SONY Bravia kdl-40w4100 bad Tcon sympthons
  • sidgallup
    • May 2014
    • 13
    • mexico
    Ive had this TV for years and this is the first tie it has gave me problems.
    When it gets hot (after 15-20 minutes) the image starts to look brighter than it should, colors distorted, and the longer its on the worst the issue becomes.
    Ive read this is a classic issue on older TVs with AS15 ICs, but this particular model does not have an AS15 chip on the Tcon board, does anyone have experience on this particular model? does this TV even use an AS15 chip? i cant find it unless its labeled as somehing else or is located on other board and not on the T-con.
  • yokoono
    • Apr 2010
    • 515
    Re: SONY Bravia kdl-40w4100 bad Tcon sympthons
    AS15 is a gamma corrector. Look for on the t-con, after the datasheet, an integrated one with these functions.
      Show us the pictures of the boards and the whole back side of the TV showing all the boards so we can see what we are dealing with.
      • sidgallup
        • May 2014
        • 13
        • mexico
        Sorry for the late rerply, ive been busy with a lot of work... anywys, heres some pics of the boards
        https://imgur.com/a/OGOTTWj
        Im also uploading a video to Youtube where its clearly visible the issue im facing. I still cant find the AS15 IC anywhere, unless its below that big heatsink on the mainboard? who knows maybe some of you can help me.
        EDIT: Heres the video https://youtu.be/jLV7Qiprdz0
        what could it be? as i expalained, image gets worse and worse the more its turned on, whatever the issue is the component responsible starts failing when it gets hot.
        • Daren87
          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
          by Daren87
          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
          08-13-2023, 03:25 PM
        • JUCaESAl
          Sony bravia KD-65AF9
          by JUCaESAl
          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
          10-20-2025, 04:03 AM
        • swrb898
          Sony KD-70X690E Bravia; Bad TCON? Bad panel?
          by swrb898
          What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
          Problem:
          Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
          My troubleshooting got me this far:
          With the left-hand TCON to bottom-board ribbon cable...
          12-28-2021, 08:12 PM
        • iglitare
          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
          by iglitare
          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
          Backlight seems to work, Sound (Setup menu after reset) works.
          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
          With my small knowledge i would think at least the cables are good.
          Can this happen because of a bad tcon board?
          Or is it always a bad/shorted...
          09-04-2025, 07:13 AM
        • PopsCaps
          Sony Bravia KDL-40V2500 that will not power on
          by PopsCaps
          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
          I do not hear any sound and I cannot see any backlight.
          I have tried disconnecting every cable on each board one at a time to see if anything changes.
          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
          03-25-2025, 11:23 AM
