prices really differ then. here, in hungary, a 32" tv mostly sold at $70-$100.
                if i will have the mood, i will take a look at the tabs.. i just want to get back at least the price i paid for it.
                that guy really scammed me
                  • 12323
                  • U.S.
                  Oh, hell no, I wouldn't replace backlights on a 37 inch tv, unless I had a spot where only that size would work but never to try and sell.
                  • shelby5041
                    • Feb 2009
                    • 1505
                    Yeah usa is diff market...hell you can buy a brand new 32in lcd tv for 100 or less
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                      09-07-2024, 05:50 AM
                    • netgearnetgear
                      TCL 43S423 TCON OR PANEL FAULTY???
                      by netgearnetgear
                      Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                      08-20-2025, 06:04 PM
                    • x_orange90_x
                      TCL 50S535 bad tcon or panel issue?
                      by x_orange90_x
                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                      03-29-2025, 11:02 PM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
