Compatibility issue?
  • RooTV
    • Apr 2020
    • 128
    Hi there
    I have a LG 55LB5820 - TB and need to replace the power supply.
    The power supply I have is EAX65423801 rev 2.0
    I have found a EAX65423801 (2.1) from an LG 50LB5610 and the markings on it are:
    PCB: EAX65423801 (2.1)
    REV2.0
    2013. 12.10
    Would this be compatible? Not sure as it is a different size tv
    It is the same part number but different revision?
    Is that just a software difference or can it be a part difference?
  • neilc6
    • Nov 2015
    • 1550
    Re: Compatibility issue?
    That is the blank PCB part number and it could be populated differently for different models. The connectors may be different. Different size tvs will have different configuration and voltages for the LED strips so likely it will power the main board but not the LED backlight.
      • 12074
      • U.S.
      Those two boards look pretty identical, I would be surprised if it DIDN'T work.
      • RooTV
        • Apr 2020
        • 128
        Ok thanks
        • diif
          • Feb 2014
          • 6978
          • England
          There's 10 LEDs different between those two models, they will be putting out different voltages.
          • handsworth
            • Oct 2015
            • 174
            They both look identical except one transformer is white and the other is blue. However there is a difference in voltage. Stay with the one you have
